jkavanagh58
L3302
Feb 17, 2025
12
32
Avon Ohio
The Quick Hitch has been a nice add to my 3302. It works great with my Land Pride implements but I have had issues with another implement.
I threw the Quick Hitch (QH16) on and while not easy connecting to a non-Land Pride implement, that previously took considerable effort to attach, took about 30 minutes. Now I would point out that the implement posts need to be a little longer for the lower arms attachment but hooked up and pulled several rows of plastic mulch layer.
Old_Paint
Dec 5, 2020
1,860
1,922
AL
I have a cheapo Harbor Freight QH. I modded it because it was a PITA to get connected to anything I had. I also learned that most QH’s are designed for cross category use, trying to be universal. Not every implement will be QH compatible (regardless of the label stuck on it). I have modified my box blade, converted my sub soiler and trailer hitch so that I didn’t have to modify the WC68. There is a slight difference in the angle of the 3 point frame on everything I have except the trailer hitch. Then I discovered my Cat 1 hitch was drilled for Cat 2 pins on the toplink and the hooks were sized for Cat 3 lift pins. Both of those problems were easily resolved with some bushings from Tractor Supply. I found out TSC color codes the bushings for toplink and lift pins which made it easier to figure out what I needed. I like the QH for anything that doesn’t need the PTO, but i am not a fan of it for anything that does. I’m still considering a set of Pat’s hooks that I won’t have take off for the PHD.
johnjk
Apr 13, 2017
1,618
1,653
West Mansfield, OH
Well I thought it was done and she opened up. Time to hide more. My cigar was getting wet. Put down close to .5”. Done mowing
biketopia
Feb 15, 2024
328
326
Warrenton VA
We've had 5.5" of rain this month, and about 3" of it has fallen since Friday afternoon. Supposed to dry out for the next 4-5 days, but it's going to be HOT and humid...Need to cut all my grass before it turns into a hayfield again. Also need to fix the driveway where the heavy rain pushed the gravel all around.
johnjk
Apr 13, 2017
1,618
1,653
West Mansfield, OH
I may have to bite the bullet and do a few passes with the land plane in the rain. Plus side there won’t be any dust
S-G-R
LX3310 for now, L5460 in progress
Jun 17, 2020
1,343
3,101
PEI Canada
Watering our fruit trees, maples and lone oak. It's been dry and I don't want to lose them.
Reactions: 11 users
S-G-R
Jun 17, 2020
1,343
3,101
PEI Canada
I've moved on to water can 2.0 I had the second tote so I figured that I may as well put it to work.
Reactions: 9 users
johnjk
Apr 13, 2017
1,618
1,653
West Mansfield, OH
Quick trip out of the barn to haul all the garden trimmings the wife did today while I was at work. I love the sound of the B3200. More rain coming in so back inside and time to enjoy a margarita while we watch the storms roll in
S-G-R
Jun 17, 2020
1,343
3,101
PEI Canada
Your continued diligence in watering the trees you have been planting is very commendable!
Thank you! We've put a lot of time and money into the yard so it's a small price to pay for future shelter and shade.
nerwin
Nov 13, 2024
521
1,250
Vermont
youtube.com
I feel lazy. Don't worry I didn't get underneath it! I have a long scraper tool I use to remove some of the stuck grass. There's a certain spot where it likes to collect and gets clogged easy when it's stuck so I was lazy and used the tractor. Hopefully now it won't clog up so easily. I need to take the deck off and pressure wash it but perhaps another time.
Reactions: 9 users
S-G-R
Jun 17, 2020
1,343
3,101
PEI Canada
Mowing at the BIL's. The Lupins are out in full force.
Reactions: 11 users
