Snow blower question
torch
Jun 10, 2016
2,880
1,126
Muskoka, Ont.
Next question. Do you folks fill the bucket as a counter weight? This blower is a heavy pig.
No.
The tractor is only carrying the blower during tranport anyway. When in use the blower is self-supporting.
nbryan
Jan 3, 2019
1,425
944
Hadashville, Manitoba, Canada
No.
The tractor is only carrying the blower during transport anyway. When in use the blower is self-supporting.
What about when you need to raise the blower to assist maneuvering? That's precisely when the front tires need added traction if possible, especially in snowy conditions. Shut down completely the blower first? Nah.
You never raise the blower during operation? I do. All the time, but mines a front mount. The principal remains the same. If you're within the safe operating range of the PTO shaft to tractor and implement angle there's no problem raising and lowering while engaged and working.
And it's mostly being raised to maneuver a bit before lowering to the ground to keep working the snow. Hell, I even hit super-high snow banks with it raised fully under full power to top them before carrying on on the ground.
And I'll give another example of needing front weight to help maneuver while the rear PTO is working:
My 60" rotary mower is regularly getting raised while spinning. And a post hole auger. Same.
My first thought after reading OP's post was there's "suitcase" weights that hang on the tractor's front frame that would stay out of the way, leaving the loader available for snow work instead of carrying gravel or whatever for ballast. Good luck if the gravel piles are frozen.
torch
Jun 10, 2016
2,880
1,126
Muskoka, Ont.
I have both a front mount and a 3ph mount. The "handling" is decidedly different!
Turning the front mount in deep(ish) snow is less effective due to the exaggerated rudder effect. The steering wheels are trapped between the "rudder" (ie: blower sidewalls) and the rear wheels. Lifting the front mount puts considerably more weight on the steering axle while reducing the rudder effect somewhat. Still hard to make tight turns but at least it turns somewhat once the blower is lifted a bit.
Compared to the 3ph mount: The steering axle has a lot more leverage against the rudder effect, since the blower is now on the other side of the rear wheels. Lifting the blower does reduce the rudder effect as weight is transferred to the rear axle, but lightens the front axle so there's less benefit than one might otherwise expect.
But: that's my tractor (B7100) and blowers. Different machines and combinations may vary.
WI_Hedgehog
Apr 24, 2024
1,129
1,646
Milwaukee, Wisconsin, U.S.A.
You could put a plow on the front? It leave the FEL on? Suitcase weights? Having a front plow I put weight out back, so for a rear blower front weight makes sense.
I plan on putting a rear blade on to blow and scrape at the same time, but I'm on concrete, and blades are spendy too. Anyone have a heavy-duty 60" used?
Bearcatrp
Oversized Garden Tractor (aka BX1880) with loader, mower and 3 point
Mar 28, 2023
1,380
997
Minnesota
Got my optional shoes for the blower today. Heavy beefy suckers. $280 bucks. Hoping it helps with keeping it from digging into my class II driveway.
Bearcatrp
Mar 28, 2023
1,380
997
Minnesota
I got lucky getting a rear 6 foot 3 point blade for $200 bucks. I see on craigslist folks are asking $500 and up for rear blades. Just keep looking on craigslist and facebook market place for a good deal.
bobnic
LX4020, BX2370, KX033, Ford 8N
Mar 7, 2025
131
130
Lakes Region, NH
A 6 ft blade is asking a lot out of a BX1880.
Bearcatrp
Mar 28, 2023
1,380
997
Minnesota
Handles it fine. Have it reversed so am not digging into my class II driveway, adjusted with top link to where its almost straight up but just enough curve to not dig in. 45 degree angle. Plows snow great. Have my larger R4's on for winter duties. But now having a 3 point snow blower, the rear blade will only be used on light snow fall.
JonM
L6060,SA20,4in1,BH92,QH16,BS40,APS1572,RTR2570,HR2572,WC1504,FM2584,SBP1684
Nov 29, 2024
280
675
wisconsin
Next question. The coupler that goes on the PTO shaft. Are gorilla hands required? Have tried many times without luck. So I pull back that coupler then lift the blower slowly to get it to seat in. Coming off is ok though.
it does take some effort. things you can do to make it easier is frequent pto shaft maintence. take it off the implement take the covers off clean it i side the shaft and the oitaide as well grease it up. i pit grease o all of it then wipe it off. you dont want a bunch of build up. reassemble with covers on. they are a pain but they are necessary.
keeping both couplers on each end and the pto shafts on tractor and implement clean and lubricated makes everything easier.
to connect i pull the retainer ring back and slide it enough so the detent is held by the pto shaft. then you can just muscle it on rest of they way till it clicks in place
mcbobhall
BX2680, BX4070A cab, BX2822A blower, WC1503 chipper
Sep 18, 2021
outside Bozeman, Mont.
If you can't twist around to work backwards with a standard 3pt blower, I would recommend against it. There are 3pt blowers that face forward, so they follow the tractor path forward. They are less common, and usually cost a lot more. But, you don't have to look back all the time except to set up the start of a run. The best option is a front mounted blower, but then that gets complicated if there is no standard design for your model. That said, I believe most of the BX series does have a front mounted blower system. I use one on my BX25 and would never go back to a rear running 3pt version. I had one before with a different tractor, and it kept hurting my neck.... The front blower is one of the reasons I bought the BX25 in the first place.
I've run a BX2680 with a BX2822A 55" commercial blower up-front for four winters now in SW Montana. We have a 1/4-mi. gravel driveway plus another 1/4-mi. of gravel roads on our property. All winter I clear almost 2 miles of ATV and e-bike trails across frozen pastures and farm fields. There's a Land Pride RB0560 blade hanging on the 3-point for touch-up, esp. on our paved turnaround. Nothing beats facing forward as you work and we get drifts that would stop a much bigger tractor without a front blower.
Blue2Orange
BX2380 with LA344S & QH05. SB1051. SG0554. BB1248. RB0560, Vassar dirt bucket
Apr 3, 2025
431
301
Bayview Township
This would have been the 25th winter with OldBlue. Normal northern winter snowfalls and Lake Effect dumps use to add up to usually over 15 feet a season, but with the warming and shorter winters over the past few years we rarely break the 10 foot mark. Ice covered driveway from rain, frizzle is now an issue every month of winter.
Shorter gravel driveway at ~800 feet. So far, no issues with swiveling the body around. I've only had a 3pt mounted blower. But the NH had a cruise control that worked in reverse. Will find out if I will need to twist more than just swivel the butt. Plus the high back seat could be an issue. With the lighter recent snowfall. Found the back blade and loader for light snowfall was more efficient than using the blower until the snow banks became too big. Would like to eventually get a snow blade for the front and see if offsetting the back blade to wing the banks would work. Snowblower for the heavier dumps or when the banks get too big.
Bearcatrp
Mar 28, 2023
1,380
997
Minnesota
I tried a front blade on the loader. Hopped to much. My rear blade and front bucket has done good past few years for me. The rear blower I just picked up will be for those heavy snow falls that seem to come once every 3 years. Just read another weather update that’s calling for colder and more snow so maybe get to test out my blower this year.
nbryan
Jan 3, 2019
1,425
944
Between the loader bucket and box blade the lighter snow events are no big deal for me, for the driveway and parking anyway, between snowblower events. I take the blower around about 2 miles of trail I maintain for walking with my pyr and go only when it's worth all the messing with the hookup sequences, starting with finding a parking spot for the FEL assembly, to putting it back on after blower work done.
Bearcatrp
Mar 28, 2023
1,380
997
Minnesota
If I didn't have a FEL, probably would have went with a front blower. Have never taken off my FEL. Probably the best combo having a front mounted blower and a rear blade. But the FEL bucket comes in handy when using just the rear blade for snow removal and using the bucket to back scrape in areas the blade cannot get to. Plus I can move piles back further that build up.
bobnic
Mar 7, 2025
131
130
Lakes Region, NH
No way would I swap my loader and blower off and on over the winter. Once the blower is on it stays on til sometime in April. Consider getting a back blade and leave the blower on for the duration.
nbryan
Jan 3, 2019
1,425
944
I need the loader regularly in the winter especially for pallet forking my dry sheltered loaded firewood pallets over to the house to burn.
My implement swapping system has become as refined as it can and I'm aware well ahead of time of what's needed. I'd say 1/2 hour each swap either way.
Only needed the blower like 3 times last winter. I'm no longer hauling it around blowing the neighbor's driveways anymore. Retired is retired.
