8,926
A friend who bought my 2016 BX25D from me in 2021 sent me this photo of the little beast this evening and told me that it's been working hard removing snow this past week. He sold me that little tractor, and I joke with him that he knew I'd want to upgrade at some point and that he'd end up with it. It's great to see it go to such a good home, and it's living a much better life with him.
Reactions: 6 users
8,954
I'm just trying to figure out why your R14's look so much smaller than mine. I've got the LX2610SU with oversize tires, but didn't realize they were that much larger.
They offer 2 different tire setups, one 14-17.5 and 15-19.5.
In Utopia
L175 FEL
Apr 21, 2013
639
154
Utopia,Tx/Pasadena,TX
Didn’t do a lot on the Kubota today. Did the annual mowing of the back of the dam this afternoon, but that was with the Stihl FS-70 sporting a blade. Did the front side about a week ago. Noticed the whole surface of the pond was frozen. We’ve had ice patches intermittently every year but it has been several years since the whole surface froze. No clue why it’s all lumpy and rough. It’s usually smooth when it freezes. View attachment 120511
Anyway… Did get the L out to deal with the remains of this Virginia pine that fell between the houses and shed. Limbs were already long gone. Tractor is about the middle of this long spindly thing. Whacked it into 3 pieces and dumped it on the scrap log pile as it’s way too rotten to do anything else with it.
Then hooked up the rotary cutter to do a little more annual mowing type stuff tomorrow. Ground is very wet from recent rains but was frozen hard until about 1:30. Top was getting pretty muddy in the sunny areas so mowing can wait until morning when the ground is frozen again. View attachment 120512
Often wondered about using a blade on a weed eater. Seems like there would be a lot of kickback.
Siesta Sundance
Oct 23, 2022
1,817
2,529
youtube.com
There can be, but I found using the blade is the fastest way to clear underbrush beneath my oak trees. With a new blade I can easily cut 3". I now have a walk behind trimmer, with a blade, I'll have to post pics later, didn't see them in this thread. If your not using a harness, I highly recommend the Darwin grip. https://www.orangetractortalks.com/...-farting-around-on-the-farm.62351/post-622293
5,177
My 4 stroke Honda ("weed eater") brush cutter is fantastic.
Wearing the harness helps to mitigate any "kickback".
Siesta Sundance
Oct 23, 2022
1,817
2,529
youtube.com
Wow a 4 stroke, pretty good size cutter!
I would prefer to use the harness, but I don't. If I encounter ground wasps, I need to get away asap and I don't want the cutter attached to me. I have had two encounters already, so I'll probably never use a harness again. My wheel version helps not having to wear a harness and less fatigue too.
Old_Paint
Dec 5, 2020
1,883
1,999
AL
:D
I have plenty of warm clothes. Also, cabs are special orders around here and would have delayed delivery by 3-4month. May eventually get one anyway, but I e been clearing snow with a 1st gen 2025r and a loader bucket for about 5yrs and really don't mind the open platform. Just got to keep the chute pointed down wind. ;)
Will be cutting some links on my tire chains this afternoon to get them to fit properly. No snow this week, so my driveway is finally fully plowed. Hoping to haul about 20yds of snow to our property later this week to keep the piles manageable in the driveway.
Optional? One would think that it would be the most commonly purchased (and available) option in Alaska. But what do I know?
Old_Paint
Dec 5, 2020
1,883
1,999
AL
Yep, with the latter size being primarily used on the SU models to enhance the AOD when outfitted with the BH-77, which was my original plan for my LX. I can't stick my hand between the fender lip and the top of the tire. They're BIG.
Apparently the big feet interfere with a MMM, but that extra 3 inches or so of height keeps the BH-77 (especially the cabless version) well up off the ground when loading on and off a trailer, meaning shorter ramps can be used. If the tractor has a cab, that makes the ground clearance even more critical because the BH-77 cab version (extended platform including an external seat) robs the departure angle advantage pretty badly. IIRC, the BH-77 for cabbed tractors is nearly 18" longer at the mounts. No difference in the sub-frame that I can recall, just the hoe itself. Cabless version depends on a swivel seat on the tractor.
Old_Paint
Dec 5, 2020
1,883
1,999
AL
Depends on the weed eater and the blade mass. If the power head has enough weight to horsepower ratio, it isn't too bad, IF the blade is used correctly. It's more a sidekick/twist, but it will usually stall the speed pretty quickly with most blades. It takes a little longer to accelerate the mass of the blade than a string trimmer (for obvious reasons), meaning it also takes a bit more to stop it. It WILL toss a lot more larger grit/gravel debris back at the operator because they typically don't have a guard like the string trimmers do, but they're intended to use for cutting brush above the soil line. They don't have much draft, meaning they don't pick up loose material so much, but they have a very high tip speed which means they'll typically shatter small rocks and turn them into shrapnel. Blades are pretty rough on the bearings and gears in the cutter head. Lots of severe impact. They also dull very quickly. Pretty amazing how tough those little buggers are, though. I typically start seeing grease leaks in the gear boxes after using a blade for a while. Blades are what I started clearing my property with. Just watch out for seasoned pine knots and rocks. The shards/chips hurt when they hit, even through thick jeans. I've picked more than one sharp splinter out. I've also seen some folks use table-saw blades on them. I can't think of anything that would be much more dangerous. Blades normally require some sort of adapter as well as some work to remove the string head. I bought a second head for mine at one time just so I could leave the blade on. I don' t use the blade anymore because I found something better, and a lot less dangerous.
As an experiment last year, I decided to try out my hedge trimmer attachment in the thick grass and brush on the ditch banks that run across my property. I was more than impressed at the performance. That thing made cleaning ditch banks a breeze, and it's a LOT faster than a string trimmer at laying down heavy grass on flat ground. Unlike a string trimmer, it doesn't wrap around small brush and beat the line off, it just cuts down the small brush. Since it uses overlapping shear blades, it'll clip anything up to about 1/2" diameter like hot butter; green, dry, doesn't matter. Lower engine speed makes a tank of fuel last a longer too. Being able to vary the angle of the hedger head also eliminates some of the wrestling with the power head weight, i.e. makes it a little more ergonomically friendly. Most blade attachments are no more than about 8 inches diameter. A hedger bar is 20+ inches, and doesn't throw stuff at ya. Hard to beat it for laying down brush in places you can't get with a mower. I haven't used a blade since. I stand on top of the ditch banks and just reach over the side because the hedger gives me a lot more reach. I also have a couple 3' extensions which are meant for the pole saw, but they work well for the hedge trimmer, too. Just like a blade though, ya gotta keep it outta the dirt/rocks if you want to keep it sharp. I use a round file to doctor mine up if I find a piece of steel wire or something harder than the teeth. The hedger head is pretty heavy, but a slight adjustment of the handle on the shaft remedies the balance issue pretty quick.
Look into some of the Trimmer Plus attachments from Troy-Bilt if you have a power head that will accept different attachments. I'm thinking there is a separate blade attachment in the Troy-Bilt line of attachments that I know will fit on a Stihl power head. My son has one of the 4-cycle Stihl heads, and all my attachments work just fine on it.
5,090
I use a three point blade for the dam. It’s good with blackberries, heavy stemmed weeds, and the annual saplings that are up to maybe 3/4” but mostly 1/2” or less. Between the mass of the weedeater and the inertia of the spinning blade it doesn’t kick bad at all.
5,090
Dropped the loader, folded the ROPS to fit under the trees, and did a little mowing.
Siesta Sundance
Oct 23, 2022
1,817
2,529
youtube.com
You should write a book. You definitely know how to do Friday right. Add a little fishing, & you could call it heaven. (Weather permitting)
Ha! Too windy lately for fishin.
And after a long day and a bit of tractoring, gotta reward yourself for safely operating.
Reactions: 10 users
edritchey
Ferris IS800Z - New Holland WM75 - John Deere X500
Jul 19, 2014
1,122
828
Wellsville, PA
Not enough snow for the 3pt snowblower so I'm using 3pt blade on the back with the LP angle plow on the front for the few inches of snow we got.
GrumpyFarmer
4,123
Just enough on the drive from yesterday to make a mess this week when the rain comes…so I switched to GREEN this morning to scrape it off…then I switched right back ORANGE to go dump it down the hill 🤪.
