ctfjr
L3800HST
Dec 7, 2009
1,982
2,539
central ct
I feel guilty. Here in Stuart FL for a couple of months. Set record high temp a couple days ago, 86. Back in CT we heard they had a boatload of freezing rain. Called my son & gave him a few tips about using the tractor on ice. He is doing driveway clearing duty and has little experience. I'm sure he will do fine.
Oh, and we had a tornado touch down here in Stuart. Not sure how close it was but sky definitely looked ugly.
10,599
Snow and more snow. I was out this morning blowing and pushing and will most likely go back out this afternoon if it keeps coming down the way it is. It's the kind of snow I like i.e. powder which is easy to move.
Reactions: 8 users
GreX
BX2380
Jan 8, 2023
185
132
Maine
Cleaned up after yesterday's snow.
This makes me want a cab even more, last night when I was snowblowing, I couldn't see anything as the spray from the blower was getting picked up by the wind and I ended up munching two of my driveway markers (luckily I didn't cause any harm to the blower)...
fruitcakesa
M 6040
Oct 26, 2010
856
270
Cavendish Vermont
After breaking the foot off the plow shoe shaft when hitting hard “lumps “ below the snow; a testament to my welding ability, I stopped in to Tractor Supply and bought a new one. Also readjusted the loader control after I noticed that I had very little movement of the joystick when pulling it back. The locknut that holds the valve plunger had backed off and the plunger had also backed up enough to move the joystick backwards. I rethreaded the plunger back until the joystick was back in place and the valve had full movement again. Then went to my moms house and cleaned the dry powder snow off the driveway with a fully operational plow and loader once again.
pokey1416
Jun 24, 2020
570
875
SW Michigan
Didn’t use the Kubota but we fought an 8” water main break all day today. Couldn’t isolate the line to shut it down for repair. Ended up widening shutoff area and of course when we did, starved 1 of our towers. YIKES! Bringing in the wheeled Volvo and hydro excavation truck to get it fixed. 4th one this week!
Reactions: 7 users
WFM
L3800
Apr 5, 2013
1,573
1,051
Porter Maine
I was out pushing snow around today , wind blowing, temp was 17*
I added a cab and heater last fall and I'm loving it !!!!
acruxksa
LX2610, lx2963, bb2572
Jan 15, 2024
46
114
Anchorage, Alaska
20 gallons of -30f window washer fluid in each tire. $3.97/gal at our local Walmart. Please don't judge the tire chains, I know I have to remove some links, had to get the driveway plowed first and will circle back to the chains later this week.
Reactions: 10 users
Chanceywd
Mar 26, 2021
773
734
central ny
It was a balmy -4 here this morning…so the block heater got plugged in…after about 1.5 hrs, had one bar on the dash when she fired right up. Did not see more than two bars in the 3 hrs I was out…and when just idling only one bar on the dash/thermostat.
Moved some wood onto the porch and relocated some of the wood slabs I had milled last year.
I like seeing the inspector/ supervisor on the porch helping!
Bill
GrumpyFarmer
4,803
Bill
Haha…yeah she is really helps…the little one is worse…if they gave out medals for detaching wood and scattering it around the yard and driveway, he would be a multi gold medal champ! I think one of his special skills is taking dry wood off the porch to leave in the rain. 😂
Old_Paint
Dec 5, 2020
1,969
2,172
AL
20 gallons of -30f window washer fluid in each tire. $3.97/gal at our local Walmart. Please don't judge the tire chains, I know I have to remove some links, had to get the driveway plowed first and will circle back to the chains later this week. View attachment 120477 View attachment 120478 View attachment 120479 View attachment 120480
I'm just trying to figure out why your R14's look so much smaller than mine. I've got the LX2610SU with oversize tires, but didn't realize they were that much larger. The back of my little SU looks like Kim Kardashian's behind with the big feet. Dealer included the ballast in the purchase when I bought mine. I don't regret getting the big tires or the ballast. I think you'll notice a lot more traction as well as stability by loading the tires. What model is your box blade? That looks like the BB1260. Silly me wasn't paying attention when I got mine, and I wound up with the BB1248 as one of two included implements when I bought my LX. It's about a foot too narrow, especially with the big feet. So, keeping my eyes open for a bigger BB. They're all but useless if they're not wider than the tractor track.
Might wanna plan some tire fluid samples into your regular maintenance program to make sure that stuff isn't corroding the rims from the inside. Just roll 'em enough to stir up anything that might be rusting/corroding, then pull a quick sample (pretty much the same plumbing you used to put it IN the tire, but do it with the stem down). It shouldn't corrode according to the product claims, but "shouldn't" with my luck normally means it certainly will. After all, the reservoir on the car is plastic, and the pump is plastic, etc, etc. There's your sign.
Kinda surprised me to see the open platform after I looked at your profile. Alaska + Open Platform + Winter = Glutton for Punishment! You have a much heartier soul than I.
acruxksa
Jan 15, 2024
46
114
Anchorage, Alaska
:D
I have plenty of warm clothes. Also, cabs are special orders around here and would have delayed delivery by 3-4month. May eventually get one anyway, but I e been clearing snow with a 1st gen 2025r and a loader bucket for about 5yrs and really don't mind the open platform. Just got to keep the chute pointed down wind. ;)
Will be cutting some links on my tire chains this afternoon to get them to fit properly. No snow this week, so my driveway is finally fully plowed. Hoping to haul about 20yds of snow to our property later this week to keep the piles manageable in the driveway.
Siesta Sundance
Oct 23, 2022
1,833
2,544
youtube.com
@acruxksa
Again, welcome. The forecast has us getting over 2in of rain next week, more the merrier anything to get us out of the drought.
Also, you can always add a cab later. I understand the AK shopping, what you want, and what you can get, and even if it's close, you still walk happy because you still got something that is mighty useful.
7,388
That's quite the setup for installing liquid into tires. I used a 15 gal sprayer with pump for chemicals. turn the bottles upside down and they set right in the opening. Remove valve core and put hose over valve stem.
5,657
Didn’t do a lot on the Kubota today. Did the annual mowing of the back of the dam this afternoon, but that was with the Stihl FS-70 sporting a blade. Did the front side about a week ago. Noticed the whole surface of the pond was frozen. We’ve had ice patches intermittently every year but it has been several years since the whole surface froze. No clue why it’s all lumpy and rough. It’s usually smooth when it freezes.
Anyway… Did get the L out to deal with the remains of this Virginia pine that fell between the houses and shed. Limbs were already long gone. Tractor is about the middle of this long spindly thing. Whacked it into 3 pieces and dumped it on the scrap log pile as it’s way too rotten to do anything else with it.
Then hooked up the rotary cutter to do a little more annual mowing type stuff tomorrow. Ground is very wet from recent rains but was frozen hard until about 1:30. Top was getting pretty muddy in the sunny areas so mowing can wait until morning when the ground is frozen again.
Reactions: 7 users
mdhughes
L3901DT
Dec 10, 2014
1,431
1,424
Ste Geneveive county, MO
I feel lucky, when I bought my L3901DT the dealer loaded the tires with washer fluid for me as part of the price. I had asked him how much to do it and he told me they do it on all the compact tractors they sell.
acruxksa
Jan 15, 2024
46
114
Anchorage, Alaska
I could have done without the valve in the feed side, but there's only about $25 in PVC parts there. Can't remember what the valve adapter cost, but it wasn't that spendy. Took less than 30min per tire once I figured all the plumbing out.
I did also purchase a Milwaukee transfer pump but I never count tools into the cost because I'll find many more uses for it down the road.
Finished fitting the tire chains this afternoon. No need for rubber snubbers anymore. :)
10,599
Woke up to 8" or more of fresh snow on the ground this morning and spent 45 minutes redistributing it. I really enjoy this sort of work. I had to make way more passes on the lower driveway than normal as I attempted to push the snow over the edge to make room for future plowing events.
Reactions: 8 users
