RMS
LX2610HSDC, RCR1260, PFL1242, LX2963, RB1684, WC-68,Flail Mower,Grapple, Z421
Sep 26, 2021
260
523
Buckfield Maine
Took of the snowblower and installed the fel. The thought of doing it was more intimidating than actually doing it. Then I got some practice with the buckt moving piles of snow around, especially the high one at the end of the driveway. Made it a lot safer to pull out onto the road.
RalphVa
738
321
Charlottesville
Turned the scarifiers on the BB upside down. Will just use it as a RB for the expected snow tomorrow, if needed. Doubt it'll stick much. Been so warm.
Removed 2 gallons from the generator's tank and plopped my Tera pump with auto shutoff into the container sitting on the brake pedals. Didn't take it all, only 2.6 hours. Guess they did really fill it on delivery.
4,877
A series of small jobs to get in before tomorrow’s anticipated rain/snow. The road has been getting to look a bit ragged as the gravel migrated out of the wheel tracks.
Switched the float remote to the sidelink and on with the backblade to pull the gravel back to center. Being able to float the sidelink made the job faster and easier than it was pre-top/tilt.
Maybe not perfect but much better. Hope to get at least a couple more years out of it before we have to add more rock.
Then on to being the most expensive wheel barrow I’ve ever owned. Despite leaf removal in the fall, leaves always gather at the basement door. I was there, the bucket was there, a rake was there: the leaves left in the bucket.
Most of my implements are on dollies in the heated shop. These two hang out together in the shed. Done with the backblade so it’s back with its buddy, the rotary cutter.
Then back to the heated shop to pick up the chipper to clean up a little brush pile by the bees created by one of our winter storms a few weeks ago. We got the tree taken care of but deferred the chipping in favor of more pleasant weather. 60 degrees and sunny today definitely qualified for more pleasant.
Reactions: 6 users
ctfjr
L3800HST
Dec 7, 2009
1,982
2,535
central ct
Well yesterday up to about 5pm I was working on my low voltage lighting under the deck in 60deg temps (record warmth) in a tee shirt.
This morning, back to reality:
The crappy thing about the super warm weather we have had is the driveway thawed out. There were areas I was turning the blower into an earth mover before I adjusted the hydraulic top link.
Poohbear
Jul 6, 2018
524
186
Gilmer,Tx,United States
Saturday I rented a disc & added about 1/2 acre to my garden area. Plan to go back over today. I have been looking for a good deal on both a disc or pto tiller and a fertile spreader
GrumpyFarmer
4,009
Used the little girl to unload the gas caddy out of back of truck and then set shelf a pallet of blocks down for the (cinder block fire pit for the evaporator) inaugural walnut and maple sap/syrup season. We are are sitting at 22F today but it will be time for some spikes hopefully in next week or two maybe?
Trapper Bob
Jan 17, 2022
446
818
Andover, KS
Snow finally melted and I decided to harvest a little of the bounty Mother Nature keeps providing. This should keep the fireplace fed while we watch the game :)
Nice wood pile. Are you happy with the hydraulic wood splitter? What brand is it?
bmblank
Mar 4, 2015
715
399
Cadillac, MI
I took it out to snowblow the several inches that had accumulated. Before I knew it I realized the auger wasn't turning. 2nd stage was fine. Great, replace the shear pin again. Except, nope... Chain between auger and drive shaft in the back was broken.
A rock got wedged up in the hole the chain goes in and, let me tell you... Rocks don't make very good chain tensioners.
It's not too bad, it just threw a master link. Unfortunately the one I got from Family Farm and Home wasn't wide enough. I assume the "H" in "60H" stands for heavy duty. The plates on the master links that I got were about 3/4 as thick as the plates on the chain.
Hopefully tractor supply has it, otherwise I might be taking a flapper to my chain and take a few thou off thickness. I don't want to do that.
Shekkie
LX2610, Virnig 60" Grapple, WoodMaxx TM-86H, Woods 60" BB/72”RB
Feb 12, 2022
183
306
Grafton, Ohio
I got my LX2610 yesterday and today I received the plug in block heater. Simple job except I tightened it to well over 100 ft. lbs. before it stopped leaking.
i also checked all fluid levels, greased the zerks and sprayed the undercarriage down with Wool Wax.
My grapple quest continues.
Orange man hero
LX2610HSD
Mar 12, 2021
343
42
Wasilla, Alaska
Been dealing with this wet snow for a few days as it never seems to stop. Snow really sticks inside the bucket so you have to stop a lot to clear it. IT sure is nice when it is a least 20 out as everything is dry then. Notice since I upped the rpm per advice here, fuel consumption goes up quite a bit. All I am doing is pushing and lifting snow around so I try to keep the rpm around 1600. I know some say keep it around 2000 but I bet they are using the pto or plows etc. IT just seems over running the engine at 2000 for no good reason. Maybe it's just me.
Orange man hero
LX2610HSD
Mar 12, 2021
343
42
Wasilla, Alaska
i also checked all fluid levels, greased the zerks and sprayed the undercarriage down with with Wool Wax.
By God, what is Wool Wax?
Orange man hero
LX2610HSD
Mar 12, 2021
343
42
Wasilla, Alaska
I
Well, I actually finished it yesterday but worked a double today. I went from this....
to this...
Now to install all the MMM stuff and fix the 3 point linkage and fix the large dent in the hood that sticks out like a sore thumb.
like the looks of this tractor. Real tractor look and no nosense.
Shekkie
Feb 12, 2022
183
306
Grafton, Ohio
It’s a lanolin based spray on corrosion inhibitor. Like a waxy oil. It doesn’t wash off easily and will keep corrosion at bay. Not a big deal but I had some extra after doing my truck for the winter.
