Siesta Sundance
Oct 23, 2022
1,802
2,516
youtube.com
Filled up wildlife waterers & tubs, we're already in a drought and hotter than normal temps here and it's not even summer yet.
I have 2 IBC totes that fill stainless horse/livestock waterers by gravity.
Reactions: 11 users
S-G-R
LX3310 for now, L5460 in progress
Jun 17, 2020
1,325
3,022
PEI Canada
Thankfully we don't have to worry wildfires here but I like your setup. Wish the LX3310 could lift a loaded tote.
I use a 1" hose for gravity feed watering trees.
Reactions: 6 users
Siesta Sundance
Oct 23, 2022
1,802
2,516
youtube.com
Bmyers
May 27, 2019
3,439
4,284
Southern Illinois
Hello, my name is Randy, I have a L3901
It is 2016 I bought It and I carried it to Costa Rica for work, here it have been working well until the check of the picture turns on, the problem here is Costa Rica doesnt have a Kubota dealer and mechanicals from Kubota
I just have mechanicals of tractors on general, any comments or any suggestions are appreciated
Thank you so much for your time
I did a quick search and it shows dealers in Costa Rica
ACDII
Oct 21, 2021
681
424
Illinois
Mowed 4 fields of about 15 acres, then tedded. Got another 11 hours on the tractor. Need to ted one more time, then rake and bale. Going to have a LOT of hay this cutting, Double what I got last year due to the drought. First 5 day stretch of dry weather we have had all spring.
edritchey
Ferris IS800Z - New Holland WM75 - John Deere X500
Jul 19, 2014
1,117
819
Wellsville, PA
All the little machines outside the house today getting spring cleanup work done.
Mowing Check,
Loading the mulch Check,
Weeding and distributing the mulch Check :geek:
Got to get it done before the heat wave gets here they are calling for 90 degree weather by the end of the week.
Reactions: 9 users
GrumpyFarmer
3,968
All the little machines outbound the house today getting spring cleanup work done.
Mowing Check,
I heard that…I mowed and composted and watered the gardens today…probably have to do again mid week (watering)…hot and dry by end of the week here.
do you have spacers on the MX or is the picture just making those tires look like set really wide?
that’s a nice line up of machines you got there. 👍
edritchey
Jul 19, 2014
1,117
819
Wellsville, PA
No spacers but they are set as wide as they go if I remember it's at 80" keeps it just under the width of the mower and the snowplow and snowblower I use on it all of which are 84"
dlsmith
BX2230, LA211
Nov 15, 2018
1,268
850
Goshen, IN
Used the BX to clean up the area around the new water well I had installed last week. I hauled 6 or 7 bucket loads of excess fill away to a low spot by the driveway to my shop, and used some to fill in the ruts in the yard left by the 70,000 lb drill rig and the excavator that dug a trench from the house to the well head.
Sure beat a shovel and wheel barrow.
Reactions: 7 users
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,222
1,831
WestTn/NoMs
Are you baling with the B?
KubotaHawg
L2800DT, LA463, Landpride ΒΒ1260, RCR1260
Jan 9, 2022
65
73
NW Arkansas
Mowed—finally—out at cabin and both easements and entrance gates. It went from ruts in mud to dust bowl in a week.
Grass tall enough to not get out of 3rd gear.
L2800 likes her fresh oil/filter, air filters, and fuel filter though.
I have to mention, I hate hooking up a bush hog. It’s hard enough on level ground much more in NWA hills. Good thing it stays hooked up out there until fall when it comes back home.
ACDII
Oct 21, 2021
681
424
Illinois
I did bale with it once ... once. I do my hay fields with my L4060-HSTC-LE now. My B2410 is relegated to moving equipment around and backhoe work if needed, maybe some finish mowing. I need to troubleshoot the electrical system, the battery light glows at idle, either dynamo or the regulator.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,222
1,831
WestTn/NoMs
Didn't think so, I see you've added an L to your equipment list, with cab no less :).
Have you checked the fan belt? I was surprised how quickly mine stretched after I replaced it.
5,159
Gave the mini a little love. Did the 250 hr service on it and changed the engine oil and filter. There's no way that I was going to wait until 500 hrs for its first oil change (as per manual). Service was drama free with virtually no observable metal wear in the drives. Its only the second time I've changed the gear oil in the drives with the first being at 50 hours with some metal present. The threaded plugs came out easily since I applied some never seize to them at 50 hour service.
Cleaned her up a bit.
Did some testing with the new "tool" added to the dipper. Looks good to go and should make for quick work when leveling pads and digging anything requiring regular pitch.
Reactions: 7 users
5,158
Such a sweet looking machine!
Speed25
L2501(sold) - BX25D
Apr 23, 2024
226
315
NC
Mowed the lawn for the first time with the BX yesterday. I learned that unlike my previous riding mower, the movements of the BX trigger my step counter on my watch. I got a great workout mowing apparently!!
