Thought I'd post a couple of pics of my baby:
Zero cost shade from the Thailand sun. Wife found the umbrella in the barn. Blue pipe is to limit the rattling around. Works great.I was wondering what the tube was that was running up the back,Umbrella holder, it was odd to see,
but oh well I guess if it works then great!
Oh I get the shade thing I lived in the Arizona Desert for 21 years, no shade means dead!Zero cost shade from the Thailand sun. Wife found the umbrella in the barn. Blue pipe is to limit the rattling around. Works great.
Been there - Done that - Got a BAD sunburn!Oh I get the shade thing I lived in the Arizona Desert for 21 years, no shade means dead!![]()
I hope so. I'll still feel better knowing the part # before I tear into itThose screens are narrow enough, that as you start to remove it, it can be caulked at an angle for clearance. Might be tight, but are designed to come out with out having to disassemble half the tractor![]()
If you got any amount of water out of the drain on the steering box then you really should take it apart and check the lower bearing. If that is rusted it wont last and if it goes it can cause the complete failure of the box.Thanks to the article section about steering boxes and clearing the weep hole. I didn't have a small enough drill bit so I used a piece of wire with a hook on the end to clean the weep hole. A little bit of crud came out and some water. Dug around in the weep hole and more water came out. Opened the drain plug and more water! Removed the drain plug and more water! Fortunately no metal fragments. Flushed with some 90W and then plugged up and filled the box. Hope I got it before more damage done!
I'm thinking (hoping) that because I didn't have any metal fragments when draining the box and haven't had any steering problems so far that I should be ok.If you got any amount of water out of the drain on the steering box then you really should take it apart and check the lower bearing. If that is rusted it wont last and if it goes it can cause the complete failure of the box.
