Fixing hole in side of block
Status
Not open for further replies.
Hugo Habicht
G1900
Jun 24, 2024
1,073
1,556
Ireland
Unreal those old Kubota tractors that all this abuse cannot kill them. I am really impressed. Top quality machines.
joesmith123
L295DT, BX1500
Mar 18, 2023
296
140
earth
L295DT changes your realm, stop and fix your loader
Your realm change forever when diesel engine come to life
But there are tons of things to fix
Halfway through shaping a half mile road, your hydraulics lock because you put RTV and now its in the system, @North Idaho Wolfman was correct again
The cylinders that you wasted all that energy on, are still leaking, both bucket cylinder
Front frame of your loader, your 45 year old loader crack the frame and is flexing hard
Do you a major magic trick and make it all one entity
Your cheap small bolts could not stand the force of your machine shaping your realm, you busted almost all the bolts that hold your loader to your machine
There might be one bolt left barely hanging on, from your hours and hours of earth carving, diesel engine magically making you power
Another magic trick: you busted the rod that hold your FEL valve to your loader, you need to do another magic trick
Your not playing with the small bolt no more, you are serious about mounting your loader to your machine and churning your realm until it is plane,
got you tons of 5/8 and 3/4 bolt with washer, you fixing to mate your loader to your machine with INTENT
Put this machine next to any skid loader that you ran before, and you will always hop on L295DT
Stop your ramblin and articulate the task:
Open you up those two leaking cylinders, seal them again with more effort
Lift up your tractor, and get you massive bolts mounting the two entities
Then do you one massive magic trick and one smaller magic trick, capture it on video so they get their receipt
Take off your failed seal on your cylinder,
clean you out the area with solvent then compress air, files, wire wheel front facing
joesmith123
L295DT, BX1500
Mar 18, 2023
296
140
earth
seal your hydraulic cylinder, mount your loader to your tractor with big bolt
try to seal it again, if it dont work, get you the proper seal
You got underneath your tractor and noticed all the bolt are either busted off completely or loose
You couldn't lift your tractor up because you don't have electricity and your cheap jack can't lift up that big heavy robot now
you cant even stand you are covered in mud
dragfan66
B7500 Z231KW G1800 L3350DT
Apr 12, 2020
65
74
Alabama
Time for a smoked fatty and reassess the situation.
At least order some seal kits for the cylinders while you are waiting out the rain.
jaxs
B1750HST
Jun 22, 2023
1,001
773
I lost count how many times what has been washed,blowed,glued and tattooed. Plus speaking in first person,secound and third person makes it difficult for me to keep up with who's washing and who's hanging out.
Sidekick
Jul 29, 2023
1,123
1,598
N.Y,
Don't worry, you will probably get to see it all again in the future. :unsure:
amschind
Kubota M6800/Westendorf TA26, IH 82, NH 648
Sep 30, 2024
46
23
At this stage, my chief question is how we got here vs. "patch the hole in the block with JB weld and RTV and call it good"? I'm not even certain that such a "solution" would've been worse than where we're at now.
joesmith123
L295DT, BX1500
Mar 18, 2023
296
140
earth
Lift heavy robot, mate loader to tractor big bolt
finally nature power your solar to power your air compressor to lift your heavy robot
your big hydraulic lift can barely lift your robot up, it feel like loader on your tractor make it twice as heavy, all that thick steel
Get you under there in the dirt, put you big bolts everywhere, also put a glue on your bolts so they CANNOT come off or loosen up
work you this task with ease and calmness, moving slow, without mistake
clean you out your bolt and bolt hole with solvent, hit with air, cover your bolt with gasket maker, fasten it tight tight
You are deep under your tractor, your jaw is less than an inch away from a sharp thick bracket that will injure you for a week or more with one wrong move,
you have leverage bars trying to get your bolt holes to match, you are fully covered in dirt trying to get leverage
do this task right so you do not have to do it again, comprehend you how important it is, and give it as much time as each task require
get your largest drill bit, bore out some hole that would fit your 5/8 bolt
your finger took a big hit when your drill bit abruptly stop
use contraption laying around to line up bolt hole, nothing more humbling than spending 3 hours getting bolts lined up
llight on your feet, focus on one bolt at a time, take it out, brush it with solvent, glob gasket maker, fasten back in tight
front bracket bolts: some are loose still one is missing,
go through them as well with cleaning and gasket maker, try to find another bolt
The other side: imagining that each bolt hold your robot to your tractor with big might
There are two massive bolt on each side of rail holding your loader to your tractor
you could not get to them, you need to: Move your tractor forward, engage hydraulics, use you your 3 point and your loader to get your tractor off the ground, put you block structure,
then you can fit under there and reach those massive bolts
@Lil Foot
ok yes i liisten, yall are saying:
"gasket maker will not hold a bolt tight"
ok get you some goodies: needed cut off disc, got permament thread locker if your current bolts dont hold, got more gasket maker, got a big pipe wrench in case you need to rebuild the cylinder, and some other glues to experiment with keeping bolts tight, and a new brush for your solvent
@Henro
yes thank you for saying that, i forget how lucky i am to be working on my robot almost near christmas outdoor on the floor
ok fasten you the rest of your bolts, slap you some glue on them, try to find a bolt to fit inside that missing bolt hole, move tractor forward, use hydraulics so robot can lift itself up, fasten and glue those last 2 big bolts hold the rear axle to loader
3,309
Just thinking after reading your post Joe.
Seems to still be warm there. Warm dirt is more comfortable to lay on than cold concrete or frozen earth.
Joe, I think you are in heaven!
3,309
At this stage, my chief question is how we got here...
It is clearly the natural evolution in the realm where Joe exists. Nothing unexpected about it at all...
I don't think I personally have ever been there, but I CAN relate...
Status
