Snow blower question
bobnic
LX4020, BX2370, KX033, Ford 8N
Mar 7, 2025
133
136
Lakes Region, NH
By "propeller" he might be referring to one of the augers. But who knows, a picture would certainly help.
imarobot
5740HSTC-3, FDR2584 Finish Mower, BH92 Backhoe, L2195A Snowblower, LA854 FEL, +
Apr 18, 2025
422
315
NH
In addition to the shear bolt on the driveshaft I also have shear bolts on the shaft that goes from the gearbox to the chain sprocket and another one on the, what is called in the manual the "fan". This may be what he is referring to.
bobnic
Mar 7, 2025
133
136
Lakes Region, NH
Thanks for the picture. That is the fan. It looks like something welded to the tip of the blade, perhaps to balance it? It does not look like anything you could torque. There is likely a shear bolt thru the fan to shaft junction that would be torqued to a spec.
nbryan
Jan 3, 2019
1,432
950
Hadashville, Manitoba, Canada
No, it’s on the fin itself. Only on one though. Manual talks about torque it to a certain amount.
If the manal IDs it then follow the manual. I can't see any mention of it in the parts diagrams available online for that blower. Only for the impeller fan mounting bolt.
My guess is for balancing it? Maybe ask a dealer what it is? That's a weird way to balance something that's going to wear it smooth and maybe even have a rock or something break it off?
I'd add some welds if it needed a balancing.
Bearcatrp
Mar 28, 2023
1,387
1,009
Minnesota
Yeah, went back and read the manual again. Misunderstood what was said. Would have been nice to identify it in the manual to let users know what it’s for. Thanks everyone for helping me on this.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,278
2,979
Near Lancaster, PA, USA
My guess is also a weld to balance the impeller. It's at a good place (back of the blade) so nothing should affect it.
Bearcatrp
Mar 28, 2023
1,387
1,009
Minnesota
My next question. How often do you check the gear box oil? I know what the manual states but wondering if it needs checking more often. Just checked mine yesterday. Was a little low. The guy who I bought it off didn't do much maintenance since he let it sit outside for about 2 years. States he used it once, then put it aside as he didn't like it. He put a plow on his truck since.
torch
Jun 10, 2016
2,886
1,133
Muskoka, Ont.
I change it every spring before putting it away and check it again in the fall when setting it back up. More because I want to avoid any moisture issues than any leakage of lubricant -- that would be readily apparent. There's not too many places the gear lube can go and the box is right there easy to see.
Bee-Positive
Nov 16, 2022
1,138
1,060
Amsterdam, NY
Sitting outside for two years - I'd change it.
Won't take gallons so cheap insurance.
Then you KNOW it's right and one less thing to worry about.
Bearcatrp
Mar 28, 2023
1,387
1,009
Minnesota
Next question. The coupler that goes on the PTO shaft. Are gorilla hands required? Have tried many times without luck. So I pull back that coupler then lift the blower slowly to get it to seat in. Coming off is ok though.
nbryan
Jan 3, 2019
1,432
950
I most definitely NEVER have the tractor running while attaching PTO shafts to my tractor.
NEVER.
That's out of the way, now I'm assuming you're running the tractor to use the 3-point to raise the blower while attaching to the tractor PTO?
DON'T DO THAT.
With the tractor turned off, the PTO driveline coupler to tractor PTO shaft needs to be fully engaged and lockpin snapped into place, then tugged at to make sure it's locked.
Then start the tractor and while idling slowly engage the pto shaft to test the blower operation. From the tractor seat.
nbryan
Jan 3, 2019
1,432
950
And yes gorilla hands help. I f***ing hate driveline attachment, but it's slowly getting easier. THe main thing is getting into a comfortable, well lit position under the driveline so it can be manipulated with the least effort.
torch
Jun 10, 2016
2,886
1,133
Muskoka, Ont.
Do you have the style with a collar that pulls back to retract some balls? You may need to clean or lube things. I prefer the style with the simple spring loaded pin on one side.
Bearcatrp
Mar 28, 2023
1,387
1,009
Minnesota
I have the shaft installed on the PTO shaft and pushed as far as I can get it. I pull that lock piece back all the way but the dam thing won’t lock in. Tractor is off. I have lubed the shit on the PTO shaft and the snap ring. Still can’t get it on all the way by hand. Am I missing something? I pull that ring all the way back. What I did was start the tractor, leave it on idle, pull back on that ring, then lift the blower slowly. It pushes it in and locks in. Not the safest way to do this.
Bearcatrp
Mar 28, 2023
1,387
1,009
Minnesota
I do have that. It was dry when I got it. Used 90 weight oil and soaked it good while moving it to get a good lube on it.
WI_Hedgehog
Apr 24, 2024
1,130
1,646
Milwaukee, Wisconsin, U.S.A.
Absolutely not. Clean everything thoroughly with diesel or even gas if needed (wear rubber gloves and eyewear--this gets messy) and wire brush any old grease out; it gets hard and packed with dirt. Do the whole shaft, all U-joints, splines, everything.
On the "pull collar" spray in WD40 if you have to so the old gunk is completely out. The whole shaft should be very "floppy" and the collar pull back easily, though it more bind a little without lubrication.
Once everything is super clean inspect for wear (which you should have none). Grease it all up with Molly grease (since there are no bearings, only bushings), and wipe the excess with paper towel so you're not flinging grease.
The shaft should now go on like butter. Run it a few seconds and re-grease with 1 pump (and wipe).
Personally, I'd grease it (1 pump, generally) before storage so nothing rusts, and when pulling it from storage so it has fresh, soft grease in the bushings. After dissembling a few of these I appreciate the simplicity and found more frequent greasing (1 pump, wipe) eliminates wear, maintenance, and frustration.
A little extra grease around the joints creates a protective barrier so don't go crazy keeping it clean, just to not sling grease and make other messes. Good lithium grease is hard to get off of clothing, gloves, hands, and attracts dirt, so implements really suck to handle and work on after years of greasing without wiping the extra while soft. BUT, that's just me, you do you.
Bearcatrp
Mar 28, 2023
1,387
1,009
Minnesota
Next question. Do you folks fill the bucket as a counter weight? This blower is a heavy pig.
