Fixing hole in side of block
Status
Not open for further replies.
Jim L.
886
181
Thinking that while waiting for seals to arrive it would be good to read up about seal and o-ring tricks - such as using hot water to make some seals more flexible - and how to not cut seals while installing.
joesmith123
L295DT, BX1500
Mar 18, 2023
296
140
earth
disconnect your leaky cylinder, keep shaping your realm with one bucket cylinder functioning
your machine fully stuck in the dirt, completely empty from leaking all the hydraulic fluid
you can wait around and do other task while waiting for one seal, OR
put you plugs on the leaky cylinder so no fluid can go to it and it is open to move, fill it back up with hydraulic fluid,
go shape you your realm with one bucket cylinder, just dont lift no crazy dirt and break your other cylinder
yes you can do other task and play it safe, but no other task feel as important as shaping your realm
your gonna let a little seal stop you from shaping your realm?
your exact plan: take off both hydraulic line that go to your cylinder, plug them with regular 1/2 plumbing
from what I recall, 1/2 inch plug should seal up your jic 8 female swivel, please let there be plugs that work in your junk pile, but you still need to go get hydraulic fluid
before getting the hydraulic fluid, make sure you have plugs that fit into your jic 8 lines
definitely a bad idea but give it a shot
go you through your random plumbing, find you something that will plug regular 1/2 inch house plumbing
No, regular 1/2 house plumbing does not thread into jic 8 female
Take you a hose with you to part store and get you 2 plugs to stop fluid at that cylinder
12 dollar just for 2 fitting to plug your hydraulic lines
cheapest hydraulic fluid available: 61 dollar from walmart auto center
plug you both lines, add you 3 gallon hydraulic fluid
go shape your realm not using the bucket cylinders, only lift cylinders
while waiting for the seal, you are still able to carve earth without leaking your hydraulic oil
just dont use your leaking cylinders, and your system will hold its fluid
who care if you cant control your bucket? use your massive lift cylinders that are not leaking and shape you that realm
icing on the cake: you actually like the bucket flopping around, it has a self leveling when going backward draigging earth down
unbelieveable
ok here you are shaping your realm with just a couple good cylinders
you actually like the bucket flopping around, grades real nice going back and forward,
and you are holding your hydraulic fluid
with just a couple good cylinders, L295DT still shapes your realm better than skid loader
here you are shaping your realm with only a couple good cylinder
and you prefer the bucket flopping around
so glad to have the fatty meat, go heat it up in its oil on low heat while shaping your realm
name you something that will heal your heart more than those 2 activities? you cant
you thought you had a problem with your leaky cylinders, no you found a solution, unbelieveable
nature handing you another gift: you gave up on this bolt, somehow the bolt line up and you got it in there with threadlock,
hold you that robot together with might
both of your magic trick holding
accept you the gift nature hand you, turn you a problem into solution like you did today
Chanceywd
Mar 26, 2021
860
858
central ny
Well the next chapter in this tale of woe might just be " robot loader frame twisted from unequal forces",
But I could be wrong.
L35
Jun 13, 2010
710
829
CT
The place is really shaping up Joe, should be ready for grass in no time. keep up the good work.
joesmith123
L295DT, BX1500
Mar 18, 2023
296
140
earth
fix your shop
your shop still not leveled, get you everything off the ground, move to edges, move your home
lift other L295 with your current L295 and put it furthe away, move all the engine parts for that build away
plane you out your shop
you hate cleaning your shop, you complain while doing it
lift your other L295 chassis using your L295 loader with chains, setup pallet area and move all engine parts with it
clear you out the way, make you perfect strides and your shop will increase in value
favorite new tool: drag you around all your item using your 4 wheel dolly on a strap that you pull
moap you around your shop with less effort, moving all item until your machine can grade that realm
lug you around your other L295 pile of part, with less effort using your 4 wheel dolley
today you are not thinking, you are lugging your realm around with mininal effort, just like your L295DT
lug away your other diesel engine in parts away from your shop,
only when you lift the block do you realize how it can create enough power to lug around your realm
chain up your other L295 to lift
get your L295 loader above it, lift it up and move it to close to fence
you almost flip your tractor trying to lift your other L295 chassis
you can see the wheel off the ground, you had to drop your chassis
you thought your tractor can lift the chassis, no, what is in that chassis that is so heavy?
new plan: lift up one side at a time, get your 4 wheel dolly under it, strap it to the chassis, then
drag around the whole contraption using your loader and get it on a pallet somehow
lift one end of your chassis, get your dolley under it
joesmith123
L295DT, BX1500
Mar 18, 2023
296
140
earth
spend you couple hour moving L295 chassis with another L295
got your chassis on your dolley, put a strap
move around your chassis with your loader
Cover your other diesel engine with pickup truck bed liner
Finally, 10 hours of moving stuff
Your L295DT ready to build your shop
joesmith123
L295DT, BX1500
Mar 18, 2023
296
140
earth
Build you a shop
L295DT building you a shop, so she can have her brother come back to life
she start right up, you can shut her off and turn her as many times as you like,
judge you your engine temperature looking at oil pressure, you dont need no thermometer
Get you some gumption. Apply it with intent.
yes, soak you in that mannerism, apply it to your narrative
That is for sure.
And if he would not be so advice resistant he could do it in half the time and with half the money.
yes i listen, you saw the other D1301 engine that need to be built?
tell your helper to hold your beer, your fixing to build that diesel engine in one shot, no leaks, purring
Your favorite thing about L295DT
run your throttle low, let you that diesel lug around your realm, if it start to bog, hit you this throttle and lug you through the bog
Your L295 building you your shop
your realm change shape when diesel engine purr
50 something page into thread, your L295 building a shop so you can revive her sibling, wow
L295 lugging earth planing out your realm
move you serious earth, low gear 4 x 4, bucket fully down going downhill
JRHill
Orange: B7100 Std and Woodmizer; Green/yellow JD Buck, Gator and 410j.
Apr 26, 2016
283
235
Wahkiacus, Washington
This thread.... A bad memory. I rebuilt a 230 Chev 6 cyl and adapted it into a '51 Chev sedan (turtleback) and all was good. Excellent if I can say so ;) But that late fall morning when the temperature dove to single digits and I woke up realizing I had straight water in it. Yup, it broke the block right in the middle - a 'C' shaped fracture about 6" diameter if a full circle. What good are frost plugs, really? A fresh rebuild darn it.
I was getting to be a pretty good welder by then. On anything. Arc, TIG, torch, you name it. "I can do this" despite all the nay sayers saying it couldn't be done. Every time regardless of what I tried, preheat the whole block, whatever, as soon as the block cooled it would open up again. Often right behind the repair as I was doing it.
I'm really happy for someone that actually had success at welding a casting of iron. I'd never do that again but I tried.
6869704x4
L45TLB, 49 8N, 57 641, RTV-X1120D, Z422, CanAm Outlander 650
Jun 29, 2011
396
541
SE, NM
Slight hijack.
I'm enjoying this thread. One of the reasons is it reminds me of my brother and myself rebuilding the engine in my dads 71 Datsun pickup. Pulled the motor using a chain strung between two trees. Our shop was a canvas tarp, the floor looked like Joes. No power, had to carry the bare block to the back porch so we could plug in the drill for the hone. Got it back together and I smiled when it fired up. My other younger brother inherited it and drove it for about four years until he rolled it. Came back over on it's wheels and he drove it home and parked it.
Anyway. keep at it Joe.
11,133
He did not weld the cracked block, he epoxied a patch in it!
POST # 360
Status
