Fixing hole in side of block
Status
Not open for further replies.
7,564
Joe, all that cleaning of parts, then you paint that engine Japanese taxi blue? Man, Ford grey is easy to find and would be easier on the eye!
5,186
I actually LIKE the "Japanese taxi blue".
It is only a paint color.
The real issue:
Will it run, and...
If so,..... for how many hours?
joesmith123
L295DT, BX1500
Mar 18, 2023
296
140
earth
Hand sand head hardware
Bucket of diesel, hand sand all crud, especially off the top of bolt, 1000 grit sand paper, then dip parts in part cleaner
Forgot to install those 6 small cylinders, took head off installed them, now put head back on
Rhythm: dip hands and bolt into solvent, dip end of head bolt in some clean grease, hand tighten
Per diagram: they call for stud with plain washer for front and rear of head
Do I have head studs in proper location? I can't find the right washer for that rear stud, I might put spring washer then that big washer
Up close of what I had torque wrench set to, they call for for 58
That bolt when I had split washer, would tear through split washer, had to go find regular washer and finally tightened it to spec
Cleaned phaser, figuring out how it goes on and the hardware, look at diagram now
Almost forgot these little caps go on top of spring
Tightened phaser bolts to 15 foot pound
Moving slow trying not to forget any hardware
I read yalls statements about washers, yes they do seem a bit off
Up close of diagram: they use 190, 190 is PLAIN washer, not split
Either I mixed the parts or it was installed improperly
Soon I go search for plain washers and just use those, and maybe take off those big washers if they are blocking the head cover
Jim L.
878
178
By the way, it is critical to tighten head bolts in sequence shown in WSM; do them in stages; and have the bolt threads oiled. One of the few places that really need the torque wrench.
dragfan66
B7500 Z231KW G1800 L3350DT
Apr 12, 2020
65
74
Alabama
Make sure those washers you are using on the head studs don't interfere with the valve cover and gasket installation.
hagrid
K1600GTL, ZX-14R
Jun 11, 2018
1,156
1,747
Pittsburgh
I am leary of this washer business. Definitely opposed to lock washers.
joesmith123
L295DT, BX1500
Mar 18, 2023
296
140
earth
Yes I now fix the washer situation
Bolts from other engine, take the washers from them, remove all split washers from head, replace with plain washers
OK yes, went back and took out head bolts that had split washer, replaced with washer from other engine, torque everything again to spec
Put phaser back on, don't forget any hardware
yes, installed phaser torqued to 15
My instinct say: give it thick coat of clean diesel, hit it with torch, then spin it by hand applying diesel periodically, keep spinning it, fill it with engine oil half gallon, give power to starter
That should pressurize the engine oil and lube everything, correct?
The way it sit, if starter engaged then oil should shoot vertically through the phaser?
Then dump that oil out, and put in new engine oil for first startup
Video: spinning engine by hand, anything sound wrong? Feels fine spinning
Fill it with half gallon engine oil, give 12 volt to starter...
Poured whole gallon oil into engine using funnel
First test with starter
Now: get bx1500, run jumper cables, do 2nd test
2nd test with more power: shot oil out the side
Put hardware on that hole and run another test trying to make it shoot oil out the top
Up close of diesel and oil mixing coming up from bottom of engine
3rd test, oil gushing to top
Now: close up engine more, do compression test
Close up head do compression tests
None of the fittings fit tight into block, might put plumbing tape if it leaks
Put plumbing tape, ran compression, sits at 250, staying still after 10 minutes
Cylinder 3 won't make it past 140 psi
Cylinder 1 almost at 275 psi
Diagnosing cylinder 3, why compression low: I did not put new rings on that piston, it is the original piston from this engine, 500 hours, there are brand new rings on piston 2 (275 psi) and piston 1 (290 psi)
The engine head has no damage, could it be the adjustments on the phaser? I think it has to be the piston rings
First, get a proper fitting that fits that hole, either make your own or find the right one
MountainMeadows
Jun 6, 2022
220
290
Poconos, PA
Cylinder #3 had the most rust and corrosion around the valve seat area. Did you use the valve grinding compound to lap in the valves? If you had, you would have most likely discovered the valve sealing area was compromised and one possible cause for low compression in that cylinder.
5,186
Shade tree rebuild looking not good!
Vlach7
L47 305DT JD500C
Dec 16, 2021
452
329
Frazier Park Ca
Joe, if the pistons went in comfortably tight, your valves are adjusted, and that was a wet test, it sounds like your valves are not seated adequately. You need to get the compression within 10% of each other. You put in new valve guides?
dragfan66
Apr 12, 2020
65
74
Alabama
Here is a thought that just popped into my pea brain, might work though to address the compression issue on number 3 cylinder.
Back off both rocker arms until there is no contact with the valves on 3.
Spin the engine over with compression gauge installed and see if it builds pressure then.
If the valves are truly seated and lapped in, I wouldn't think that cylinder would build any pressure, or maybe build pressure but not leak down.
Like I said, I have never thought of that concept until just a minute ago.
joesmith123
L295DT, BX1500
Mar 18, 2023
296
140
earth
I know it is a bit confusing, the head you are talking about is the damaged head with 2500 hours, this head has 500 hours and no damage, this head was cleaned on page 4 or 5 of this thread, NOT the one more recently cleaned
You just proved that you read my statements
I didn't see where he adjusted the valves.
I dont know how this is done, I need to watch video and comprehend
I keep studying your statement until I understand what you mean
Piston 3 was the EASIEST to get into the bore, it did NOT have new rings
I don't think he did.
Just slapped the valve train on as it was.
I still suspect valves and seats though.
Yes you are correct I just reinstalled it, those valves and seats are perfect, if I had better internet, I would go back and get you the pictures
Yes, I keep reading these statements until I comprehend
The gauge stays at the peak pressure until you hit the reset button. It's not a leakdown indicator.
Yes I realized that later after reflection
Diagnostic plan for low compression on cylinder 3:
First, find out the thread pattern of the glow plug, and get that exact fitting. The way I had the fittings in was BARELY holding on, it would not thread in, it would get stuck instantly. the thread is M-(number) and I show picture soon showing the kit has M-(number) matching
Then next thing: learn how to adjust valves, see if you can get high compression
Last resort: drain the oil out, take off oil pan and head, pop out piston, put in new rings
Lesson: ALWAYS change rings when you have pistons out (I even have new rings but was just being cheap/frugal)
Data sheet for chinese compression kit: I need to find exact thread of glowplug and make sure it match with the fitting
New rings: should have put them on piston 3, big mistake
Video: bx1500 knocking, pay attention to the sound it make when shut down. Last night, when charging the battery to do the test on the engine, bx1500 started metal clanking sound, I was far away and it was noticeable. I run and shut down bx1500. I share with you the sound
my suspicion: a knock, connecting rod bearings are loose
It is a sign from nature, to kill one engine and revive another (hopefully)
But at this moment, all 3 engines are broken/incomplete
No worries, I will not run bx1500 at all until fixed, not trying to fix another hole in a block
yes yes I listen to yalls statements, first I let them marinate and we come up with plan
Now: look up the specs of the glowplug and see what the exact thread is and get a fitting that would be tight, then do compression test again
100% wrong thread, dark part of fitting as far in as it goes
Paint showed up, hopefully it match
Instructions: "thin it using naphtha" if spraying it with airless sprayer
Tried all kinds of combinations with air fittings, cannot get anything to thread into block reliably
yes, i search through this forum, @D2Cat said it is M10-1.25
Now, I search for a kit that has this exact thread, AND a gauge that goes up to 500 psi (they call for 450 psi per the spec sheet)
@Ktrim said: "backyard valve job" - yes, I will look into how to do this
Summary: get the right compression kit m10-1.25 that goes up to 500 psi, watch videos about adjusting valves, come up with plan to paint the entire chassis/engine in one shot (if possible)
shoot ideas from the hip about how I can paint the entire chassis/engine in one shot after getting the compression problem solved
Paint plan: take all panels off tractor, leave the back wheels on, clean the entire thing with the usual methods, then spray entire chassis including engine with the enamel paint
Here is a kit, that has the m10-1.25, and goes up to 1000 psi, $40
look at this guy adjusting kubota engine valves
Simple: put in the flat metal that they call for, twist other side with flat head, and tighten down on the right thickness flat metal, now I gotta find out what thickness metal they want
Per spec sheet, they ask for 0.009 inch "valve clearance"
I can get this tool from harbor freight? I check now
feeler gauge: it has 0.009 inch thickness for this task
Spun engine to make valves level
.009 feeler gauge
Plan: loosen nut on right, put feeler gauge, tighten the screw with flathead, take out feeler gauge, tighten the nut
Adjusted valves: let me know if they look fine
Cylinder 1: 300 psi
Cylinder 2: 300 psi
Cylinder 3: 175 psi
I guess take out top and bottom, pop piston out and put new rings
Cleared area, took off head
Drain oil, remove oil pan, remove hardware, pop out piston
Took out piston 3, I point to new gashes in connecting rod from hitting crank
As it was coming out, it was twisted a bit, take connecting rod from other engine, use that connecting rod
5,186
First, find out the thread pattern of the glow plug, and get that exact fitting. The way I had the fittings in was BARELY holding on, it would not thread in, it would get stuck instantly. I swear the thread is M-(number) and I show picture soon showing the kit has M-(number) matching
"take off oil pan and head........"
And, of course,......reuse head gasket?
Ktrim
Dec 23, 2020
444
369
Nazareth Pa
Easy to go in maybe a dead give away!!!! Always new rings when they are removed. And at least a back yard valve job to be sure. Again no one I know has eyes like a micrometer.
Hugo Habicht
G1900
Jun 24, 2024
1,534
2,199
Ireland
Hello Joe,
take the injector out and put a tiny bit of oil into cylinder 3. Turn by hand first if it runs freely, then do compression test. If compression is good it is the piston, if it is still bad it is the valves.
Maybe you can get the oil in through the intake or exhaust port.
Kind regards,
Hugo
joesmith123
L295DT, BX1500
Mar 18, 2023
296
140
earth
Cylinder 3 fixed, now has 300 psi
New piston, new rings, connecting rod from spare engine
Ready to go into bore
Installed piston with large hose clamp
Put top back on for compression test, now all 3 pistons have 300 psi
Status
