Post your ROPS light mounting pics
7,366
On my BX2660 - is there factory wiring for auxiliary lights out back that works with the multi-function switch or do I have to tap into tail light wiring?
Check your fuse box - may have a 10A(?) fuse labeled Work Lights or similar.....my 2360 does.
There are a hot and ground taped up near and to the left of the the top link mount in the back. I had to take off some electrical tape to get at them.
Hot when key is on.
JeepinMaxx
BX2660, LA243 FEL, RCK54P-23BX MMM, BX2751 QH Subframe, BX2750D 50" Blower
Mar 27, 2018
296
9
Columbia, CT
Hot when key is on.
Thanks RCW! I used your advice and found the hot and ground leads...
sorry for the un focused pic...
Anil8tor
BX2660 Loader 60"belly mower
Jul 16, 2026
27
42
Hello fellow owners,
So, I have a B2620 and have been contemplating different ways of mounting and running the wiring for my new 12V - 18W LED lights, 2 forward and 2 rear facing, on the ROPS bar. Searching through numerous threads yielded some pics...but I was hoping folks that have mounted auxiliary lights on the ROPS would be willing to post some pics of HOW they mounted the lights? Drilled into ROPS? Clamped? Magnetic mounts? Top? Side? Fabricated brackets?
I would certainly appreciate seeing how everyone else has mounted them and this could be a central repository for future reference for others!!
Thanks very much and I will post my pictures and description once my setup is completed...
Thanks...Burgie
I added this canopy to keep my head cool. On the front of that i mounted two 12 inch LED bars. On the back hanging under the rops is a strobe, and on the right is a fan pointed at my neck, its a beautiful thing on those 90 degree days
