GrumpyFarmer
4,223
I lost a couple nice trees last year in a wind storm and finally just getting to this one…so I took the little girl for a walk in the woods today…we put a good dent in it, but I ran out of GO-GO juice. (The MX would have been helpful today).
Took the little girl for a walk in the woods this morning. Not sure how I would manage without a tractor or grapple. Sure is helpful moving the rounds and sections of branches and holding branch to working height. Put another dent in the tree this morning…rain got here by late morning so I had to stop. I did not have a measuring tape but at an estimated 20-25 feet up the trunk at the 2nd fork the bottom of the fork is close to the OAL of the saw (in the pic…that’s the bottom of the fork). That’s a black walnut tree…there was some damage and bugs at the bottom but I think I am going to keep that log (that saw is sitting on in pic)and buy chain saw mill and try making some slabs to use in the wood shop. Anyone use a chain saw mill? Any advice or recommendations would be appreciated. Thanks.
johnjk
Apr 13, 2017
1,670
1,813
West Mansfield, OH
I use permethrin a lot. It works.
But the abundance of frogs and birds at my place, especially Swallows, do the best work on mosquitoes.
We have not had mosquitoes this year. Weird with all the rain. I do have some ponds and wet areas where I avoid spraying within 20’. Stuff isn’t good to get in waterways. I need to learn more about the fowl Fordtech is using, that or get me a couple dozen resident possums
6,910
Geese and chickens keep critters off the grass also.
MOOTS
MX6000
Jun 27, 2019
2,186
2,713
Canton, Georgia
Turn the oiler all the way up. Wouldn’t hurt to have an auxiliary oiler too. Get a milling chain, the grind angles are different on them. Milling is HARD on a saw.
I had this milled last year. Took the logs to him and gave him $250. Picked up a few days later. Found him on facebook giving away saw dust, he had a bandsaw mill.
GrumpyFarmer
4,223
Do you have an opinion on a brand and model? I have 2 more trees that tipped over or snapped like the one I have been working on in the pics that I have not started to cut up and have several acres of similar sized trees (I just can’t see turning all that into firewood)…however for the couple I have and the terrain I can’t get a logger to come out to get one or two (they want a truck load and I don’t blame them). On my property I can’t get anything bigger than my B near them…and the B can’t handle the logs so I am sort of stuck in place. So I think an Alaskan would be portable and I should be able to make some slabs with a little elbow grease and some go go juice. I’m leaning towards granberg, but I have zero experience with a mill. Help me spend my money…what mill and size bar makes sense. I plan to use with a stihl 461. I’m thinking that means I could do a 30 or maybe a 36” bar. Thoughts?
WAS BANNED FOR NSFW PICS
5,154
The most efficient mills use a band saw. If you wear out your chainsaw, then you are half way to the cost of a band saw. Look on Craigslist, or Marketplace for a used one. I have seen them come up for sale, and they are inexpensive compared to the cost of a new unit.
MOOTS
MX6000
Jun 27, 2019
2,186
2,713
Canton, Georgia
No I don’t. Never used one. On the chainsaw forum I’m on, those guys say it is very hard on the saw. You will want to be in the 90cc range for that size log. As I don’t believe that 461 will pull a 36” chain. That saw in the pic is an 044 with 24” bar. It was struggling to just make that one cut. I had to cut from both sides and the saw got overly hot.
2,342
Here are recommendations about the chainsaw milling:
Get long bars and rip chains for your largest chainsaw. The rip chains are ground at 10 degrees instead of 30 degrees and will cut faster and smoother than regular chain.
Get a few air filters for the chainsaw, they seem to clog faster doing the ripping than normal use. It may just be the length of the cutting that is done but I had trouble figuring out why my saw was not running well until I removed the air filter. The color of the filter is too close to the color of wood dust in my opinion.
Granberg makes a lot of good Alaskan mills to cut the slabs with. They also make a edge cutting mill to cut the first layer flat so you may want to get one of those also. That is all I use but I don’t cut slabs, I just cut logs in half for benches and step treads.
Build something to get the logs up to a reasonable working height and get them somewhat level and stable.
You might be able to hire a mobile sawyer that would be much faster.
GrumpyFarmer
4,223
Thanks. At my place up north I have someone with machinery that can come and pick up and take back to mill and he does great work and reasonable…but he is 4 hrs away and I can’t bribe him enough to get him to come to my residence…or he hasn’t hear the right offer yet. I have called a couple locals today and see what they think if they have something potable or a way to get it out of the woods. I think if I could get my Mx to it I could get it out of the woods and figure a way to get it on a trailer…price has held me back thus far on buying a mill. Looks to me like to not too hard to be approaching $1k for the buy in price…I am struggling that I only have a couple to do…if I get get a local here and split the spoils or pay a modest price I think it would be a better solution for me.
I appreciate all the inputs and thoughts from everyone. Stay tuned. 🥃
trial and error
Feb 16, 2023
394
386
NY
Finally got Humpty dumpty all back together after the fourth split doing the clutch. he fingers on the pressure plate ended up being most of my adjustment issue. The throw out bearing wasnt contacting the new pressure plate until way to late in the pedal throw. Even if that wasnt it, adjustung them helped me get everything else at least close to back into spec and have a pedal that feels pretty close to what it should
5,179
Excellent advice.
OP's chainsaw mill is not an efficient or cost effective idea.
Used bandsaw mill has resale value (likely no net cost).
Quick
B2601, LA435, BH70, LP SGC0554 Grapple, LP RB1672 Rear Blade, King Kutter 60" BB
Sep 23, 2021
146
252
St. Clair, MO.
Thought the bucket on my little B was bullet proof. Nope. Trying to roll a stump (that I couldn't lift) on to the burn pile was going okay, until it rolled back and fell on the corner of my bucket.
No worries. Took the bucket off, stood it on it's end and used a BFH to make it conform to original shape. (-:
N3BP
Sep 20, 2016
501
230
Lebanon, PA
Added a gearbox breather to my MMM. I'm trying to figure out why it keeps seeping oil through the pinion seal. When I went to open the fill plug, it let out a whoosh of air. That's when I thought it might be from built up pressure. I can't figure out why Kubota omitted a vent from the older boxes. All current MMM gearboxes are vented.
I didn't feel like drilling and tapping the box, so I just used the fill port to double as a vent.
flyidaho
L 3301 HST
Feb 28, 2017
428
255
IDAHO
I had to set some iron that was a bit too heavy and awkward to set by hand (I tried), so I
cobbled up a quickie extension out of 3" sq tube, lashed to my forks. The big angle was only about 100 pounds, and the extension was the next piece I'd be setting, closer so I could just use the forks for it. It went perfect, though at one point it did occur to me, a professional crane operator, that I had taken the mower off and had no counterweight, but I do have filled tires, no daylight appeared under the rear tires!
Fordtech86
L3200
Aug 7, 2018
4,966
5,916
Pineville,LA
Worked up ground again for next years expansion, ready to start mixing compost in it next.
worked up the fall gardens too.
Not on the kubota, son was mowing, finished up around the house, and I had noticed the neighbor couple hadn’t mowed their grass in a while, their mower is broke down and the husband has health issues and the heat is rough on him. Went to put more gas in ours and it’s steady dripping out the bottom 🤦‍♂️ WTH!
pulled the side cover and tank…
not sure what the hell they from, only the the middle one on the crease was leaking right now…got the plastic welder out and filled in all 4 though
storm came through before it was back together so will send him over there to mow tomorrow if it’s dry.
