Summit Hydraulics
torch
Jun 10, 2016
2,888
1,135
Muskoka, Ont.
What this world needs (or at least, my world) is a FEL joystick operated dual spool control block sized for around 5-6gpm, in keeping with the capabilities and capacities of the average SCUT.
The smallest controls can handle around 10gpm (Summit's smallest is 11gpm). Yes, a 10gpm can handle 3 gpm obviously but control is ticklishy sensitive. Smaller spool valves should provide a better graduation at low flow rates.
Ideally, the control would come with 4 position spool valves; adding Float to the boom circuit and regenerative flow to the dump at the 4th position of each. And offer the PB adapter as part of the package -- don't make me go hunt down the correct adapter.
I realize that Summit imports their valves (from Finland, IIRC?). But maybe your buying power has some influence with the manufacturer?
Just my 2¢.
Summit Hydraulics
Vendor Member
Hydraulic Kits & Components
Mar 2, 2023
68
82
Phoenix, AZ
summit-hydraulics.com
I placed an order yesterday for a 3 circuit and 4 circuit multiplier for the MX and M respectively. I also emailed the folks in Canada who sell the Scorpion grips to get a price on the S Series with a momentary trigger and two momentary buttons on the faceplate. I'll be able to control snow blower chute rotation and deflector angle with the same lever in the cab simply by pushing one of the two buttons on the faceplate and moving the lever. The trigger can be used for a third function such as to control a top hydraulic link or hydraulic lift rod link. Too bad you're not a dealer for Scorpion.
Hello, we will pass this info along to our Purchasing department. Thank you!
Summit Hydraulics
Vendor Member
Mar 2, 2023
68
82
Phoenix, AZ
Just my 2¢.
Thank you for the feedback!
11,757
@Summit Hydraulics, I received both multipliers this past Tuesday and will say that the quality of the kits exceeded my expectations. Those blocks are stout, and heavy! Packaging was top notch, and the only odd thing to me is the steel bracket that's included. Not sure I'll be using it, but if so, it might get incorporated into some custom mounting system.
Thanks for the 15% discount, and for offering quality kits to help us out. (y)
Summit Hydraulics
Vendor Member
Mar 2, 2023
68
82
Phoenix, AZ
Thank you so much for the kind words! We are glad that you like our Hydraulic Multipliers so much! Take care and please feel free to reach out if you ever need anything!
Summit Hydraulics
Vendor Member
Mar 2, 2023
68
82
Phoenix, AZ
Paul Allwood
Kubota B7200HSTD, homemade FEL, front flail mower, forks & ballast box, tiller
Jul 8, 2025
847
1,569
Baranduda, Victoria, Australia
Please let me know if this is not the right spot for this question....
I'm looking at modifying my homemade FEL and considering making it self-levelling. Do you supply a hydraulic self-levelling valve that might suit ?
Many thanks.
