While you're looking for a solution to the sleeves - Are they (shop) machine capable; does their tool maintain accuracy in three dimensions? Is the machinist capable?
Yes, your statements is the reason why I decided to slow this thing way down, I need to get this part of the process done properly
I'll show yall what I figured out:
Here's someone in the same situation, trying to put in new pistons
Just like the forum said, if you get pistons from kubota, they will not fit, the sleeve needs to be bored for the piston to fit
And the genuine kubota pistons are not coming from japan, they are Indonesian
Piston liners: I might be able to hammer out the liners, and hammer in new liners
Here's a clip of someone removing cylinder liner using flathead and hammer
Ok here's him installing new cylinder liner using: 4x4 wood block, and hammer
Here is another video of someone hammering down on the liner with flathead, removing it from the block
My thoughts before seeing these videos: the liner is fused to the block and cannot be removed with hammers etc
Not true, one can take out liners and put in new liners without going to machine shop
Question: how does the liner not go up and down when the piston is rubbing on it up and down? I get it cant go up since the head will stop it, but what is stopping it from going down?
Let me know if these statement are true:
"Liners are like bearings, they are made to be replaced and should be replaced when doing overhaul."
"The area of most resistance in the bottom area of engine, is the piston rings rubbing on the cylinder liner."
"This engine, since piston #2 and #3 had cracks in them, that is signs that something is off in the way the piston is going up and down that bore hole, leading to the need to put in new liners, and bore them out to factory spec"
What is the yalls theory as why pistons break?
I am slowing things down because I need to get this part of the build right
I do see people when installing new liners: Put the engine block in the sun for hours, put the liner in the freezer overnight, take the liner out of the freezer, lube it up, and hammer it down into the block using 4x4 wood
I am working on another job, but once i get back to it, I will try to remove the liners
