B7000 owners wanted
11,223
I was wondering what the tube was that was running up the back,:confused: Umbrella holder, it was odd to see,:p but oh well I guess if it works then great! :D
Tomcat
B7000 4WD, RS1(?) rototiller, Konik 125 ATV
Nov 19, 2014
557
Thailand
Zero cost shade from the Thailand sun. Wife found the umbrella in the barn. Blue pipe is to limit the rattling around. Works great.
11,223
Oh I get the shade thing I lived in the Arizona Desert for 21 years, no shade means dead!:D
Tomcat
Nov 19, 2014
557
Thailand
Info plate says - guessing here on the translation - 3200 RPM max? and 13 ps (HP?) @ 3000 RPM guessing again that is the PTO power? Main question is how do I know the RPM's w/o a tach?
Tomcat
Nov 19, 2014
557
Thailand
Spent the day searching the web for part #'s with no luck. I'm looking for the # for the suction screen filter as I thought it would be nice to know BEFORE I pull the screen and discover that I need a replacement. I read the service article and located mine but I might have a problem. The screen shown in the article is about 7" long. I don't have that much clearance to the fender, maybe 4-5"! I hope my screen is smaller.
Also, part #'s for glow plugs and indicator because my tractor is getting really hard to start.
9,118
Those screens are narrow enough, that as you start to remove it, it can be caulked at an angle for clearance. Might be tight, but are designed to come out with out having to disassemble half the tractor :)
Tomcat
Nov 19, 2014
557
Thailand
I hope so. I'll still feel better knowing the part # before I tear into it ;)
Tomcat
Nov 19, 2014
557
Thailand
Got the #'s I've been looking for:
66611-36120 Suction screen
YBP204-15221 or 15221-65510 Glow plug
15221-65950 Preheat Indicator
Tomcat
Nov 19, 2014
557
Thailand
Still can't find the fluid capacities. I'd rather not have a 55 gal. drum of 90W sitting around the barn and don't want to come up 1qt short when I do the service.
Tomcat
Nov 19, 2014
557
Thailand
After an hour and a half drive to the Big City, roads crowded with trucks hauling cane, I get to the Kubota dealer so I can buy filters and it's CLOSED! No signs or anything to indicate why. :mad:
5thhorseman
B7000, Allied 95 FEL, Sovema Tiller, Blade, on 3 overgrown acres
Oct 21, 2010
107
Aldergrove, BC
Hey Tomcat, I sent you a PM the other day as we're both B7000 owners. Just wondering if you've seen it.
Tomcat
Nov 19, 2014
557
Thailand
Yeah, I just checked my msgs. I'm sure I'll have questions for you in the future. Thanks! :)
Will try the dealer again next week. I'm sure service can wait another week. :cool: Now I just need to get the old girl running so I can get some things done around here.
Tomcat
Nov 19, 2014
557
Thailand
Put a good charge on the battery and the old girl fired up! Now she's parked in the shade ;)
Tomcat
Nov 19, 2014
557
Thailand
Thanks to the article section about steering boxes and clearing the weep hole. I didn't have a small enough drill bit so I used a piece of wire with a hook on the end to clean the weep hole. A little bit of crud came out and some water. Dug around in the weep hole and more water came out. Opened the drain plug and more water! Removed the drain plug and more water! Fortunately no metal fragments. Flushed with some 90W and then plugged up and filled the box. Hope I got it before more damage done!
kubotasam
Apr 26, 2010
1,212
137
Alfred Maine
If you got any amount of water out of the drain on the steering box then you really should take it apart and check the lower bearing. If that is rusted it wont last and if it goes it can cause the complete failure of the box.
Tomcat
Nov 19, 2014
557
Thailand
I'm thinking (hoping) that because I didn't have any metal fragments when draining the box and haven't had any steering problems so far that I should be ok.
