Fixing hole in side of block
Status
Not open for further replies.
whitetiger
Nov 20, 2011
3,844
2,236
Kansas City, KS
What good are frost plugs, really?
There are no freeze plugs in an engine block. However, there are core plugs that were used to clean the mold sand from the cooling system and a few galleys in a block.
People referring to a core plug as a freeze plug does not make it one.
joesmith123
L295DT, BX1500
Mar 18, 2023
296
140
earth
Shape your realm for 14 hour straight
L295DT ran for 14 hour straight with no issue
Beside building you a shop, L295 also grading half mile road with massive pits in it
Does not get hot, only gets hot if you're not moving and working one area in low gear
You even got into 7th gear with the bucket grading your half mile road
You would be in 6th gear going to a pit you are trying to grade out, your bucket bulldozing through anything
Sometimes you would hit a rock 🪨 and your entire robot when to come to a halt,
But your massive rear tires are spinning while you are stuck, she will spin your tires in high gear rather than shutting down your engine when you come a halt
Unbelievable
Both of magic trick did not hold from your crazy abuse
The bolts should be holding but you haven't made sure yet
These are 2 massive pits on the half mile road that you are fixing to level out
What you are doing: run you that blade hard along edges with all weight of your robot
Dragging it to the low point,
Then make you massive strides going downhill trying to build up low spot, hit it from both angle with big force from your robot
Your magic trick not work, you ain't no magician
It ran for 16 hours and used not even 5 gallons, there's no way right?
dragfan66
B7500 Z231KW G1800 L3350DT
Apr 12, 2020
65
74
Alabama
Nice playground for sure.
I'm glad the tractor is still running and shaping your realm, Joe.
Ktrim
B2400, lA352 loader,3pth quick hitch/z122r zero turn/restored 52 farmall super a
Dec 23, 2020
444
372
Nazareth Pa
Think Joe inhaled too many various fumes through this project.
Not even sure what person he is speaking in lately. 🤷
3,600
I keep running across Vids of Joe reshaping either his tractor or his realm:
JRHill
Orange: B7100 Std and Woodmizer; Green/yellow JD Buck, Gator and 410j.
Apr 26, 2016
284
235
Wahkiacus, Washington
Sand. I remember sand. No boulders or rock. Just sand. I understand better now.
jaxs
B1750HST
Jun 22, 2023
1,135
847
Yep sand has been essential to joe's adventure. Once something is saturated with diesel sand kicked in a breeze sticks giving it just the right amount of abrasive to clean til it's shiny as diamonds in a goat's hinny.
Vlach7
L47 305DT JD500C
Dec 16, 2021
457
330
Frazier Park Ca
Joe get yourself a 110 volt wire feed flux core welder from HF, Im sure after a couple hrs of playing with it you will be able to produce a much stronger weld then the brazing your doing.
joesmith123
L295DT, BX1500
Mar 18, 2023
296
140
earth
bust your tires, fight you with your neighbor, transmission talk
Your 30 year old tires disintegrating and hitting your nice new paint
good thing you got some spare wheels, switch you out busted tire and keep shaping realm
install you a hillybilly lambo push to start on your tractor
your other switch was left on and you ran your starter for 30 minutes with the engine running but starter still work
your neighbor ripped out your glow plug switch because he claim:
"you are making the road worse"
he forced you stop fixing the road, stole 2 gallons of your hydraulic fluid, and chased you back to your shop to make sure you stop working the machine
your glad he ripped the switch out because now when you want glowplug, just make those 2 touch for a bit, works perfect
transmission talk:
you start off all excited running it in high gear 2 wheel drive swinging you that big steel around, then
you realise its true earth moving capability is in 4wd low gear
then you become like a japanese artist and unlock the true potential of robot
go you uphill in low gear bucket down on the ground flattening, then
push you that bucket hard into your earth, the power of that 4wd in reverse going downhill is tremendous, earth moving and noticeeable, and
the driveline somehow can handle 7000 pounds or more total of force, meaning
you let that clutch out, and all 4 wheels are pulling back your earth with big might,
something has to be really strong inside their transmission that can orchestrate the entire thing
your suspicion was right in that inside that transmission are crazy strong gears that come from old foundry better than the new foundry
You havent tried to break it yet but your suspicion is that even if you tried to break it, you couldnt
what an idiot, you thought you can lift up a chassis like it was not packed with crazy thick steel/gear/everything
you honestly think you can move a mobile home in low gear with your robot
your busted tire ruining your paint job on your loader frame
put you your other L295 wheel and keep churning
Stuff breaking but you still churn earth 🌎
L35
Jun 13, 2010
734
844
CT
Joe, what’s the plan to repair those blown out tires?
Maybe;
Tarmy
L2800, BH76A, FEL,box scraper
Nov 17, 2009
620
649
Lake Almanor, Ca
Who is Joe talking to?
Joe has a whole host of friends, they are there in the pics. They are a team that he communicates with to address the next ailments of the Orange patient. They may appear to be invisible….but only to us mortal types.😎
5,761
Now I remember, why i stopped following this,, its like a bad acid trip on crack
BX23-S,57 A-C D-14,
6,340
FYI The slang term "freeze plug" was coined many decades ago based on the mistaken belief that the primary purpose of the core plugs was to protect the engine block against freezing.
7,744
Do you think it is possible Joe has some connection with the things people see flying on the east coast? You know, the things some people see but they are not really there as reported by some government know-it-alls.
rudder35
MX4800, G1800, Bobcat E26
May 22, 2023
50
60
ac3510!??
Agree with the MIG or he could get a Lincoln stick. He should also get an old sink and electric fuel pump for a parts washer.
Status
