billrigsby
Mar 17, 2015
1,050
247
Florissant CO USA 8213'
www.facebook.com
That's correct, I looked into all the similar models to see if any one model had a battery tray available
and I noticed the L 185 had a different set-up, and correct again on the little metal nubs sticking out.
Sent from my SM-G930T using Tapatalk
9,117
Worked on s sun burn today :D
Leveled out a really steep portion of the yard where an old fence line used to be.
Got the grade down to where I can go any direction over it comfortably with the tractor.
Howling
BX2370
Feb 5, 2016
217
10
Ayer, MA
Continued to work on the yard.
Extending an level area from the house. Then using that dirt to fill in wash outs going up the hill.
Ran in to a couple rocks. They only stuck up 3-5" from finished grade.
Bucket hooks and chain are nice for pulling brush and dragging rocks
Mike9
Kubota B6200
Oct 9, 2015
391
31
Ghent, NY
Picked up a dirt scoop of off CL and installed a new Hydraulink that came Friday. Agra Supply is blowing them out for $130+sh for Cat-1.
Billdog350
Kubota L3710 HST,L2230A QT,forks,Takeuchi TB125, 60" Luck Now pto Snowblower
Jan 6, 2014
468
11
East Hampton, CT
Replaced the front headlight assembly that was broken when I got the machine, and re-sprayed the entire nose assembly. Looks much better!
Also removed a stump with my Takeuchi TB125 and backfilled the area with material with my L3710.
Box bladed the driveway back to its ~30mph status.
In the background of that picture I also moved ~1800lbs of brick on a pallet.
Lastly, moved a swingset out of my back yard and replaced it with a different one....long story...
bmblank
Mar 4, 2015
774
496
Cadillac, MI
Looks like you run a daycare out something.
Sent from my XT1254 using Tapatalk
Billdog350
Jan 6, 2014
468
11
East Hampton, CT
Lol, no I have 4 girls...1yr to 13yrs....the eldest has grown out of most of the stuff, but the 1 yr old is growing into it.
The old playscape came with the house, the new one is from my wife's house. Apparently (according to my wife) my daughter needs a toy for every age and phase....since they're all hand-me downs...its not like it costs us anything (and gives me a reason to use the tractor!)
I'm moving the old playscape in the background into the woods wherever the girls pick and turning it into a treehouse. Should be a fun project!
rookiefarmer
1972 L260
Nov 1, 2011
82
Colfax, IN
Got the L260 almost back together. The transmission and differential bearings are all replaced, the tractor halves are back together and the rear wheels are back on. A couple more hours and it should be running.
While I had the hood off, I replaced the hoses and fan belt. Also replaced the plastic fan. The last time I used the tractor before the bearings exploded, I was getting pelted in the face by little bits of plastic coming off the fan. Appears to be original to this 40+ Yr old tractor. Its coming along nicely.
My plan is to get it running, usable and mobile, and plow and disc my garden then bring it back into the shop to make it pretty. I am taking the hood and fenders to get sandblasted. I can't decide if I'm going with powdercoating or spraying Kubota enamel yet.
Mike9
Kubota B6200
Oct 9, 2015
391
31
Ghent, NY
Tore into our two gardens today. Removed fencing, pulled posts and getting them ready to till and rake. Moved a lot of stuff with the rear forks too - getting quite a pile of old lumber out back. It'll go in dribs and drabs this year.
bmblank
Mar 4, 2015
774
496
Cadillac, MI
My dad's and brother's tractors each have a hook that holds the top link when it's not in use. I want so lucky to have that on my tractor when I bought it.
Well, now I am.
Had some sort of rod in the scrap bin, little bending and voilà.
On top of that I've been working on wiring my tractor for the snowblower chute winch conversion. Getting there. Just waiting for connectors and relays, hopefully I can get things put together this weekend.
millsan1
BX25D, SGC05, 4' Box Blade, 6' rake, 6' blade, Titan BX42 Chipper
Used the Box blade to smooth a dirt road on the property.
Leveled off a hump on the upper side of the driveway.
Used box blade to bevel the dirt next to paved driveway.
Made a few extra parking spots by removing uphill dirt and moving it to downhill side of driveway, 2 birds with one stone.
KeithG
2000 Kubota B2710, Woods BH75 backhoe, LandPride York Rake, B2783 Snow Blower
Jan 1, 2016
129
Rindge, NH
Recently my red battery light came on and stayed on. I figured it was either a bad dyno or regulator so I decided to buy the alternator upgrade. I also wanted to upgrade the spot lights and add a canopy and second light bar. Well I finally finished these upgrades, but it did not take a single day, this was done over a couple of weekends.
Interesting note, when I finally got under the instrument panel I found why the battery light was on, there was a mouse hotel in there that I got rid of by pulling out all the debris with long needle nose pliers, but when I lifted the instrument panel I found that the dang mouse had chewed off the coating on 3 wires and completely chewed through a forth! The last wire must have had a single strand of copper that finally failed causing the red battery light.
As luck would have it, the only two wires that were mostly unscathed were the two wires needed for the alternator upgrade. I verified that the other four wires were not needed via my Kubota dealer so I cleaned them, covered them with liquid tape and left in place so as not to mess with the harness.
Well I know talk is cheap so here are some pictures.... :)
7,650
KeithG, nice work. Might go up to the top of the page where it says "UserCP" and list the tractor you're working on. Might help other viewer with questions.
KeithG
Jan 1, 2016
129
Rindge, NH
D2Cat: Thanks for the pointer, I have updated equipment info...
