Finally got my lights mounted and wired. I used all marine grade wire and connectors with heat shrink.
I ran two 10 gauge wires, one red and one black, from the battery to the back left fender of the tractor. I mounted a fuse block there and connected those two wires to provide both power and ground. The power wire has an inline 30 amp fuse.
I ended up using four Nilight 6.5 inch flood lights. Two pointing forward and two pointing to the rear. I mounted them on some brackets I got from Couper's products.
I used Mictuning wiring harnesses. I ended up cutting the in-line fuse off the harnesses since the fuse block is there. Plus I changed the connectors to use circle #8 connections to match the fuse block.
Now I just need to figure out where to mount the switches.
I know it's overkill, but I just ordered a 13.5 inch Nilight spot LED bar that I'm going to mount between the two LEDs pointing forward.
Nilight 6.5 LED lights
https://smile.amazon.com/gp/product/B01N0SFVCT/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
Fuse block
https://smile.amazon.com/gp/product/B000THQ0CQ/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
Wiring harness - 2 lead
https://smile.amazon.com/gp/product/B00WMPGLYU/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
Nilight 13.5 inch spot LED I just ordered. I'll update pictures when I get it mounted.
https://smile.amazon.com/gp/product/B019MF1NPE/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
Couper's LED Light Mounts. I ordered both the light bar mount and the non-rotating ROPS mount.
http://coupersproducts.com/rops-light-mounts/
