B7200 hydraulic steering
Paul Allwood
Kubota B7200HSTD, RC60-72H MMM, homemade FEL, forks & ballast box, rotary hoe
Jul 8, 2025
667
1,176
I'm in the process of purchasing some hydraulic steering bits from a BX from Daryl at Mossy Creek Outdoors @Mountainman - planning to attempt to fit it to my B7200 HSTD 4WD hydrostatic.
I found the plumbing diagram below on another thread - I think it was done by @North Idaho Wolfman - apologies if I have that wrong.
The specified maximum hydraulic oil flow rate is 15 l/min.
Would this plumbing work in my case ?
Is the line out of the steering control valve to the PB/T a pressure line suitable for supplying the FEL valve ?
Many thanks as always.
11,014
No you can not do that, there are several reasons, but #1 is that the PS controller can not handle the volume required to run the rest of the systems properly.
Have him send you a priority valve to split the flow into 2 paths.
Paul Allwood
Jul 8, 2025
667
1,176
Ok, thanks heaps.
I'll have a go at a plumbing diagram and post it for critique.
7,231
Ok, thanks heaps.
Its just a prority flow divider that duvides one input stream (pump) into two separate outlet steams. One outlet has priority and gets a fixed flow for the PS circuit. Excess flow, if any, goes to the implement circuit.
Therein lies your problem. Your pump produces a 4 GPM flow at max RPM and if you suck off anything close to 15 LPM for the PS circuit there will be nothing left for the implement circuit. What you need is an additional pump for the PS and forget about a priority flow divider.
Paul Allwood
Jul 8, 2025
667
1,176
Thanks Dan.
Paul Allwood
Jul 8, 2025
667
1,176
Well, this leaves me in a difficult spot of not really knowing what to do. I've only been a member of OTT for about 6 months with no previous experience with tractors or hydraulics. I've got two different opinions on which path to take from two of this site's respected experts, @TheOldHokie and @North Idaho Wolfman and I'm in no position to pretend to be able to argue with either of you.
Dan, NIW - is there anything you can offer to help clear the path ?
Many thanks both.
3,075
@Paul Allwood
Not that you asked me but here is my opinion on your situation.
1) NIW was probably focused on the system requirements of a priority flow divider and never considered how much GPM that your tractor hydraulic pump can produce. So he just pointed out that you need the priority flow divider.
2) The Old Hokie probably has the manual for your tractor that states what the hydraulic pump flow is. I also assume he knows how much flow the BX steering system requires in a similar manner. So he is warning you that you can’t use the tractor pump to do both steering and implements. He suggested separate systems to resolve your issue and still have power steering and be able to use your implements.
I suggest you confirm how many liters per minute your tractor can produce and also how many liters per minute the power steering system requires. Then you can see the dilemma yourself and decide how to proceed.
As I see it you have three options:
1) Abandon the plan for power steering.
2) Provide a separate pump that will satisfy flow for the power steering.
3) Change to a different type of power steering that doesn’t require as much flow.
You can mount a hydraulic pump that is driven off the front of the tractor crankshaft or driven by a belt.
You can see the belt driven pump style and a priority divider valve in this thread as well as an older type of power steering system that was used on a tractor that was produced in the same era as your tractor (I may be wrong on years of production).
And I apologize in advance for butting in!
3,075
And I forgot to mention that the separate pump might be able to be used for the FEL (which I think you added) but that would require the use of a priority flow divider valve.
Paul Allwood
Jul 8, 2025
667
1,176
@Paul Allwood
Many thanks Russell. I don't think I'd like to assume what anyone did or didn't take into account here, but all input is most welcome.
7,231
You dont have to assume anything.
Do you understand what a priority flow divider does and why they are used to provide a PS circuit? Thats what NIW was hinting at.
I simply pointed out that in your specific situation that solution is problematic due to the low flow rate of your hydraulic pump and the flow requirements of your loader.
Kubota offered a factory PS option for the B7200. It used a priorty fkow divider placed between the pump and hydraulic outlet block . It stole flow from the aux and 3pt circuit and the negative effect of that on a loader is unambiguous. That may be why very few B7200 tractors had factory PS.
Kubota has moved away from using flow dividers and now favors tandem pumps with one section supplying a steering circuit and the other suppkying the implement circuit.
Your options are pretty limited.
  1. Use your original circuit and live with the problems inherent in it.
  2. Add a flow divider and live with the problems inherent in it
  3. Retrofit an EPS type system and live with the added stress a loader puts on the woefully fragile steering box.
  4. Forget about power steering and live with heavy steering and the same steering box problem inherent in (3).
  5. Add a second pump and avoid all of the problems above.
7,231
I found this on the web B7200 power steering, don't know if has anything to do with your tractor.
That is the parts breakdown of the B7200 factory power steering option. Very nearly a Unicorn and suffered from the insufficient flow problems I described earlier.
Paul Allwood
Jul 8, 2025
667
1,176
Many thanks Dan.
It's looking like it's hard to go past option 5 above. I assume an automotive style power steering pump would work (since they work in cars), and they will be easy to source.
My understanding of priority flow divider valves is limited to what I've picked up in this thread - so it's not much. Probably more questions than answers.
7,231
Many thanks Dan.
Option (1) "works" but you have the steering in series eith the loader and 3pt. The problem with that is when you operate the loader you lose power steering assist
Having owned a B7200DT I think a front mounted crankshaft driven pump is the easiest way to add a second pump.
7,231
Many thanks Dan.
This is from the BX1880 WSM and shows how the power steering circuit is implemented.
  1. Item (3) is the priority flow divider which takes the full output of the hydraulic pump (max of 5.5 GPM) and divides it into two separate supplies
  2. The priority stream is a constant 1.8 GPM flow and is sent to the steering controller
  3. The excess stream is whatever is leftover after the 1.8 GPM is diverted from the pump supply. It is sent to the loader outlet block and from there to the 3pt control valve.
  4. Simple arithmetic tells us the maximum flow going to the loader is 3.7 GPM which is pretty close to the max your B7200 pump can produce.
  5. The pump on your B7200 can only produce ~3.9 GPM so using a flow divider and this PS controller on your tractor reduces the max loader supply to 3.9 - 1.8 = 2.1 GPM. Its going to be about half as fast as it is now.
Does that help your understanding of prority flow dividers any?
Paul Allwood
Jul 8, 2025
667
1,176
Thanks Dan. Yes, it does. I was wondering if there priority valve always takes the steering flow even when there is no steering happening - this makes it clear.
11,014
You have an HST, you could very easily add a pump to the MID PTO and get all the right performance without the issue of attaching to the front of the motor.
The coupler for the mid PTO is pretty easy to get.
11,014
Oh and you would use the Mid PTO pump to run just the loader.
Paul Allwood
Jul 8, 2025
667
1,176
Thanks - adding a pump to the mid pto sounds appealing if it weren't for the mid-mount mower getting in the way. I might still have to come up with a way to mount a pump to the front so I can leave the mower alone.
