Front loader for a B7200
3,741
2,312
Many thanks ProTreeBoy. When you say "the main lines", do you mean the line from the hydraulic block to the valve and the line from the valve power beyond port back to the valve ?
And thanks for the link to the sizing chart.
Yes, the lines that carry continuous flow, even when the loader is not being used. Remember, this is an open center system.
What size are the lines on the tractor side? No point in making the new lines bigger than the existing ones on the tractor.
barts
4wd B5100 w/ FEL, box blade, JD110 TLB, WC68 chipper, log arch, brush mower.
Feb 10, 2015
125
115
Lopez Island, WA
Many thanks Barts. Did you also build your own loader ?
I converted a B219 Kubota loader that was in pieces to fit my B5100. Basically I had to make a new subframe, and devise a drive for the hydraulic pump. The arms, bucket and towers are from the original loader.
Paul Allwood
Kubota B7200HSTD, RC60-72H MMM, homemade FEL, forks & ballast box, rotary hoe
Jul 8, 2025
583
996
Thanks.
I've only measured the OD of the main lines on the tractor as follows:
- Main steel line from selector block to the back (to 3 pl controls ?) 12.0 mm - possibly 3/8" ID - yellow arrow in pics
- Main steel line from bottom of tank to pump (main suction line ?) 19.2 mm - ID ? - red arrow in pics
I guess based on this it would make sense to use 3/8" hydraulic lines from the right side of the hydraulic block to the loader valve inlet, and back from the loader valve power beyond to left side of the hydraulic block. Does this make sense ?
Paul Allwood
Jul 8, 2025
583
996
Help understanding hydraulic block connections....
I think I've got the hydraulic selector block connections sorted (from Kubota manuals) for connection to the loader tomorrow, but I don't understand a couple of the lines on the hydraulic block.
In the attached pic, my understanding is:
1 - supply to loader valve
2 - return line from loader valve power beyond port
3 - supply to 3 point controls
4 - connection at the base of the hydraulic pump. Is the the pump outlet ?
5 - no idea. Looks like a large flexible hose, suction ?
Many thanks again from a hydraulics (and tractor) beginner.
6,979
Thanks.
It isnt going to matter one way or the other so do whatever makes you feel better.
The ONLY thing gained from using a larger hose for loader delivery and return is less heat is generated and on that tractor with a max of 4 GPM flow and those run lengths the difference is probably immesurable.
As a reference point a factory LA525 on a L3901 HST is conveying twice as much flow using 3/8" hoses.
6,979
Number 5 is used for the pressure relief unloader and loops back to the suction side of pump.
On a factory loader the loader valve tank return goes to the transmission filler.
Paul Allwood
Jul 8, 2025
583
996
Thanks Dan.
Do you know if that pressure relief unloader is sufficient to protect the pump if the pump outlet is closed ?
I'll also have the tank return from the loader valve go back to the transmission filler. It was originally just a filler cap, so I've replaced it with a tee - filler cap on top, return in the branch.
6,979
Thanks Dan.
The pressure relief in the outlet block controls the maximum pump outlet pressure and protects the pump from catastrophic over pressure if the outlet is deadheaded.
Like most Kubota systems it can operate for extended periods but prolonged operation will overheat the oil and stress both pump and valve eventually leading to premature failure.
6,979
BTW - the supply and return ports in the outlet block are BSP thread.
3,741
2,312
Thanks.
That's what I would do. However, as @TheOldHokie points out, 4 gpm in 1/4" isn't very restrictive. (In my former career, I always tended to be generous in my line sizing.)
BTW, I see green, not red. Tell me I'm not color-blind :).
Paul Allwood
Jul 8, 2025
583
996
It appears to work - I'm happy with that so far. Many thanks to everyone who has commented and offered advice so far.
I haven't made a bucket or any other attachments yet so can't use it, but I might try and see how close it can get to the rated lift capacity for a B7200.
Edit: Just used the tractor for spraying weeds and discovered that the 3 point hydraulics aren't working. Turns out there is an additional fitting required for the valve to make the power beyond port work. The part is on the way. So close.
Reactions: 7 users
torch
Jun 10, 2016
2,877
1,117
Muskoka, Ont.
Looks pretty good, but that poor chair may not survive too many more tests... <lol>
When you are making your bucket, you will want it mounted so as it lifts the front end up about that same amount when flat on a flat surface. That will give you some digging depth while maximizing dump height.
Your max arm height looks pretty good and is still well forward of the front of the tractor. Your range of curl looks good, make sure you plan the bucket mounting angle to still allow some curl back. You want the bottom to be around 15°-20° from horizontal at the lowest position. Too much and you won't have enough dump angle to unload sticky material like mud.
Bear in mind that while operating you will need to curl the bucket down a bit as you raise it above the hood level to prevent material from spilling out the back and landing on your hood. Don't Ask Me How I Know This (tm)!
Paul Allwood
Jul 8, 2025
583
996
Your max arm height looks pretty good and is still well forward of the front of the tractor. Bear in mind that while operating you will need to curl the bucket down a bit as you raise it above the hood level to prevent material from spilling out the back and landing on your hood. Don't Ask Me How I Know This (tm)!
Thanks. Yeah, dodgy operator.
Planning on the level bottom of the bucket being able to be about 4" below ground level.
Haha - I'll be turning the valve into a joystick control for the raise/lower and curl/dump to try to help avoid tipping the load on myself.
torch
Jun 10, 2016
2,877
1,117
Muskoka, Ont.
That works in theory...
With the low flow rate from the pump I find I can only get two functions to work at part flow on each -- especially when trying to fight gravity with one while going with gravity with the other. It's less critical with a bucket than forks due to the difference in leverage. Also, the things lifted with forks tend to slide around more than the things lifted in buckets.
Paul Allwood
Jul 8, 2025
583
996
Some of the things I make because I think I'll need them. Other times it's because I wonder if I can. I've zoomed in on a couple of videos of joystick valve mechanisms - wondering if I can turn my two levers into one.
I have a three spool valve (grapple, 4 in 1 bucket....) so the 3rd will still be a separate stick.
torch
Jun 10, 2016
2,877
1,117
Muskoka, Ont.
I don't see why not -- it may end up a bit ungainly depending on how you can attach a joystick mechanism to the spool valves, but underlying the purpose-built joystick controls are two parallel spool valves. The only question is are they set up as a bank that allows flow through both simultaneously or did they start life as two separate single-spool controls set up as a PB series?
6,979
With the low flow rate from the pump I find I can only get two functions to work at part flow on each -- especially when trying to fight gravity with one while ats hy with gravity with the other. It's less critical with a bucket than forks due to the difference in leverage. Also, the things lifted with forks tend to slide around more than the things lifted in buckets.
You dont have that problem on a modern Kubota loader because the boom and bucket spools are in series.
Paul Allwood
Jul 8, 2025
583
996
Don't know about the simultaneous flow, I guess I can check by operating both the raise/lower and curl/dump levers together and see if both things move ?
I saw what looked like a pretty neat and tidy joystick setup in a Ask Tractor Mike video and thought I might try to copy it - see pic below. I bought 3 ball ends, just need to make the rest - hopefully not too ungainly 😆.
