B7200 hydraulic steering
7,377
Haha - glad you're keeping an eye on this and thanks for the suggestion....same as what I posted as a question above at post #60. Makes me feel good when someone who knows stuff makes the same suggestion as me.
The distance between the knuckles
is critical to wheel alignment. Measure the length of the cylinder and the center to center knuckle spacing to see of thats even possible.
7,377
I assumed you had all of this worked out before buying the BX bits. As best I can tell Kubota B series tractors used the drag link and tie rod steering design paired with a an old school PS gearbox up until the B01 series (2018) when they switched to hydrostatic. Measure the length of your BX cylinder and compare to the length of the B7200 tie rod.
Paul Allwood
Kubota B7200HSTD, homemade FEL, front flail mower, forks & ballast box, tiller
Jul 8, 2025
833
1,553
Haha - don't assume too much. No, I didn't have it all worked out, just some rough ideas and figured I'd be able to make it work somehow.
Looks like it's back to Plan A.
Rather than just looking at it and speculating, I measured a few things....
The full lock to lock left to right travel of the steering connection in the green circle is approx 300 mm.
The full lock to lock forward and back travel of the steering connection in the red circle is approx 150 mm.
The full travel of rod in the double ended steering cylinder is 160 mm, and with the ball joints and tie rod ends fitted it's a bit more than 100 mm longer than the left to right steering link.
I won't be able to swap the left and right steering knuckles as the steering cylinder assembly is too long by a bit over 100 mm and it's travel is too short by 140 mm.
Back to Plan A....
The steering cylinder replaces the dashed yellow steering link with a ball joint attached at the red circle. It's travel is within about 10 mm of the full travel of the yellow steering link. I'll make a bracket that bolts between the standard BX mounting brackets and attaches to the chassis with another ball joint somewhere close to the clutch pedal end. I don't see any of this being overly difficult.
Hopefully some pics of the real brackets when I get around to making them might make more sense than the dodgy description above.
7,377
Haha - don't assume too much. No, I didn't have it all worked out, just some rough ideas and figured I'd be able to make it work somehow.0
Back to Plan A....
Thars pretty much what I expected.
I am goung to say this one more time and shutup. I think you will be miles ahead by ditching that BX cylinder and replacing the drag link with an aftermarket cylinder designed for that type of operation. They are cheap ($75-$150), readily available, and damn near trivial to fit. Thats exactly what you pictured earlier in this thread.
Paul Allwood
Jul 8, 2025
833
1,553
Haha - thanks. I've got the message. But mounting the cylinder I already have won't be very hard, and I already have it.
airbiscuit
Mar 18, 2021
439
499
NW WI
This might be the easier way for you to add power steering.
Paul Allwood
Jul 8, 2025
833
1,553
Thanks. I have seen this video, and it would be an easy way to add power steering for a tractor with a nice strong steering box. The problem with this approach on my tractor is that it would just allow a much greater force to be applied more easily to the input of the small steering box and possibly break it more easily.
11,302
Admins - is it possible for me to move posts #53 and #55 to my "B7200 hydraulic steering" thread ?
Next time you want or need posts moved, please give me the place to move them to.
This thread was 12 pages back and 20 threads per page back in your history. 😋 ;)
Paul Allwood
Jul 8, 2025
833
1,553
I made a start on the hydraulic steering today. The play in the old steering box has been slowly getting worse - thought I better do something with the bits I bought ages ago before I have no steering at all.
Here's a shot of the front of the crankshaft pulley looking under the radiator. Easy enough access and already had two M10 x 1.25 threaded holes ready to attach the latest fashionable accessory.
I was able to gently run a tap into both holes to clean out the rust.
After tapping they look like new.
I turned a point on a couple of bolts and screwed them into the holes so I could measure the centre distance....a nice even 70 mm.
Next I welded one side of a Lovejoy coupling to some 12 mm flat, then turned and drilled it to fit the mounting holes on the crankshaft pulley.
I'll fit a shaft into this coupling, run it out under the radiator to another of the same coupling onto the hydraulic pump.
7,377
Looking good. Just FYI Kubota used a solid splined coupler and if needed a flex coupler on the outboard end of the shaft.
Paul Allwood
Jul 8, 2025
833
1,553
The bracket to mount the new hydraulic pump is made. I started with a piece of angle iron and drilled, bored and cut away all the bits that didn't look like a pump bracket.
I clamped the angle iron in the 4-jaw chuck and started by drilling a hole big enough to fit my boring bar....
Bored the hole out to 2" diameter to fit boss on the mounting flange of the pump....
A bit more....
Now it fits nicely....
I may need to take some material out of the bottom arm of the angle iron below the shaft. This will depend on the OD of the Lovejoy coupling - it should be here in a few days.
Apart from being a bit new and shiny, it almost looks like it belongs there....
Next job is to mount the hydraulic cylinder.
Paul Allwood
Jul 8, 2025
833
1,553
I decided I wanted to use countersunk screws to attach the flange to the crankshaft pulley. Seemed like a good idea. But the two local specialist fasteners suppliers I go to both said countersunk socket screws in metric fine (M10 x 1.25) are not a thing.
So the next best thing would be to use a standard socket head cap screw with a counterbore. So what do you do when you want to counterbore 17 mm diameter for the head of a M10 SHCS but you don't have a counterbore tool to keep it centred about the original 10 mm hole ? You make one....obviously.
7,377
A bit more....
I am not trying to nit pic but dont you think that mount needs to adjustsble so you can dial in the shaft runout?
Paul Allwood
Jul 8, 2025
833
1,553
Thanks for the pics, Dan. No need to feel like you are nit picking - I'm always open to alternatives. It's funny how many times I find out that someone has already had a better idea.
That looks a bit different to what I was planning. I was going to have a Lovejoy coupling at the flange bolted to the crankshaft pulley. Then a shaft running under the radiator to another Lovejoy coupling that would fit onto the pump shaft. This was my attempt at preventing any sideways load on the pump shaft.
In your pics, is the end of the shaft close to the pump (circled in green) supported by a bearing, and is this intended to prevent any side load on the pump shaft ?
7,377
I have done a l9t of these and used various designs but they are all similar.
In my picture the crankshaft pully hub has some small flexibility provided by rubber bushings in the mounting holes. There are no bearings and the slots are used to dial in runout at installation
This is one historical OEM setup used in the 50s and 60's. It used the same hub as mine and an outboard flex coupler but still needed to be roughly dialed in at the pump end.
Your two piece couplers are limited in the amount of angular misalignment they can handle and the more there is the more side loading on the driveline components, and pump input shadt and the shorter their service life. JMO but I have done lots of front pumps and I think you will be better served with a two piece base that allows both horizontal and vertical adjustments.
The engine on the B7200 is rigidly bolted to the frsme so an adjudtable base lets you dial in the driveshsft to the point where you have almost no runout. One flex coupler is more than adequate and Kubota's later loader designs used a chain coupler on the pump input shaft. It was a very robust and compact drive.
Dab
