Thanks! Its a 200PGM pump pulling from a pond down below. The water goes through one more stream and fall before hitting the pondNice! more details please.
Spring, or is it a pump recirculating the water?
Thanks, It's a pond and pump feeding the falls and stream. I have a 30x30x5ft upflow bog for filtration near the house. Then there's that first fall (the smaller one)Nice looking project, and the protection against hydraulic effect of your small waterfall step.
Is that a flash flood, with high run off on a stream running house to assist it water control.
Just guessing, what is your water works project.
I like the project, and the "inspector" will now be able to go wading.
Sorta like what I need to do (x3) but I’m not so fortunate to have wide open space to do it in.
Sounds like a real project, hopefully you have equipment for it next time you dig!Sorta like what I need to do (x3) but I’m not so fortunate to have wide open space to do it in.
Three washes cross my property and all need some serious erosion control. The raised beds and water feature are actually my first efforts to keep my property where it was when I bought it. I did every bit of that with a pickaxe and shovel and a very helpful spousal unit. A few tornadoes and lightning strikes and several thousand cut poison ivy vines later, it’s kinda turning into a yard. The washes have been there since at least 1975 when the house was built, so I don’t reckon I need to hurry too much unless I expose more soil. I get enough leaf fall back there that I don’t get much problem anywhere except the ditches, but they wash clean pretty much every heavy rain. I thought about culverts across the first one and backfill with purchased fill and top, but my first calculation is calling for 50+ yards and then I still have to buy the culverts. I reckon I can redo that water feature and terrace area a lotta times before it gets anywhere near the cost of a private storm drain. That’s been there for 6 years, and I see no signs of needing to replace anything for a while.
Operating an orange is addictive.I decided to give the new folding cutter more of a test this evening and spent about 2 hours getting used to everything. The only problem I had was that I didn't want to stop! This cutter is absolutely amazing and a game changer for me. It's so easy to use and adjust on the fly and it really does turn on a dime without any contact between the cutter and tractor, other than on the drawbar of course.
Here are some photos of tonight's activities. I'm really, really pleased with this purchase.
I use a 15lb sledge, occasionally I have to put a little bit of heat on the 3/4" thick tines on my grapple.I have been fighting with a bent tine on a LandPride SGC 0554 claw grapple that I purchased from a fellow OTT member. He told me the tine was bent before I made the purchase and we met up at the Carlisle PA spring swap meet to exchange $$$ for steel. The second tine in from the end was bent about 4 or 5 inches toward the outside. I hooked a ratchet strap onto the tine and worked at tightening the strap and pulling it back into place. I also used a large sledgehammer to bang on the side of the tine in the direction that it belongs. On day one, I got it within an inch of where it belongs, and on day two I got it another 3/4" closer. Today the best that I could do was to pull it over beyond where it is bent, but it just wouldn't stay in place, so I admitted defeat. I am planning on using 1 1/2" black iron pipe welded between the tines at the bottom and I will get all the others welded into place first and then give the bent tine a final pull to get it into place, and then weld in another piece of pipe. I am going on the assumption that once it is fully braced at the bottom it should stay in place. I don't want to put heat on the tine since it might weaken the grapple. Overall I am quite pleased with my purchase.
Do you store that magnificent Airstream outside, where falling tree debris could dent it's beautiful skin?We were on vacation last week. Got back Saturday. Since then we’ve had rain at least part of the day every day. 5” total this week. So only thing I’ve done with the L in the past couple of weeks is put up the camper. In between rains, the T mowed all three yards, top of the dam, and grassed parts of the ditches on the common road.
![IMG_0147[1].JPG IMG_0147[1].JPG](https://www.orangetractortalks.com/forums/data/attachments/128/128010-76351e5f3d2a81321c59e5f0a45fb3a1.jpg)
For now, I do. Almost 3 years in, it seems to be handling it well. It would be a bit of a stretch for tree debris to hit it while in its parking spot, but I’d much rather park it inside.Do you store that magnificent Airstream outside, where falling tree debris could dent it's beautiful skin?
Woman wants a boat = WONDERFUL scenario!For now, I do. Almost 3 years in, it seems to be handling it well. It would be a bit of a stretch for tree debris to hit it while in its parking spot, but I’d much rather park it inside.
Looked into building a shed, or having one built, and would have pulled the trigger on a metal 3 bay 5 years ago but couldn’t convince wife to agree to clear out the trees that would have to go. Right now, she wants a boat. If she persists I’ve thought about telling her we’ll get a boat right after we have a building to store it (and the Airstream). Maybe someday.
For sure! I'm on 20 acres but am only cutting 15 acres at the most. I cut close to 12 acres of my friend's fields on the river a few times each summer so will need to modify my 22ft trailer to work with the M6060 and RC3712. Not a difficult modification but I want to add 3ft.Operating an orange is addictive.
Nice cutter. How many acres do ya have?
That one is forced flow. Pump is in the pool. The pool holds water very well, but there is a lot more evaporative loss when it’s running. Frogs seem to get most of the skeeters stupid enough to try to reproduce in it. It doesn’t freeze in our mild winter if it runs. The pump is submerged and helps warm the water a little and moving water doesn’t get cold enough to freeze here.Sounds like a real project, hopefully you have equipment for it next time you dig!
A seasonal water feature would be a neat deal there. Its pretty dry here so I have to use some well water to keep my pond full. Opposite problem, but I love running water
Re the previous owner's wiring job: It never ceases to amaze me at what some will do to mess up the simplest of things. It takes a lot of work to do it poorly so why not do it well and do it once?Project 1. Got a IBC tote strapped into my yard trailer. I'll be using it for watering trees.
Previous owner used it on the road. Like his wiring?
FYI, If you can't find a decently priced adapter for the IBC shutoff valve, a 2" ABS rubber coupling will work. I haven't picked a reducing fitting for a hose. Have to decide if I'm going to use 3/4" or 1" hose.
