Electrical - Wiring Diagrams
fastbob
L4600HST
Jun 8, 2025
Kansas
"Diagrams may vary depending on the Exact model, serial number, region and options equipped"
Hopefully those looking for an electrical-wiring diagrams for a given tractor can find them here.
Those that are willing to share, please make the POST TITLE that starts with the tractor specific name:
The reason for the specific post title - IF a person wants a diagram on B7100's - then hopefully this will be included in the search.
I.E.
B7100 Newer version (B5100,B6100)
And then clearest picture possible
I own a L4600HST ROPS and have since it was new. Today it decides not to start. No clicks no nothing. Battery is good and terminals are spotless. Fuses are all good too. If someone has an electrical wiring diagram, I would greatly appreciate a copy. Thanks
Paul in Paragould
Many but my new buy is a Kubota L175
May 28, 2025
Paragould, Ark. USA
I have spent the last year trying to find a wiring diagram for an 50 year old L175. I have three books that should cover it but the last pages are missing in all three. Thanks ahead of time if you might have it.
Mr Haney
L3710, ZD326S
May 23, 2022
422
116
FL
ZD326
This is a datasheet I found for anyone who wants to fiddle with their controller and use something else to run the relays. It applies to all three relays connected to the controller. The version of the relay Kubota uses is SPDT with 5 pins and runs on 12V.
This is a standard automotive relay you can get anywhere for under $10.
The manual has an error. It gives the wrong figures for testing the relays. Here is the correct info:
Resistances:
85-86: ~90 ohms (coil)
87-87A: infinite
87-30: infinite
30-87A: 0 ohms
RHR
MX-5200 KX-71-3 ZD21F-60 Cat D5K2 Cat 324E L
Dec 14, 2021
55
TEXAS
Does anyone have a wiring diagram for the thumb controls on a KX71-3S?
I have the service manual for the KX71-3 but not the S series.
Hugo Habicht
G1900
Jun 24, 2024
1,542
2,238
Ireland
Hello,
I am looking for schematics of an L1421. A friends tractor is not starting and I will have to look at it tomorrow. Any help would be appreciated.
Kind regards,
Hugo
CottonValley
SVL 95-2S, KX-040, M110GX, M5400, ZD331
Nov 19, 2018
Tuskegee, AL
Does anyone have the wiring diagram for the SVL-952-s? Dealing with error code 028 so I am assume rodents got my accelerator wire somewhere.
whatsupdoc
L3302
Jul 9, 2024
180
208
I want to add a fan and a rear camera, does anyone have a L3302/3902
wiring diagram.
Ragnorok
B2150HST, B7100D
Mar 6, 2025
New Hampshire, USA
Hi I'm looking for a wiring diagram for a B2150. Big thanks in advance if anyone can share.
I'm looking for one of these as well, HST if it's that specific. My dash is dead ... lights below are fine. Also doesn't shut off properly and the lights don't work. Since I have to rip this thing in half to put in a clutch I should have about all that stuff off as well, then I can fix it when putting it back on. Wiring diagram would make that a bit simpler.
I did look at each and every link's name and even looked at the B2300 one but the instrument cluster isn't right.
Thanks for your time...
11,321
modle z482-d2-ef08 motor yer 2018 0.479 l made by kubota it a gen 8-18 kw i need a wiring diagram
on the motor please
You will need to look at whoever manufactured the generator as they would have made the wiring harness for it.
copper creek
L3830
Jun 7, 2026
ME
Does anyone have a wire schematic for an L3830HST? I've lost all power. No dash lights. Replaced the ignition switch, all of the fuses (both sets), new battery, checked the safety switch under the seat, swapped the relays above the battery...
