shootem604
Apr 23, 2018
874
British Columbia
Started building a 3 point pallet fork/carryall. Have to do a little welding yet, and then paint. Also tacked together the frame for my 3 point scraper made with half of an old skidder tire. Maybe finish them this weekend.
JeepinMaxx
BX2660, LA243 FEL, RCK54P-23BX MMM, BX2751 QH Subframe, BX2750D 50" Blower
Mar 27, 2018
296
9
Columbia, CT
Adapted my leaf sucker to my Kubota and tried it out this evening:
Before:
After:
The combination of the MMM and Cyclone rake engine turns leaves into confetti/1/4 stamp size! Did a 1/4 acre on one dump...
7,070
Mower deck off and fall service.
317 total hours, 64 hours in the last year.
Doing HST Fluid/filter / screen cleaning also. Last done at 38 hours.
Will hope for a better day to do Tire chains. May not put FEL on, don’t have a need now....snowblower time is coming....
Had a few big filings in my first change. Screen looks very clean this time.
For what it’s worth, I found a spot where a bunch of grass clippings get jammed in above the bottom frame, aft of the lift pump. Never noticed it before, and it’s not a mouse nest.
I think it’s about under the battery on a BX. Good place to check if you mow a lot, like I do.
highonrunning90
Eastern Maine, USA
After over a month waiting, i finally took Delivery of my B2650 and put it right to work on the driveway. Long overdue rutting abd wash-outs dissapeared within a few hours.
What a great feeling accomplish a task in such comfort. [emoji16]
Sent from my LGUS215 using Tapatalk
Blkvoodoo
B2400, LA352, RC60, Cammond Box Blade
Mar 27, 2010
143
Zebulon NC
it started small 1A school, only needed one utility trailer to haul all their percussion
but it grew into a monster 4A schools, needing multiple trailers and tractors.
was a good time !
the first of four years of this crazyness !
OhioOrange
BX2360
Sep 6, 2016
I fixed the "Loss of Power" at full throttle. I chased the problem first by changing the fuel filters, then cleaned the fuel cap vent. That did not solve the problem, still no power at full throttle. I then decided to remove the fuel line from the first fuel filter. I noticed that it did not flow very well by gravity. I used compressed air to blow it out from the fuel line to the tank. It sent fuel into the air from the fill and removed the problem causing fuel starvation. If the problem returns then I know the tank has debris and will clean the tank and that should solve it.
7,070
I would look into a box blade or grading scraper for that. You'd be surprised what you could do!
Just a suggestion, and welcome!
Fordtech86
L3200
Aug 7, 2018
4,966
5,916
Pineville,LA
‘Bota was busy this weekend, used the rake to pull some downed limbs to the burn pile, pulled the splitter out to a pile of logs that have been down a while, split a little of that before I started getting into fire ants and termites, and had to kill a snake in there. Gave up on splitting that stuff and hauled it to my brush pile whole to burn. Then since I stirred up the ants and termites I had to spray for the bugs. Today I cleared some more brush to add to the pile
otter
L3800, LA524 loader, BH77 backhoe, thumb, box blade small wood lot log grapple
Sep 26, 2014
52
Chase, Alaska
Sorted out the troublesome relief valve on the backhoe boom lift thanks to help on this site, then dug out two birch stumps, hosed off Baby and put her on blocks for the winter with a fresh 400 hour fluid/filter servicing 6 hours ago.
Ground is freezing up but no snow yet.
Sleep well Baby.
Mainah
L2501HST, BLMX3164 blower, BB1266 box blade, BX42S chipper, Titan forks
Feb 26, 2018
100
Standish, Maine
Congratulations on the new tractor! Beautiful picture btw. I was born in Eastport and I love the whole Downeast area.
I agree with a box blade though, or a land plane for a driveway like that. Then finish with the York rake.
SidecarFlip
Banned
562
Replaced the fuel cut solenoid on the M9 this morning. First component failure in over 10 years. Dang thing cost over a hundred bucks. Finally ordered the 540-1000 pto kit for the M9 as well. That will take some work to install. Have to pull the back cover on the transmission and drain all the fluid.
Fordtech86
L3200
Aug 7, 2018
4,966
5,916
Pineville,LA
Loaded mine on the trailer to pull the trailer for trick or treating tomorrow,calling for 1-2 inches of rain tomorrow night so it may just spend the night at work :(
flyidaho
L 3301 HST
Feb 28, 2017
428
255
IDAHO
Took a load of clean fill, excavated with the U25 mini excavator, as part of my project to add onto my pole barn an additional 30' by 13', out to the end of the driveway. Using the tractor to move the 5 ton dump bed trailer around is perfect, and so much easier then using the pickup. I dumped it to enlarge a bit the drive entry, it's radius coming off the county road, and as long as I happened to have my 54,000 lb. 30 ton (capacity) boom truck home that day I used it to compact the dirt by making repeated runs over it, perfect!
