Electrical - Wiring Diagrams
Lafarms
M9540, L3830
Jan 23, 2025
Lower Alabama
New to the site. Needing A wiring Diagram for a l3830. Mainly the tach input from alternator. Auction buy tractor says enough. Thanks
11,036
It really helps if asking for a electrical diagram that you include the EXACT sub model you need it for, A GST Cabbed does not have the same wiring as a DT ROPS. šŸ˜‰
Also that tractor doesn't use the Alternator for the tach, it uses a RPM sensor.
Lafarms
M9540, L3830
Jan 23, 2025
Lower Alabama
Dt rops. Ok thanks, I was told that it read from the alternator.
11,036
I don't know of any Kubota's that have ever used the alternator for the tach signal.
Most of these older models used mechanical tachs.
Newer models used engine sensors.
6,285
I just did a quick check of the BX1870 WSM (WorkShop Manual) and the schematic-diagram in in there.
HINT: The WSM has THREE parts.... look in part3
that's really just the connections to the cluster, not the schematic. A proper schematic would have parts listed, interconnections and CPU pinouts..... something any tech needs to troubleshoot and repair the cluster.
11,036
Im looking for the safety switch controlling the high/low range on a M 120
I think the answer is a lot more complicated that just "it's right here" answer.
Read this thread, any similarities?
You need to get yourself the WSM (aka Service manual).
Roberto160
Poland
Dzień dobry czy ma ktoś może schemat instalacji elektrycznej Kubota l1511 dt special
Mod add:
Good morning, does anyone have a diagram of the Kubota l1511 dt special electrical installation
11,036
Mod add:
I don't know of a L1511 WSM (Service Manual) available.
I will send you two tractor manuals that will have similar wiring, Look at colors of the wires and where they end up to compare.
Nie znam dostępnej instrukcji obsługi L1511 WSM.
Wyślę Ci dwie instrukcje obsługi traktora, które będą miały podobne okablowanie. Przyjrzyj się kolorom przewodów i ich końcowi, aby porównać.
Roberto160
Poland
Okej dziękuję
Roberto160
Poland
Jak możesz to wyślij jak najszybciej będę bardzo wdzięczny
Alex Nelon
ZD1211 72, L2501
Apr 8, 2025
North Carolina
"Diagrams may vary depending on the Exact model, serial number, region and options equipped"
Hopefully those looking for an electrical-wiring diagrams for a given tractor can find them here.
Those that are willing to share, please make the POST TITLE that starts with the tractor specific name:
The reason for the specific post title - IF a person wants a diagram on B7100's - then hopefully this will be included in the search.
I.E.
B7100 Newer version (B5100,B6100)
And then clearest picture possible
Looking for a wiring diagram for ZD1211, specifically the instrument module and hour meter
HutchinPa
Kubota B2620
Apr 29, 2025
W Pa
Hello newbie to the forum. I bought a used B2620. Had an issue with it not starting eneded up playing with the forward/revers pedal and now it starts. Had lots of hay dust and such so i power washed it. Now the glow plug and battery indicator lights come on but when i try to start it just clicks and the lights go off. Took the negative batt terminal off wait 30 seconds put it back on and dash lights come back on. Try to start click they go off. cleaned all terminals and neg batt ground still same issue. Thoughts?? Thank you
HutchinPa
Kubota B2620
Apr 29, 2025
W Pa
I have not replaced the battery as yet because it was starting fine right after the power wash. I did replace one of the battery connectors. It`s almost as though removing the Neg batt terminal is allowing something to "reset" I was thinking timer relay but i may srat with all grounds first
