ajschnitzelbank
Update on my $160 carport tractor cover:We shall see regarding the snow, that is of course my biggest concern. I’ll knock it off when I can (I’m usually here as work from home).
That hoop house sounds great, but I was able to set this up in a couple hours with a three year old’s help, didn’t require running electric, and cost $160 (plus some fasteners and a couple pieces of wood I had sitting around). If I had hoop house money I’d just build a carport!
We had serious winds the past few days. Though it didn’t blow away, the fatal flaw of my installation design resulted in the wood pieces sliding and the frame getting tweaked. Luckily I complained about the kinda shoddy cover it came with (fabric had thin spots and it came with mildew on it) so they sent me a replacement. They couldn’t source just a cover apparently so I go the entire assembly. Good thing, because now I had spare parts to replace the bent ones!
The fix is I spiked it down at the corners with some rebar. Hopefully that does it! While I was at it I added more braces from the replacement.
