Kubota b2150 HST not working
11,292
I got the three point to go up and down. If the tractor is moving, when I move the 3-pt up, the tractor stops until it’s all the way up and the tractor moves again. 3-pt going down doesn’t seem to make that much of a difference. On medium speed, the tractor moves only on flat paved surface. On high speed, the tractor moves at times but only in the garage on flat concrete floor. This is frustrating!
Have you ever had it running properly?
I'm pretty sure its a fluid flow issue.
Turn this valve a 1/4 turn and see what it does to the operation.
Matoyan
b2150 and b2320
Oct 30, 2024
78
9
Rhode Island
I bought it as is unknowing the condition. I heard the engine run and I know the clutch was bad and it was leaking from a seal on the shaft. The clutch and the seal has been repaired by the dealer. I do remember we had a hard time getting in the trailer, but I assumed it was the clutch. It had been sitting for a long time. So should I open the valve all the way and then close it a 1/4 of a turn or close it and open it a 1/4 of a turn? The loader is not on it and I have the loop connected.
11,292
The selector valve only should turn 1/4 turn, there should be stops (roll pins).
It turns off the loader loop and makes the hydraulics take a direct route to the three point and HST.
When the loader was on and working, was it strong and fast?
Matoyan
b2150 and b2320
Oct 30, 2024
78
9
Rhode Island
It runs and acts the same way no matter what direction I put the selector. I also unscrewed the air bleeder bolt and a small amount of air came out before hydraulic fluid flowed out but runs the same. The hydraulic cooler in front of the tractor looks “newer”, does that have a bleeder bolt/screw? I can’t find one and I’m thinking maybe air is trapped blocking fluid flowed? Is that possible?
11,292
No, air can not be trapped in the cooler.
But, There was just another case where the aftermarket cooler was causing issues with the tractor, low flow.
It might be in your best interest of trying to get to the bottom of this issue, to bypass the cooler and test it.
Matoyan
b2150 and b2320
Oct 30, 2024
78
9
Rhode Island
I took the cooler off and no change. I mean maybe a little better in middle speed but no change in high speed.
Matoyan
b2150 and b2320
Oct 30, 2024
78
9
Rhode Island
Is there a spring and poppet in there? I think that's the orifice in the poppet you're showing in one picture.
Nope. Just what’s in the pictures. The WSM doesn’t seem to show a spring for the flow divider assembly. Unless it’s in the middle of the assembly but I can’t get it apart. They bend some of the edges to prevent it from coming out. IMG_9367.jpeg IMG_9366.jpeg
4,030
2,484
Nope. Just what’s in the pictures. The WSM doesn’t seem to show a spring for the flow divider assembly. Unless it’s in the middle of the assembly but I can’t get it apart. They bend some of the edges to prevent it from coming out. View attachment 153342 View attachment 153343
Ah ok, I was wondering why it stayed together. Yes the spring and poppet are inside there, looks like the poppet is brass? With no flow, the bottom holes should be blocked by the poppet. I can't really tell from the pictures. Is the orifice hole open and clean? Can you stick something in the bottom to compress the spring and make sure the poppet is free to move? When you reassemble it, I'd use new o-rings. If it still doesn't work, you could remove the line to the power steering/hydrostat, start the tractor and measure the flow- should meet spec.
I think there's a relief valve in the transmission that could also cause the problem. I'll go look.
You may be the victim of wear. Without re-reading everything, you changed the filter? Did you notice the transmission working better with the engine revved up? How many hours on the tractor? Maybe ready for a new pump?
Matoyan
b2150 and b2320
Oct 30, 2024
78
9
Rhode Island
I was able to compress the spring and I did clean the whole assembly, as much as possible since it doesn’t come apart. I changed the o-rings and sadly no change. The only thing I noticed is that the holes on the top row don’t all align up with the inner “thing” where all the holes are open.
4,030
2,484
Can you remove cap 1 and catch the flow to measure it? Should be 1.3gpm.
ruger1980
L4310 w/La682, L225
Oct 25, 2020
593
259
CNY
Does your power steering function properly? Doe sit steer easy and quickly or is it slow and hard to steer?
If it steers fine then the flow to the charge circuit of the Hydrostatic drive is most likely fine. Unfortunately it is not that easy to test charge pressure with this setup. You can only test high and charge pressure in one direction at a time unless you have a digital gauge that can measure both low and high pressures with reasonable accuracy.
Matoyan
b2150 and b2320
Oct 30, 2024
78
9
Rhode Island
Power steering is working as it should. It did start leaking some fluid from the steering wheel, but that should be an easy seal replacement.
ruger1980
L4310 w/La682, L225
Oct 25, 2020
593
259
CNY
Then chances are you have sufficient flow to the Hydrostatic unit. You really need to check charge pressure in neutral and when trying to propel the machine. That will tell you if you have excess internal leakage.
