PaulL
2,566
1,527
NZ
Full service on the B2601 over the past 2 days. 400 hours.
Emptied engine oil. Taking the cap off the top lets it flow out faster. Replaced filter. Put two drain bolts back in, refilled. Cursed stupid funnel with a filter in it that runs incredibly slowly. Cut down a milk bottle as a funnel instead.
Emptied axle oil. Poured on the floor because my catch tray didn't quite lean inside the wheel rim enough, and as the flow slowed it trickled out sideways. Went to refill, milk bottle funnel didn't fit in the hole. Worked out how to remove filter from filter funnel, used that. Filling from full 20L UDT container very hard, spilled starting it off. Then funnel tipped over sideways and poured on the floor. Tied to fuel hose with string, filled.
Then noticed spare crush washer in the drain container. From engine oil drain plug. Checked which one was missing drain washer, took off, installed washer, reinstalled drain plug without losing too much oil. Not on the floor this time, went in drain pan.
Drove tractor up onto some timber to make it high enough to drain HST fluid directly into spare/empty UDT container. Took out drain plug, drained into UDT container well. First filter wouldn't come off with filter remover - too much fluid had gone on it from gloves. Slip jaw pliers are under tractor front wheel. HST fluid empty, cannot drive. Tried various other tools that didn't work, found pry bar to lift front wheel enough to get slip jaw pliers out. Removed and replaced first filter.
Went to remove second filter. No clearance, someone put a pipe right underneath it. Tried slip jaw pliers on the end of it, slipped off and crushed little finger on my left hand. Said some rude words and lay on the ground. Better half who had chosen that time to visit to see how I was going decided not to visit at all and went away again. Crawled under tractor to get better angle, and inched off the filter a tenth turn at a time. Replaced filter.
Refilled fluid using filter funnel without filter in it, and tied to tractor tool box so it didn't fall over. No spillage, but 20L UDT container is heavy to hold and pour. Probably need a pump.
Removed air cleaner, full of dirt. Started air compressor and blew it out. Air compressor hasn't been used for too long, pressure valve didn't work, air all leaked out, but filter clean.
Removed fuel bowl, full of junk. Diesel on floor. Hard to remove old fuel filter - seems to be jammed in. Tried screwdriver for a while, almost but not quite. Used slip jaw pliers to grab and pull out. Cleaned bowl, put in new filter. Tipped spare diesel from bowl and filter into the UDT container with the used fluid.
Refitted it all.....and everything works.
All in all, a good days work.
Reactions: 6 users
Old_Paint
Dec 5, 2020
1,850
1,909
AL
Gave my L3130 a colonoscopy, as recommended by @North Idaho Wolfman due to my glide shift trans not responding well to the hydraulic fluid I had in it.
Also bought it a new friend for it. Just arrived before dark today, so no time to unbox. 48" from Titan attachments. I know there are "bigger/better", but I am a light duty user, and I have CNC plasma and several welders if I decide to beef it up or add width.
Their standard duty grapple actually looks pretty robust. What I like about it is the gripper teeth on the clamshell. That'll stop logs from rolling and slipping out. IIRC, it also has gussets where the bottom teeth meet the cross brace. While that may dig a little wider trench than you want, you'll be glad it has them because my LS grapple did not have them and I was constantly bending the teeth. I finally added gussets. I still bend them a little but only on the very ends where a few quick whacks with a 4 pound hammer fixes them right up. I still need to add them to my clamshell. One thing that stopped me from getting the Titan was the single cylinder. I dunno for certain and someone will probably tell me I'm wrong, but it would seem to allow the clamshell to torque pretty hard and put some undue stress on the pins. I could be completely wrong though. My LS has two cylinders, so perhaps that's even worse about torquing the clamshell, but the bracing in the little LS is pretty darn good. It's just the ends of the teeth that give me a little heartburn. If I could figure out a way to harden the whole thing, I'd probably do at least 6 inches on clamshell and body teeth. That also looks like Titan puts ripper chisels on the bottom teeth. Let me know how that works out for you. That thing oughta be a root eating monster, even for a standard duty.
6,844
Our forecast of 6-9” turned out 3. I’m not complaining. Still needed to do a little removal.
WI_Hedgehog
Apr 24, 2024
634
807
Milwaukee, Wisconsin, U.S.A.
Thanks for sharing, that's the funniest thing I've read in a long time. Sometimes I too have a job where everything just goes sideways so I'm laughing with you as a fellow wrench monkey. (y)
Old_Paint
Dec 5, 2020
1,850
1,909
AL
lynnmor
B2601-1
May 3, 2021
1,565
1,319
Red Lion
What a missed opportunity! Next time don't start till the better half fires up the video recorder.
Old_Paint
Dec 5, 2020
1,850
1,909
AL
I have my 400H service due right now (399.6 on the ticker). I didn't bother with just a filter change at 200H, I went ahead and swapped out the UDT2 when I remove the filters (had the wrong one for the suction filter, didn't I). The pressure side WILL NOT fit on the suction side. Note to self, MAKE SURE TO HAVE THE CORRECT FILTER WHEN CHANGING THEM. Pressure side filter was easy because I lost enough fluid to get below that level. Engine service was easy, except for removing the filter. Have to remove a guard for the fan belt to get the strap wrench on the filter. I haven't needed an air-filter yet, but I think I'll change it this time just for general gits and shiggles. Most of my work is on leaf mat covered ground, so not much dust.
Gonna go to my local Kubota dealer tomorrow and get the filters, UDT2, and some Kubota engine oil. I already have a full 5 gallon bucket of UDT2, but doing the front axle this time is gonna take a little more. 8 more payments and the LX is mine, all mine. Got a 5 year warranty when I bought it, and I'm thinking I'll keep the KTAC insurance on it just for giggles. Makes sense to protect it because I sure can't buy a new one again.
g_man
Feb 3, 2023
238
1,072
NE Vermont
I enjoyed your story ! One of those days where you have to fight everything. It made me glad I'm not on the bottom of the world where you are and it is upside down making it harder to do stuff.
gg
8,787
A mixed list today. A quick trip down and up the driveway to clear off as much of the overnight stuff as possible to limit build up. Then off with the snow blade, on with the pallet forks and ball to move a trailer, off with the ball, unload the pallet and fuel tank and move into the truck bed, off with the pallet forks and back on with the snow blade.
Reactions: 8 users
8,787
After I was done with the MX, I made up a test extension piece for the Buhler/Farm King rear blade to see if this cylinder rod extension concept is worth pursuing. This was a hurriedly made POS using what I had laying around. Extending the boom cylinder rod by 6" does move the boom over a fair bit more, which of course moves the blade over more, and gives me an additional 12" to 14" of reach on the left side of the tractor.
I'll test it out this week, and if all goes well I'll make this extension look a little better with the idea to make something a lot nicer in the spring or summer. You can see in the bottom photo that the boom has contacted the 3-point mount plate in the past (previous owner), and caused a little bit of damage. I made sure that there's about 1/2" of clearance between the boom and the plate at full cylinder extension.
Reactions: 9 users
MOOTS
MX6000
Jun 27, 2019
2,153
2,649
Canton, Georgia
Gonna haul the box blade to work, to add a receiver tube on the back. The toy yoda putting in work.
Reactions: 13 users
Jsjac
B2650
Feb 13, 2022
205
330
I cleaned up the snow we got. About 6"
Snow is starting to add up. I had to clear the snow from the front of the house where the snow slides off the roof. Started to cover the windows and the oil fill.
Jsjac
B2650
Feb 13, 2022
205
330
I see where it is hitting the frame. Is that a crack also?
g_man
Feb 3, 2023
238
1,072
NE Vermont
I have a ratchet jack on mine - slower than death. Cylinder would be better. A while back I drew up a tube within a tube using square tubing to give me quick adjustment but it is back away in the priority list.
I'll be interested to see what you come up with.
gg
8,787
The boom doesn't hit the plate when the boom cylinder is attached. That damage must have occurred when the previous owner disconnected the cylinder and let the boom swing over and make a hard stop.
No crack, it's just a mark where I had a piece of wood stuffed in there to make sure that there would be a gap between the boom and plate at full extension of the boom cylinder.
8,787
gg
I could cut and weld a plate to the boom to the right of the current bracket for the boom cylinder rod to connect too, but the extension seems like a less invasive solution. Once winter is over I'd remove the extension for regular use.
nerwin
Nov 13, 2024
513
1,214
Vermont
youtube.com
I've been blowing snow recently in 1°F weather but have blown snow in -20°F weather too. Having a cab makes it a far more comfortable task of course, but I've been on two open station tractors in -20°F weather and it's not a whole lot of fun. Do you think a blower is in your future? The ability to send snow 50ft to 75ft away can be very useful.
As for frequency of snow removal, this is affected by the kind of snow removal equipment you have, which is related to how long it takes, which also affects how good of a job you can do, and how enjoyable the work is. I don't mind spending 30 minutes moving snow in the morning and in the evening if necessary, but I wouldn't do that if I didn't have a good set up and certainly wouldn't be on that schedule if paying a contractor as my neighbors still do.
I don't think I'll be getting a snow blower, I can understand why some people really like them. My brother loves his, although it's front mounted. If I had a cabbed tractor and had to do a TON of snow removal. Definitely worth it but for what I do - the snow plow is good enough. Takes me about 45 minutes to an hour to plow my driveway, parking area and my neighbors as well. If I had cylinders and 3rd valve, I would save even more time! But nothing wrong with more seat time.
nerwin
Nov 13, 2024
513
1,214
Vermont
youtube.com
Woke up to 7 inches of snow this morning. Did lots of plowing, the banks are massive now.
It's looks like snow banks you see in big parking lots lol. I have the biggest snow banks on my road now 😎
When I was letting the tractor warm up, I noticed a little bit of green spot under the tractor. It was antifreeze...I'm like hmmm. Looked arounded and traced it back to the radiator hose, leaking right where the clamp was so I snugged it up some and now no more leak! Easy fix. The coolant reservoir never dropped any, still a hair above full so super minor leak.
8,787
I had to drive through 12" to 14" of snow yesterday to get to the pallet forks, and I was reminded of the difference between the MX with R4s and the M6060 with R1s in terms of performance in "deep" snow. The MX with R4s isn't great in that application.
I should have removed the front weights from the M6060 and reinstalled the loader with pallet forks for the winter, but will add that to my to do list next fall.
Old_Paint
Dec 5, 2020
1,850
1,909
AL
Picked up my filters and engine oil at the local dealer today. They claim 5 gallons will do the trick to refill the tranny and the front axle on the LX2610SUHD, so I guess we'll see. Gonna try to meter it in rather than just glug-glugging it into the tranny first, and hold off on the front axle until I know for sure I have at least a gallon left over in the bucket (per the salesman). If 5 does it, I'll pick up another bucket next month. Gotta ration my tractor expenses these days. Nearly $150 for filters and engine oil. It's still under warranty, so I'm sticking with the Kubota branded oils. Warranty runs out about the same time I make the last payment, and was timed that way for a reason. I will be looking at less expensive substitutes, especially engine oil when the warranty is done.
UDT2 is also expensive so I'm hoping for a full 400 hours out of this change. It was changed at 50 and 200 hours according to the service schedule. Schedule said just filters at 50H, but I went ahead and put new oil in. Couldn't hurt, and I had the money at the time. Now I'm just holding out for some dryer and warmer weather. Crawling around on concrete is better than crawling around on gravel, and certainly better than being in the mud, but the slab in my shop will suck all the body heat out of ya in a blink. I do have some anti-fatigue mats I may try out under there this time, though. Turns out while anti-fatigue mats are great for feet and ankles, they don't do diddly (except perhaps make it hurt worse) for messed up discs at L2, L3, L4 and L5. Never mind they don't follow me around when I'm working in the shop. Hopefully I don't spill much on them and can use them again. Gonna drop the BB and the FEL (with the bucket on) so I can do a good cleanup and proper greasing after giving Lexy a bath. She's overdue, but I've been trying to keep the worst sprayed off with the hose and wiped down. Time for another good thorough cleaning so I can monitor for any newly developing leaks. I'll do the grapple next.
PS. Does anyone know how much replacing both filters affects the refill quantity on the LX2610SUHD. IIRC, it does hold a little less than the non-SU models because there's no mid-mount PTO, but seems I remember at least 4.5 gallons going in to get proper level on the dipstick. I raise the lift to fill the lift cylinder for checking level as well. Dunno, just always figured it should be accounted for.
