What did you do to your Implement today
3,540
Looks like a flush is definitely in order.
billrigsby
Mar 17, 2015
1,050
247
Florissant CO USA 8213'
www.facebook.com
DONE :D
Gears look to be in good shape and no noticeable play
Just the requisite rust, considering what they have been sitting in.
Will probably do a couple more flushes,
there is a lot of area below the pinion gear that is not accessible without a tear-down.
And I see no need for that.
armylifer
Mar 26, 2013
2,322
1,079
Thurston County, WA
How do you plan to get rid of that rust? I am thinking that as long as you have the gear box torn down that far, would it be easy enough to replace the bearings? With the kind of rust that you have in there I am sure that the bearings have to be pitted.
7,323
Only my gut talking, but I'm with Bill on that one, and use it the way it is.
May not last forever, but a lot better than it was.
3,540
That would be my feeling also. Not perfect, but we're talking bush hog, not space shuttle. Probably only last another 20 or 30 years.:D
billrigsby
Mar 17, 2015
1,050
247
www.facebook.com
Yes, I am going to run with it as is,
Everything feels good and looks good.
Once the cover is on I will never see the rust again.
AND
There will be loads of anti seize used in reassembly so to
dismantle will be a breeze in the future.
billrigsby
Mar 17, 2015
1,050
247
www.facebook.com
Brush Hog rebuild update,
Over the last few days I have done some paint removal in two stages;
1 with a paint remover...
2 with the wire wheel...
Today I did a light coat of Rust-Oleum Rust Reformer...
And a coat of Epoxy primer...
Also got most of the ancillary parts primered and painted...
billrigsby
Mar 17, 2015
1,050
247
www.facebook.com
Lookin' good Bill :cool:
Thanks, it is coming along, the nice weather here helps :D
Got the three point assembly painted and put together
A fresh coat of color on the deck, (yes it should be RED), but this is not a restoration, all my implements will be ORANGE :p
And the assembly begins.....
Last bit will be the gearbox, blade assembly and decals.
billrigsby
Mar 17, 2015
1,050
247
www.facebook.com
Drive shaft lubed, assembled with new zerks
Blade pan de-rusted, primered and painted
Added a washer at the bottom and top of the fork tube, do not see why it should be metal to metal?
Wish I could have found a 3" one for the bottom
Replaced ID tag
Next the gear box and decals
billrigsby
Mar 17, 2015
1,050
247
www.facebook.com
Today I got the gearbox painted, photos later perhaps. But I noticed something actually a couple things,
I was surprised that the 4 bolts for the top cover were metric,
while I was cleaning off all the gunk I noticed the gearbox was actually made in Italy for brush hog.
I also noticed I've been calling this thing a brush hog it is actually a BUSH HOG, gar-dang, don't I feel stupid.
Well anyway no help to my stupidity this thing will be assembled tomorrow!
Bill Rigsby
Florissant CO
1972(?) KUBOTA L-1500-DT
Great Bend M10 48" Front End Loader
Bush Hog 48 (SQ48R-3) "Squealer Mower"
Atlas 48" Landscape Box
48" Harrow Rake
Rhino 60" Rear Blade
4 Seasons haul-all Dump Trailer
Draw Bar with 2" Ball
28" Fork Lift Forks
Sent from my Samsung Galaxy S7 using Tapatalk
hodge
Nov 19, 2010
2,960
531
Love, VA
I compounded a finish mower that I just bought. It is a Woods RD60, that was originally Kubota Orange. It had faded to an unsavory pink, so I cleaned as much of the oxidation off that I could. It looks well used, but at least it's not pink!
billrigsby
Mar 17, 2015
1,050
247
www.facebook.com
Gear box all painted and ready to be installed
(NO that is not Bronco's Orange and Blue, my Black paint was dried up) :rolleyes:
New safety decals installed
Found a rubber plug to help keep some water off the blade pan
BEFORE
AFTER
All new hardware, paint and decals.
Blade assembly re-installed with plenty of grease and anti-seize
With the weather still nice I may have time to do the Rhino Rear Blade this winter also :D
It is already in the shop :p
Grouse09
B2650 Cab, snowblower, FEL, brush hog
Aug 24, 2016
139
Traverse City, MI
Now that is just amazing. Another great refurb. You are quite a magician Bill.
Spectre381
Kubota B2650, LA534 FEL, SGC0660 Grapple, 42" forks, ballast box, ratchet rake
Aug 18, 2016
47
9
NC
BEFORE
AFTER
Awesome work! I just became the recipient of a rotary cutter (unknown brand) and following your work on here has given me lots of ideas about what to do with mine. Hope it turns out half as well as yours did!
