tested out my new stump grinder
And?.....tested out my new stump grinder
I threw the Quick Hitch (QH16) on and while not easy connecting to a non-Land Pride implement, that previously took considerable effort to attach, took about 30 minutes. Now I would point out that the implement posts need to be a little longer for the lower arms attachment but hooked up and pulled several rows of plastic mulch layer.The Quick Hitch has been a nice add to my 3302. It works great with my Land Pride implements but I have had issues with another implement.
I have a cheapo Harbor Freight QH. I modded it because it was a PITA to get connected to anything I had. I also learned that most QH’s are designed for cross category use, trying to be universal. Not every implement will be QH compatible (regardless of the label stuck on it). I have modified my box blade, converted my sub soiler and trailer hitch so that I didn’t have to modify the WC68. There is a slight difference in the angle of the 3 point frame on everything I have except the trailer hitch. Then I discovered my Cat 1 hitch was drilled for Cat 2 pins on the toplink and the hooks were sized for Cat 3 lift pins. Both of those problems were easily resolved with some bushings from Tractor Supply. I found out TSC color codes the bushings for toplink and lift pins which made it easier to figure out what I needed. I like the QH for anything that doesn’t need the PTO, but i am not a fan of it for anything that does. I’m still considering a set of Pat’s hooks that I won’t have take off for the PHD.I threw the Quick Hitch (QH16) on and while not easy connecting to a non-Land Pride implement, that previously took considerable effort to attach, took about 30 minutes. Now I would point out that the implement posts need to be a little longer for the lower arms attachment but hooked up and pulled several rows of plastic mulch layer.
I may have to bite the bullet and do a few passes with the land plane in the rain. Plus side there won’t be any dustWe've had 5.5" of rain this month, and about 3" of it has fallen since Friday afternoon. Supposed to dry out for the next 4-5 days, but it's going to be HOT and humid...Need to cut all my grass before it turns into a hayfield again. Also need to fix the driveway where the heavy rain pushed the gravel all around.
Awesome tractor! It looks new.a bit of water Hauling to the cows, sheep and horse. View attachment 156772
Your continued diligence in watering the trees you have been planting is very commendable!I've moved on to water can 2.0 I had the second tote so I figured that I may as well put it to work.
Thank you! We've put a lot of time and money into the yard so it's a small price to pay for future shelter and shade.Your continued diligence in watering the trees you have been planting is very commendable!
Thanks, I recently spraypainted the rims and the ROPS. That makes a big difference.Awesome tractor! It looks new.
