M4900 Hydraulic Problems. Power steering, PTO are OK. Everything else weak
wheelinag
M4900
May 16, 2025
La Grange, TX
My intelligent colleague just made a good point. Maybe there is some kind of suction problem? How much PSI does it take to make the steering work?
5,697
I dont see this being a suction side problem and I don't like guess work when I can quantify things.
You now have a pump pressure test adapter - test the PS pump. PS pressure relief specification is 2631 PSI. Also measure the flow rate coming to the loader valve. All that takes is a bucket and a stop watch.
wheelinag
M4900
May 16, 2025
La Grange, TX
I'll do this when I get the pump in as I'll be taking that off anyways.
While I haven't done any flow tests yet, I've discharged fluid into a bucket quickly a couple of times and did the pressure tests into a bucket as well. Probably 20 seconds total, but I'd say there's a little over a few gallons in there. Obviously not very scientific.
I need to put it on the back burner until the pump gets in and catch up on work.
2,393
Just to provide you with more information on the tank return line since you asked a question that I didn’t see an answer to.
These Kubota tractors have open center hydraulic systems (for the most part). That means each valve just lets the hydraulic oil flow through with little pressure since there is no restriction to flow. The Power In port is the feed into the valve, a Power Beyond sleeve is added to one port that allows the open center flow to the next valve. Most valves in modern hydraulic systems have two lines that go to a double acting valve, pressure on one side forces the piston and ram to move. Tho other hose is used as a return line so the hydraulic fluid is fed back to the valve. Then the valve has a Tank Return port that dumps the fluid back to the tractor sump.
So most valves today on smaller Kubota tractors will have three lines (P, PB, T) connected to them. In older systems the valve may only use 2 lines and that can cause problems with too much pressure in the valve body (if I recall correctly).
5,697
His valve has IN, PB, and TANK via the manifold.. Its the unused work port thats the issue.
wheelinag
M4900
May 16, 2025
La Grange, TX
To start off, I didn't check the power steering side pressure. There was no way I was fitting anything in between the pump and the hardline without taking the entire hard line off and I really didn't want to take the dash apart to get to the steering valve. A fairly interesting observation was that that when all the intake and pressure lines were off the pump, the steering side was still fluid all the way to the top, and the main side had no fluid in it.
I had read that somewhere on this forum that someone used a chinese pump, but the bolt's didn't line up correctly. I measured the individual ports on the top and they were fine. Get the pump off and first thing I notice is the new shaft doesn't have a snap ring groove to hold the drive gear on. Secondly, the pump is shorter. Looks like there are spacers in the middle that are different. The shaft wouldn't be an issue, I'd probably just be lazy and grind a groove carefully with a thin cutoff wheel. The spacing is an issue for the bottom, as the the ports on the hardline are fixed.
I'm going to take the main side of the pump apart and see if anything is apparently wrong. I don't think I have much to lose at this point.
wheelinag
M4900
May 16, 2025
La Grange, TX
Alright experts, seal kit? Worth a try for $100? I thought there was varnish in there at first, but looks like it's a backer.
The only real concerning thing I can see is the wear on the aluminum bushing holders. Not actually sure what they are called.
Pics.
5,697
Pics. View attachment 155574 View attachment 155574 View attachment 155575 View attachment 155576 View attachment 155577 View attachment 155578
The pump has self destructed from oil starvation or over pressure. A seal kit is not going to fix it. If the new pump will fit put it on. If not a new OEM pump is $2K.
wheelinag
M4900
May 16, 2025
La Grange, TX
I could cut the intake tubes and reweld them to fit this pump, or make an adapter plate, but with the shaft also not having the two grooves for the snap rings, I'm worried about what else in the pump is wrong. I'm probably just going to buy an OEM pump.
What I really want to know is why this pump failed at that moment, so the new pump doesn't fail the same way. There was plenty of fluid at the time of failure. All I had done for the previous 6 hours was use the mower and push around a little dirt from irrigation ditches with the loader. There was not lack of power, noise, etc...
The seals were not in good shape. Did the seal cause the failure or did failure chew up the seals?
I will add another line to the cylinder on the mower. Maybe 1000's of times of hitting the relief valve pressure caused this? The last time was just the straw that broke the camels back?
5,697
The new gear is probably pressed on or retained in some other fashion. I doubt its a manufacturing defect and would not worry me in the least. There are probably other internal differences.
I am assuming the bushing blocks in the old pump are also wear plates. A common design technique is to provide an internal oil passage that uses the oil pressure generated by the pumping gears to push a movable wear plate up against the gears. That compensates for normal wear and limits oil loss (slip) caused by excessive end clearances. From the looks of your failure the wear plates were destroyed by the gears. Two things come to mind - excessive pressure and/or insufficient oil. I dont think the case seals had a role in the failure.
At this point in my life I am inclined to spend money for parts rathrr than retrofit things. But $2K is a lot of money and a little bit of hose is cheap. Welding would not be in my game plan.
wheelinag
M4900
May 16, 2025
La Grange, TX
The gear is probably pressed on or retained in some other fashion. I doubt its a manufacturing defect and would not worry me in the least. There are probably other intermal differences.
I'd still have to cut grooves for snap rings to locate my gear correctly.
Ok, but why now when it wasn't really being used hard? Mainly, I just don't want to repeat this.
I'm probably just going to go OEM. I need the tractor sooner than later. I work for myself, so time working on this is taking away from that.
Lastly, when I called the hydraulic shop last week, they said they have a guy there who rebuilds these type of pumps. I'm skeptical as I can't find parts. It could definitely end up that the guy on the phone doesn't know this style pump. I guess I'll find out tomorrow and talk with them before I buy and new pump. Anyone had luck with going this route?
5,697
Probably more than you ever wanted to know about external gear pump design and operation:
There are some things that are just not rebuildable. Small external gear pumps are in that category.
wheelinag
M4900
May 16, 2025
La Grange, TX
Finally got the pump in yesterday. Looks like this ordeal is over.
After installation, I had the relief valve almost all the way out and started up the tractor for very short periods and couldn't get any flow. I did this less than a handful of times and less than 10 seconds. Enough to know that the pump wasn't getting oil. I had searched on bleeding and priming and didn't see anything in the manual or many posts regarding this.
I cracked both outputs, pulled the engine stop and cranked. It probably took 5 times of cranking for the main pump to burp and even longer for the steering pump. I did this until I had good flow. Bolted both outputs back down and immediately had pressure after it started up. I hope this might help someone in the future.
Pump had some pretty thick assembly lube in it, so not too worried about the initial startups.
Now to set the relief pressure and get this thing buttoned up.
I think I'm going to sample the fluid in 5 hours or something arbitrary.
