Summit Hydraulics
7,285
Well if Summit made a kit then presumably they would use electric valves like they do with the other kits. I'm going to guess that the reason you ask is because the electric valves don't have a PB port, right?
Here's my attempt to diagram the plumbing for both backhoe on and off operation...this what you're thinking?
Backhoe ON
Code:
P ----> BH P
T <---- BH T
        BH PB ----> RR P
                    RR T ---> PB
Backhoe OFF
Code:
P ----> RR P
        RR T ----> PB
T no connection
I see no advantage to that.
Just run the tractor P line to IN on the electrIc valve and feed the backhoe off of the OUT port on the electric valve. You are done.
When.you remove the backhoe loop the backhoe feed to the tractor return exactly as you always did.
The remotes are in the circuit with or without the backhoe.
ejb11235
BX23S, Braber BBR4G 4'BB & LRM5G 5' rake, Redline 48" rock bucket, PFL1242
Jan 20, 2022
486
374
Seattle, WA, USA
Yeah, this is the way. I hadn't thought of that. This is great! Thanks! Ok, well maybe on monday we'll hear from the Summit folks.
gened14
Kubota B26 TLB, ZD 1211, ZG23, Allis Chalmers D17 series IV, Allis Chalmers 170
Jul 7, 2014
20
Tennessee
Last Sunday I installed the Summit 3rd function kit on my B26 and it works great! I should have done it years ago.
5,164
Hello DustyRusty, please contact our customer service line and they would be happy to take care of that claim for you.
Email: contact@summit-hydraulics.com
Phone: (602) 806-7173
I did call your customer service and they didn't have a clue as to how to handle this. I explained that it was purchased through Amazon and shipped by Summit and that it was past the return period. I also mentioned that I was instructed to call customer service by a post on OTT. Was told that it would have to wait till the "manager" came back from vacation. That was about 3 weeks ago, and not one email, or call.
  • Sad
Summit Hydraulics
Vendor Member
Hydraulic Kits & Components
Mar 2, 2023
68
82
Phoenix, AZ
Our Third Function Valve Kit for Kubota L2501, L3200, L3301, and L3901 tractors is a customer favorite! Experience the same innovation and quality trusted by thousands. Upgrade your tractor with our 3rd function valve kit today!
Summit Hydraulics
Vendor Member
Mar 2, 2023
68
82
Phoenix, AZ
Take a tour of our Phoenix, Arizona warehouse and see how Summit Hydraulics makes the parts that keep your tractor running smoothly. From our popular Third Function Kits to our tough Flat Face Couplers, we’re proud to show the quality and care we put into every product. Our goal is to help you work more efficiently on the farm with reliable, easy-to-use hydraulic solutions that get the job done.
Summit Hydraulics
Vendor Member
Mar 2, 2023
68
82
Phoenix, AZ
Summit Hydraulics Diverter Valves allow for a multiple function tractor so you can operate different attachments with ease!
These valves come in 13, 21 and 30 GPM so you have options based on your system's hydraulic pump flow. We also carry numerous DV switches like our joystick, maintained rocker switch, and momentary push button.
Watch as we take you through a quick rundown of our bestselling DV50 and DV90 Diverter Valve Kits, as well as the switches that operate the valve.
Check out our Diverter Valve blog for more information as well!
Summit Hydraulics
Vendor Member
Mar 2, 2023
68
82
Phoenix, AZ
Fall is here! As the weather cools off, there should be plenty of work that needs done around your property.
Consider adding one of our bestselling Kubota Third Function Kits to make Fall clean-up more efficient and easier! Add a grapple, mower, blade or snowblower to clear obstacles and clutter in less time.
Read more about their effectiveness and applications on our Third Function Kit Blog!
Summit Hydraulics
Vendor Member
Mar 2, 2023
68
82
Phoenix, AZ
Don't let the cold put a freeze on your productivity! As temperatures dip, starting your hydraulic equipment can get tough. Check out our short video for must-know tips to keep your machinery running smoothly in chilly conditions. From preheating methods to oil advice, we’ve got everything you need to stay up and running all season long! 🚜
BonnySlope
BX2380FEL, Add-A-Grapple, Box Blade, Rake, Rear Blade, HR12 Tiller, Flail Finish
Apr 11, 2021
146
126
NW Oregon
For those who wonder how the lines lay on my BX2380 here are a few. Showing 3 spool system with two rear remotes with feeder line to third function. Hydraulic lines-Tighty uo.jpg Hydraulic_Layout (1).jpg Hydraulic_Layout (2).jpg Hydraulic_Layout (3).jpg Hydraulic_Layout (5).jpg Hydraulic_Line-lay (3).jpg Hydraulic_Line-lay (4).jpg Hydraulic_Line-lay (2).jpg
Thought I'd added show a view of how the 3rd function line and connection went forward. SideView-mirrors (1).jpg
BonnySlope
Apr 11, 2021
146
126
NW Oregon
A little excess line on BX, which could be corrected. they come into contact when lifting implement. this may cause so premature wear on lines. I did let Summit know this with marked photos. and I also wrapped hyd. lines, enveloped with radiator hose to cut down on chafing, just a little extra protection.
Summit Hydraulics
Vendor Member
Mar 2, 2023
68
82
Phoenix, AZ
Summit Hydraulics
Vendor Member
Mar 2, 2023
68
82
Phoenix, AZ
As we are well into Fall, you may have some jobs on your property that need completed with your tractor. Enhance your Kubota's efficiency and make life easy with one of our Third Function Kits! The Summit Hydraulics Complete Third Function Kit adds another hydraulic function to your tractor without diverting fluid away from an existing implement.
Watch our new install video today to see how easy it is to install our kit to a John Deere 3038E! Subscribe to us on YouTube to stay up to date on new content dropping every week.
Summit Hydraulics
Vendor Member
Mar 2, 2023
68
82
Phoenix, AZ
When temperatures drop, starting your hydraulic equipment can be difficult. However, cold weather doesn't have to throw a wrench into your operations!
Watch our full video on essential tips to keep your machinery running strong in the winter. From preheating tricks to oil recommendations, we want to ensure you keep operations moving all season! 🚜
Summit Hydraulics
Vendor Member
Mar 2, 2023
68
82
Phoenix, AZ
Through March 17, we’re offering 15% off hydraulic valves, couplers, kits, and more at Summit-Hydraulics.com.
At Summit Hydraulics, we stand for quality, customer service, and solutions that work—because downtime isn’t an option. Whether you're running a farm, a job site, or a shop, we’ve got the parts to keep you moving.
Valves, couplers, hoses, kits, and more—ALL 15% OFF!
Shop now: Summit-Hydraulics.com
Use code: STPADDYS at checkout!
Trusted parts. Real solutions. Get what you need before the sale ends March 17.
11,757
That's awesome! I've been holding off ordering multiplier kits for for my tractors but not any more!
I have three sets of rear remotes on both tractors, but my intended use (thanks to @MtnViewRanch) is controlling an implement that has two or more hydraulic cylinders using one lever and a Sure Grip control grip. Happy St. Patrick's Day!
Summit Hydraulics
Vendor Member
Mar 2, 2023
68
82
Phoenix, AZ
Glad to hear that you'll be ordering some multiplier kits! They are one of our most popular products! :) Please let us know if you have any questions before ordering.
11,757
I placed an order yesterday for a 3 circuit and 4 circuit multiplier for the MX and M respectively. I also emailed the folks in Canada who sell the Scorpion grips to get a price on the S Series with a momentary trigger and two momentary buttons on the faceplate. I'll be able to control snow blower chute rotation and deflector angle with the same lever in the cab simply by pushing one of the two buttons on the faceplate and moving the lever. The trigger can be used for a third function such as to control a top hydraulic link or hydraulic lift rod link. Too bad you're not a dealer for Scorpion.
