Old_Paint
Dec 5, 2020
2,039
2,308
AL
Hooked up the itty bitty trailer and hauled the chicken brooder out to the compost heap for a cleaning. Put all the chicks in a box and took them out to the run at Cluckingham Palace and then turned the compost heaps with the grapple. The baby girls did NOT like the tractor. (Compost heap is right behind the coop/run). Came back to the house and realized we could not see Cluckingham Palace from the deck, and we want to keep an eye on the girls because theyare only about 3 weeks old. So I got out the pole saw attachment and extension and turned the weed eater into a pole saw. Cut what I could reach, then got the MPS(Manual Pole Saw) and pulled down a few more small limbs that I could use the lopper for. Piled up all the trimmings and then took them out near the chip pile (just past the compost heaps) This time, the only Ameraucana in the flock (3 Barred Rock, 2 Rhode Island Reds, 2 black Australorp, and 1 Ameraucana) hopped on on top of the feeder and watched the whole process of hauling off brush. The other 7 were all huddled in the corner of the run again.
All this started with the bright idea of giving the girls a day outside while we cleaned the feeder and waterer. If there’s anything the missus is good at, it’s job expansion. Without the tractor today though, we would still be struggling in 90+ degree heat and 80%+ humidity. She’s glad I let the lX follow me home a few years ago.
Cluckingham Palace from the deck:
The girls are too small to see in the photo.
Reactions: 6 users
Josie M6800
M6800S 2005 with Cab
Aug 18, 2024
Sat on my M6800S and cried, just replaced my cab a/c, then had to replace Hyd pump, now clutch is hard to press down, dont know what to do now!!
  • Sad
Moose7060
Oct 14, 2023
827
2,243
bc
Took the L3902 a hundred yards down the road to a neighbors. They asked the other day if I would mind brushcutting approx an acre of overgrown yard. Grass was about 3-4 feet and some willows 6-8 feet but not overly thick. Went slow as it was somewhat bumpy, but no rocks or stumps. Took about 2 hours and they were very appreciative once I was done. Got fed fresh out of the oven muffins and hot coffee, even left with some pocket change I tried to decline. Forgot my phone so no pics.
Reactions: 8 users
lynnmor
B2601-1
May 3, 2021
1,797
1,605
Red Lion
What I really like about this site is all the knowledge and if someone sees something wrong in your post, they respectfully let you know (well maybe @SidecarFlip was an exception).
Thanks @lynnmor for questioning the bolt length in post 19,502. I got ahold of parts schematic and used sharpie to trace the bolt. Bingo - been ordering the wrong bolt for 2-years. Since I hadn’t removed 2 of the bolts it looks like whoever installed the subframe used the wrong side bolts for that piece too. There is a L and R and they are different lengths.
Here’s before and after. This explains why I was stripping bolts, not enough bolt into the nut when torquing to specs.
Thanks to everyone that commented and kept my brain thinking.
Big help but I would go another step longer, that would assure that you gain the last bit of strength and leave a margin of safety should a bolt begin to loosen. Bolts can be bought at numerous places and perhaps for a lower price, just be sure they are the same grade.
Old_Paint
Dec 5, 2020
2,039
2,308
AL
Just goes to show that sometimes it ain’t the length of the bolt, but maybe it’s if the bolt is in the right place.
Siesta Sundance
Oct 23, 2022
1,835
2,545
youtube.com
It's gonna be hot week here with the heat indexs hitting 115*.
When I stop sweating, I stop shreddin with the tractor, that means the humidity has burned off. I run into higher risk of starting a fire. If I get off the tractor to move or retrieve an object, the seat will heat up to over 150* in less 2 minutes. Finished my gallon of water before noon, I'm done for the day!
Reactions: 6 users
g_man
Feb 3, 2023
386
1,806
NE Vermont
I been moving wood into the shed between rain events lately. It wasn't a very good summer here for drying wood with all the rain and high humidity. But still, I am amazed at how dry it actually is compared to last April and early May when I split it. Not ready to burn but another summer in the shed will fix that.
Have to use the L3010 with the 5' bucket to get through the opening and reach into the rear of the shed.
gg
Reactions: 9 users
g_man
Feb 3, 2023
386
1,806
NE Vermont
Yikes ! No way I could handle that,
gg
6,670
The main rowed up, then abandoned for 5 years or so, field we recently picked up from a developer was a self propagated meadow, which was fine with us, but being rowed up and having a swale near the middle that eroded into a less than preferable ditch was making it quite difficult to bush hog, walk through, or drive through.
Had been planning to borrow my brother’s almost new 7’ double gang disc harrow to flatten it, but he’s a couple hours away and with appointments at Mayo in FL and life in general, a day trip to pick up a disc harrow was getting to be harder than it probably should be.
Since there wasn’t a lot going on today, spent a half hour with the forks digging this thing out of the back of the shed where it had a variety of stuff piled on it. When I was a kid, we used this thing in the garden and a couple of small fields. Other than driving with a carryall, it was the first implement I recall running. I could be wrong, but I don’t think it has been out of the back of the shed in at least 30 years. I haven’t used it in almost 40 years. IMG_2977.jpeg
Covered in spider webs and unidentifiable gunk, but the axles still spin free and there’s something left of the discs. Hit it with the pressure washer a little bit and wire brushed the rust off the lift pins. The board on top is U bolted on to provide a tray for weight. The scrap metal, I don’t recall using but it adds weight as well and it was there so I left it. Put a total of 70’ of 3/8” chain and 16’ of 1/2” chain in a steel box and strapped it on the weight tray. IMG_2980.jpeg This was the before. Hard to see exactly how ridged up it is with the way it’s grown up. It is actually pretty rough. I bush hogged it once earlier this year. Had 10” to 12” stuff left in the furrows and 2” to scalping the ridges.
IMG_2981.jpeg Took me a couple passes to get it working right even though it’s about the simplest implement there is. First, it’s way undersized for the tractor. Started out running around 5 mph. Even with the extra weight, it was bouncing around violently and not cutting worth a crap.
First thought was, this ain’t working; going to need a road trip for a better harrow. Second thought was, 40 years ago this thing would have gotten it done and it hasn’t changed so far as I can tell so maybe I’m doing something wrong. That and all that bouncing around wasn’t agreeable with the weight arrangement.
So back to the shop for a redo. Moved the chain box further forward where there’s some blocking to assist the straps. Deleted the scrap metal.
Back to the field to experiment with speed. Did a decent job going really slow and doing some half lapping. If I heard the chains in the box rattling, that sound meant I needed to slow down. Far from ideal but I reminded myself the other option was a pair of four hour round trips so even if it was slow it was probably overall the fastest method. IMG_2982.jpeg
About 3/4 done a little shower popped up. Didn’t feel like it was going to last long so backed into the entrance to a short trail and spent about 15 minutes under the trees watching it rain. IMG_2985.jpeg
This is the after. No, it’s not done. Didn’t expect it to be after one cutting regardless which disc was used. The ridges are gone. The eroded places are leveled. The top couple inches of the red clay field are disturbed and, while moist, aren’t overly lumpy. Pretty pleased with it for a first cutting.
Allegedly no rain rest of this week. After the dirt and vegetation dries some, plan to cut it again with full angle on discs, probably at a 45 angle to today’s cut. Then a third cut at 90 degrees to today’s lines with discs at less of an angle and a drag chained behind the disc. For now that’s the plan.
Been a long time since I’ve done anything like this. It started to kind of come back to me as I got into it a bit. There was quite a bit of switchgrass in it already and it’s a native grass so likely that’s what will go back there. IMG_2983.jpeg
Reactions: 8 users
trevoroni
B6000
May 24, 2023
205
254
Used the B6000 to push the bottom of my brother's garage/shed wall back onto the concrete foundation.
Dug some holes in the process....
It was built in the 50's and didn't have any anchor's into the concrete.
There was a brick chimney anchored to the bottom of the wall and the weight of it bowed it out.
He removed the chimney and tinned the roof and wanted to true up the wall before fixing up the inside.
Reactions: 7 users
slamin81
KUBOTA B2301, LANDPRIDE RCR1248, LANDPRIDE RB1560, LANDPRIDE GRAPPLE SGC0660
Nov 7, 2023
41
68
austin, indiana
dang
Siesta Sundance
Oct 23, 2022
1,835
2,545
youtube.com
I'm gonna fill and top off the wildlife waterers today, extra salt/minerals for the cows. Yesterday at 4pm I measured the temperature of the shop concrete floor at 101* Items within the shop, atv, tool chest etc. was measuring 104.2* the galvanized metal on the shop was 126*
This week can't pass fast enough.
3,535
We have two, but it is because of the size of the home.
One cools the upper floors, one cools the lower floors.
On the rare occasion of a failure that can't be addressed right away, we have moved our activity up or down as needed.
6,670
That’s miserable for people and livestock. Today here feels like first day of fall. It isn’t, but it feels like it.
Siesta Sundance
Oct 23, 2022
1,835
2,545
youtube.com
Do folks in that climate have two AC's installed at the residence so they have a backup in that kind of heat?
No, but its best to have the extra AC disposals parts, like a contact switch, capacitor and hard/run start capacitor, those items are stupid cheap and can be bought off Amazon.
Siesta Sundance
Oct 23, 2022
1,835
2,545
youtube.com
Yup.
We're able to adjust by going to our RV or the other house. I also lived in East Texas(hurricanes) for many years, I have 1ton window unit & generator for power outage.
I've been thinking of adding a mini split to our bedroom/bathroom area, since our boys have moved off to college. No reason to cool the entire house when there is 3 bedrooms and bath is not being used.
Siesta Sundance
Oct 23, 2022
1,835
2,545
youtube.com
Heat wave headed your way on Aug. 25th. Pop the service cover on your AC verify parts, buy some spare parts, contact switch, capacitor and if equipped hard start capacitor.
Mitjam
Jan 14, 2013
348
420
Edmonton, Alberta, Canada
Man that’s unreal hot we had some 35-37C days in July I was in the tractor mowing but also some days running the wipersnippers it’s hard on everything. But we also had the coldest 3 days I have ever experienced in Jan at -50 with windchill absolutely terrible. Anyways hope you all stay safe
