6,893
Back on.
Seems like it just came off a couple weeks ago..
6,893
"Antennae" on...just 4 angle brackets, but it works. They need to come of in summer anyway.
Will aim them later. Two forward, two back.
greeno
B2710 w/LA402 FEL, BL4690 hoe, RB1560, GS1560, Haban 5' sickle bar, 5' JD RC
Jul 14, 2018
187
Big Lake MN
Winterized the B today. Shoulda done it last week this 12 deg business is for the birds.
JeepinMaxx
BX2660, LA243 FEL, RCK54P-23BX MMM, BX2751 QH Subframe, BX2750D 50" Blower
Mar 27, 2018
296
Columbia, CT
Back on.
How difficult is the quick hitch snowblower install? My BX2660 came with that set up - I was considering leaving the loader on for snow
6,893
Easy. Toughest part is hooking up PTO, my hands are too big.
If you’re in an area that can get a lot of snow, the blower is the ticket hands down.
I don’t have much room to push snow around. I throw it once.
If you need help, give us a shout. Lots of guys with this setup.
6,893
Will see how my heavily modified shoes work out.
The steel extensions were done couple years ago, and have worked great on a stone driveway.
The UHMWP liner is new for 2018....
WFM
L3800
Apr 5, 2013
1,478
894
Porter Maine
I moved a few stacks of pallets down back out of the way of plowing this winter. Then sit my new woodmaxx snow blower on the flat pavement and adjusted the shoes.
Then I got out my Dewalt cordless grease gun and greased the blower and tractor from end to end. I've used my Dewalt grease gun like 5 or 6 times.
Whatever I paid for it. Its worth twice as much. Working alone it makes greasing SO easy. If I only used it twice a year its well worth it. Anyone that doesn't have one should.
thebicman
B2601 + BX2755HD + 50" box blade
Feb 2, 2017
337
100
Ottawa, ontario
Put the subframe and front blower on again. Serviced the fel before taking it off and sprayed everything down with krown rust proofing. Found out my daughters old skateboard is the perfect height to slide the subframe under the tractor. It took a grueling 90 seconds to hook it up. lol
aeblank
411
Cadillac, MI
Takes way longer on a grand L. I hate that frame.....
Sent from my XT1254 using Tapatalk
3,098
I re-installed my newly resealed FEL hydraulic pump, installed the PTB, changed the oil & filter, topped off all three hydraulic reservoirs, topped off the battery electrolyte, checked tire pressures, switched from the 14" toothless bucket to the 9" toothed bucket on the backhoe & greased it. Then I tested the PTB, as shown in the PTB thread.
shootem604
Apr 23, 2018
874
British Columbia
Dug some trenches to bury some waterlines before the winter freeze. Broke the ball joint connecting links for the control levers - first the balls pulled out of the sockets at different time (fixed by tack welding a split washer to the socket) and then the ball on one broke off the shaft, perhaps weakened by the heat from welding. Ordered new parts from the local dealer - I will replace all four - they come in tomorrow. Then I can finish the last 30ft of trench.
Mike9
Kubota B6200
Oct 9, 2015
391
31
Ghent, NY
Yesterday was the third dry in a row in months!!! After two days of pretty good wind yesterday was 48 degrees and sunny - perfect do or die time to till some patches in the back field. I hooked up the tiller (after some swearing and lots of oil) and tilled each patch twice after broadcasting pelletized lime. Then I put the york rake on and raked then hand raked. It RAINED AGAIN today :mad: If I'm planting garlic on Thanksgiving then so be it. :D
I know a lot of pissed off farmers around here. They have hay and corn in the fields and can't get to it. If they lose that feed some could go under do to the cost of buying feed with money that is scarce.
JeepinMaxx
Mar 27, 2018
296
Columbia, CT
Thanks for the input! Can I leave the quick mount on and still have the loader mounted? (obviously not the hydraulic hoses)
JeepinMaxx
Mar 27, 2018
296
Columbia, CT
Used the FEL to help my wife set a base step granite stone
Also hit the 300 hour mark!
SidecarFlip
Banned
557
Started them both in the barn and let them warm up. Took a bit of pre-heat to get them to pop over and some white smoke from the exhaust stacks too. Was 20 when I started them. I start them every couple weeks in the winter to keep the batteries up and the juice inside circulated. Besides, I like the music of 2 M's sitting side by side running.
Sometime this winter I need to pull the front rims on the M9, dismount the tires and install a new set of R1's. Before I do that, I'll sandblast the rims, rime them and repaint them. getting a little ratty over the years.
The 9 gets at least 2 times the pavement miles the 105 gets. The 105 usually stays hooked to the round baler whereas the 9 runs everything else so tire wear (from pavement) is greater on the 9.
I like leaving the round baler hooked up because of all the hydraulic lines and electrical / electronic connections involved.
