ken erickson
Nov 21, 2010
1,264
2,201
Waupaca Wisconsin
I introduced a young man studying wildlife and habitat work to tractors and grapples. Impressive young person, listened to my safety talk, operation and controls and not once did he take his phone out and look at it!
Since purchasing my habitat restoration property I have met some great youngsters. It is easy to think that all are living in their parents basements and gaming 18 hours a day. There is Hope out there! 👍😀😉
Reactions: 11 users
NorthwoodsLife
Oct 15, 2021
1,283
1,275
Wisconsin
It's slim odds, but there's still some very capable younger folks out there with a head on their shoulders. Great post.
Mak65
L2501 HST
Apr 25, 2019
131
96
TX
Yesterday, not today… Thermometer hanging in pole barn read 102. Decided it was a good day to grease all fittings on chipper and shredder (the only two things that run off PTO and not stored outside the barn. Pulled apart PTO shafts on both and greased them, too. The only fitting I couldn’t get was the shredder’s wheel axle as I had parked it with it behind the support fork. Too hot to move tractor and hook up just so I could rotate the wheel. I have it noted to do so before mowing again
Labman
B2301, 60" finish mower, 60" back blade, 72" disc, 72" cultivator, 3 pt. sprayer
Nov 30, 2021
12
9
Kansas
Worked up ground again for next years expansion, ready to start mixing compost in it next.
What did you work the ground with? It looks nice.
worked up the fall gardens too.
Not on the kubota, son was mowing, finished up around the house, and I had noticed the neighbor couple hadn’t mowed their grass in a while, their mower is broke down and the husband has health issues and the heat is rough on him. Went to put more gas in ours and it’s steady dripping out the bottom 🤦‍♂️ WTH!
pulled the side cover and tank…
not sure what the hell they from, only the the middle one on the crease was leaking right now…got the plastic welder out and filled in all 4 though
storm came through before it was back together so will send him over there to mow tomorrow if it’s dry.
Bmyers
May 27, 2019
3,452
4,304
Southern Illinois
We finally received a good rain, a little over two inches. Spent a few hours on Saturday mowing and hoping for more rain.
Reactions: 6 users
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,120
3,381
Looked at my tractor today. Going to be 93 and a rh in the 60s. I think I'll do some indoor chores 😄
Flintknapper
L2350DT
May 3, 2022
1,943
2,466
Deep East Texas
I know its all relative to what you are used to, but where I am....it will be 93°F by 10:30 this morning and won't drop below that until about 9:00 O'Clock tonight.
Daytime high will exceed 100°F today. Humidity currently 78%.
But yeah, indoor chores need to be done too. (y)
3,099
Left the house today at 5:00am for a fat bike ride, temp was 93F.
Got in 10mi, but then that sun came up & started baking my a$$, so that is it for today.
5,175
I feel for you guys.
Will be high of 85 today, and humidity 88%.
That is hot,...... wind is off the ocean, but that also influences humidity.
No central air here.
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,120
3,381
This is true. If something needed to be done, I wouldn't have a problem doing it outside. Fortunately, today, I can choose.
Interestingly enough, out heat index is not forecasted to be much different from yours. You probably lack the wafting scent of Canadian fires though.
Flintknapper
L2350DT
May 3, 2022
1,943
2,466
Deep East Texas
Yep, not much chance it will make it this far South.
We have a different problem coming across our border, I'd prefer the smoke.
Hope they get the fires under control. Got to be rough on the those Canucks....EH?
forky
Feb 23, 2021
303
328
Wisconsin
Good for you Ken! I had the same experience at the feed mill Friday with the nice young man filling my order. I told the owner when I paid my bill that he was lucky to have such a nice young man working for him. He said, yep I'am lucky to have him and he never looks at his phone! There is hope!
4,959
About a year ago my wife bought this thing for the cat so he can sit outside without getting gone or getting eaten by the wild things in the world beyond. It was cheap (I think about $40 on clearance) and decently made except it had this stupid flat roof made out of MDF wrapped in roll roofing face screwed onto the top rails and nowhere for the water to go. She wanted it put up as is so whatever, and the cat loves it. Surprised it lasted as long as it did. After a year the top was near collapse, so time for a re-roof.
One problem I have currently is stuff scattered across various buildings. The lumber is split between three buildings and the woodworking stuff is mostly at my house with a little bit at the common shop.
I used to do some furniture building but quit because I pretty much built everything we wanted, built for customers for long enough to pay for all the equipment a couple of times over, and quit after deciding customers in general are irritating to the point of sucking the joy out of a hobby sideline, turning it into just another job. So a lot of the woodworking stuff is crammed in one corner of my shop area. The lumber I needed for this project was at the common shop area. For this little roof deal I had to rip a 74” long 1” wide strip at a 4/12 angle to match the roof pitch so I rooted out the tablesaw and forked it to the common shop.
It isn’t a fancy cabinet saw. It’s what I’d consider a two man contractor saw. As in you can pop the motor off in about 5 seconds and two reasonably fit guys can set it in the back of a pickup being it’s only about 275lb with the motor and somewhat less without.
It got me to thinking as I was driving away with the saw, why loader forks are better than friends:
  1. My forks don’t have chronic orthopedic problems that restrict their weight lifting to 50lb without complaining; 75lb with grumbling; 100lb intermittent with full on bitching. At my age, most of my friends do.
  2. My forks don’t have to ask their wife before coming over.
  3. If I want my forks to shut up, I can turn off the engine.
  4. My forks don’t expect return favors.
  5. If my forks don’t like the way I’m doing something, they mind their own business and don’t say anything about it.
  6. My forks don’t hang around forever after I’m ready for them to leave.
  7. My wife gets along great with my forks. She’s never accused them of being a bad influence; never asked where we’re going, what we’re doing, or when we’ll be back.
  8. Yes, I spent a few hundred dollars on my forks the first time I met them. Haven’t spent a dime on them since. They haven’t even asked to borrow money.
  9. They’ve been around me long enough now they have to have picked up on some of my more obvious faults but they never give me any crap about them.
  10. Forks can hand stuff from the ground straight to the roof on a one story.
New roof. I’ll put the trim back on to cover the very effective, yet aesthetically unacceptable, Great Stuff after the paint on the new part is thoroughly dry. Yes, it slopes downhill. That was an unsuccessful attempt to maybe get the flat roof to shed water enough to not fall apart immediately.
Then continued the almost done project of thinning out some of the overgrown landscaping at my father’s old house. 3 of the 4 people who live on the property disliked this bush. The fourth (me) didn’t care. Wonderful as the forks are, this was a job for the grapple. Took a short trip to the junk heap, then used the boxblade to fix up the hole left by the root ball. After that pulled a few T posts that were part of the electric fence around the beehives. Gave the bees away so don’t need the fence.
Edit: Maybe someday I’ll list off 10 reasons friends are better than forks. If I can come up with 10.
Reactions: 9 users
5,175
About a year ago my wife bought this thing for the cat so he can sit outside without getting gone or getting eaten by the wild things in the world beyond. It was cheap (I think about $40 on clearance) and decently made except it had this stupid flat roof made out of MDF wrapped in roll roofing face screwed onto the top rails and nowhere for the water to go. She wanted it put up as is so whatever, and the cat loves it. Surprised it lasted as long as it did. After a year the top was near collapse, so time for a re-roof. View attachment 107513
I used to do some furniture building but quit because I pretty much built everything we wanted, built for customers for long enough to pay for all the equipment a couple of times over, and quit after deciding customers in general are irritating to the point of sucking the joy out of a hobby sideline, turning it into just another job. So a lot of the woodworking stuff is crammed in one corner of my shop area. The lumber I needed for this project was at the common shop area. For this little roof deal I had to rip a 74” long 1” wide strip at a 4/12 angle to match the roof pitch so I rooted out the tablesaw and forked it to the common shop. View attachment 107514
View attachment 107515 New roof. I’ll put the trim back on to cover the very effective, yet aesthetically unacceptable, Great Stuff after the paint on the new part is thoroughly dry. Yes, it slopes downhill. That was an unsuccessful attempt to maybe get the flat roof to shed water enough to not fall apart immediately.
View attachment 107516 Then continued the almost done project of thinning out some of the overgrown landscaping at my father’s old house. 3 of the 4 people who live on the property disliked this bush. The fourth (me) didn’t care. Wonderful as the forks are, this was a job for the grapple. Took a short trip to the junk heap, then used the boxblade to fix up the hole left by the root ball. After that pulled a few T posts that were part of the electric fence around the beehives. Gave the bees away so don’t need the fence.
After that: Maybe someday, 10 reasons why a BH is better than either friends or forks (for some jobs)?
