S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,535
3,754
PEI Canada
Re the previous owner's wiring job: It never ceases to amaze me at what some will do to mess up the simplest of things. It takes a lot of work to do it poorly so why not do it well and do it once?
My son would say "It's a half passed job and they used their whole ass to do it."
S-G-R
Jun 17, 2020
1,535
3,754
PEI Canada
Project 2. Took the hillers off and just used the sweeps to line up some rows to plant trees. The line closest to the fence won't get trees. Line 2 & 3 will get trees starting tomorrow and line 4 is optional. I may plant more in the fall.
Reactions: 7 users
Siesta Sundance
Oct 23, 2022
1,832
2,544
youtube.com
For sure! I'm on 20 acres but am only cutting 15 acres at the most. I cut close to 12 acres of my friend's fields on the river a few times each summer so will need to modify my 22ft trailer to work with the M6060 and RC3712. Not a difficult modification but I want to add 3ft.
Awesome
7,083
Ran the new generator with a space heater attached for a while. Only 1,500 watts, but good to run them under a load.
The BX was the emotional support machine…..😉
GrumpyFarmer
4,437
It’s mud season here…can’t do too much. We did use the B to muck out the chicken run and turn some compost today. I’ll try to sneak in a mow tomorrow.
Old_Paint
Dec 5, 2020
1,937
2,110
AL
It’s too far to walk back out there for photos, finally tried out a homemade jig to mill a couple of 6x6 timbers from some pine logs accumulated from downfall on my property. A. Did not have the proper chain for the saw. B. The 2x4 I used for a guide tried to crawl off several times while I was using it. Despite those problems, I still wound up with one 9-footer and one 12-footer 6x6 beam/post. Milling with a chain saw is hard work 😓
S-G-R
Jun 17, 2020
1,535
3,754
PEI Canada
Project 3. Used the PHD and 9" auger to poke 122 6-8" holes in the ground to plant trees.
Reactions: 9 users
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,667
2,119
Western MT
Pulled an old apple tree out from the rear draw bar, of course. It's the first time I used the D-ring that I added a while back.
Consolidated my burn pile to a smaller size and added the apple tree to it. Added sand to the newly created burn pit.
mdhughes
L3901DT
Dec 10, 2014
1,379
1,176
Ste Geneveive county, MO
I finally was able to do a little tractor work around the place. I used the box blade and bucket to do a little work on our driveway (2/10 mile). We had a really hard rain the other day and one of our covert pipes wasn't able to handle all of the water causing it to run down the driveway making a rut down a section. Just had to pull the rock back up the hill.
Then I used the grapple to put down a small tree top along our private road that we share with 12 other houses. It was hanging by vines. I was able to grab a hold of it and pull it down.
Since I had the grapple on the tractor, I moved some logs to a new banking area. They were in two different places.
Also used the grapple to clean up some brush close to our yard.
ShootinBlanks
26
52
Maryland
Don’t think I would try one. I have a kind of deep ditch to mow Besides my yard. Thought about it before getting my 1880 but needed something for snow removal and a loader For moving dirt around. Was my 1st time removing and putting it back on so hope future movement gets easier.
It does and especially when you figure out the tricks. Best one is using the loader to lift the front and roll the deck under the front wheels. My trick for re-mounting is once the deck is back under the tractor, the first thing I do is connect the front bracket/carrier thingy. This helps a lot in getting things lined up in the back for the lifting arms. I take the 60” deck off my B in about 5 minutes and on about the same. Helps to do it in the shop on a nice solid and level floor :)
WFM
L3800
Apr 5, 2013
1,527
977
Porter Maine
I used my pallet forks slid together to dig a hole and pop out some rocks to plant a pyscinthia bush my girlfriend had gotten...
Our soil here is crap. Rocky and iron.
5,313
Many years ago had one of those Alaskan Saw Mill saw guide things and yeah, it was a lot of work. Also made a fair amount of lumber from the white oaks that had to go to make room for our house. Much better with a ripping chain in place of the normal chain. Can’t recall if that thing is still in the shed loft or if it went away at some point.
S-G-R
Jun 17, 2020
1,535
3,754
PEI Canada
Got the first 50 white spruce planted. Picking up another 50 tomorrow but will need to water these before the second batch get planted.
Reactions: 14 users
S-G-R
Jun 17, 2020
1,535
3,754
PEI Canada
They look so far apart now, but in 20 years they will be a solid high wall,......hope that is what you intend.
I planted them 10 feet apart but staggered the two rows so they are 5 feet apart. I'll see how this bunch does and I may add a third staggered row in the fall. I'm hoping not to see the neighbors home within 10 years.
Siesta Sundance
Oct 23, 2022
1,832
2,544
youtube.com
Plant ya a bunch of Christmas trees to sell in the future too.
5,183
Many years ago I did the very same thing at my then home in Minnesota.
20 years later, the (pine seedlings) had grown together to choke each other out.
Perhaps you could plant/stagger that third row, with the long term expectation that you might eventually cut the entire center row out.
S-G-R
Jun 17, 2020
1,535
3,754
PEI Canada
I'll keep that in mind. I want it to have a good windbreak and view block.
5,183
That is what I was after, but it kinda "grew" away from me.
I sold the property shortly thereafter, so it became a moot point.
Another thing you might consider is waiting 10 more years, before planting a third row.
That way, when the trees are tall, the 3rd row will be at least 10 shorter, helping to block lower limb needle shedding on the first batch.
