ctfjr
L3800HST
Dec 7, 2009
1,982
2,538
central ct
got to see that purple primer or make the inspector unhappy :)
RalphVa
738
322
Charlottesville
I pulled two cyclone fence posts out of the ground with the FEL.
Only took the tiniest bolt run through holes drilled in the aluminum posts. Just had to slide the FEL up the post and let it connect with the tiny bolt head. Slid right out of the ground, posts encased in concrete. Ground is quite soft.
Tried it with one of the cyclone clamps near the top of the posts. Just slide right off.
Porcupine
L2501
Jun 15, 2021
125
153
NC
Moved 3 too big for my little 2501 hay bales (1100 pound) from the trailer to next to the field.
Moved another 6 comfortable sized (750 pound) from the trailer to storage.
Moved an estimated 6000 pounds of rough cut lumber from the trailer to a stack awaiting the start of a project.
Not real smart with the first load of wood and got the back end of the tractor in the air on a down hill slope. I got much smarter reall quick and avoided any further incidents.
In hindsight I guess I did more trailering than tractoring. ;)
Trapper Bob
Jan 17, 2022
446
818
Andover, KS
Cut down some pretty big trees.
KubotaHawg
L2800DT, LA463, Landpride ΒΒ1260, RCR1260, ZG222
Jan 9, 2022
96
142
NW Arkansas
Moved the rear wheels to the widest tread width on the new to me L2800 and replaced with new bolts. I didn’t realize the rear tires were liquid filled until the first one was unbolted—quite a workout for 51 years at 6’2” 170 lbs, they probably weigh twice as much as I do. Happy to find they are though, using in NW Arkansas mountain property.
KubotaHawg
Jan 9, 2022
96
142
NW Arkansas
Good taste in beer to replace those burnt carbs, too.
Been a couple Shiners consumed getting this tractor maintenance up to par. Replaced all dry rotted hydraulic hoses on FEL, new air filter, tapped out and replaced all 4 bucket pins with new ones/new grease fittings, and greased every fitting. I think the previous owner was allergic to grease.
She’s ready to work now.
GrumpyFarmer
4,524
Drop shipment received today after storm finally….raining now,
still ice and little snow left and lots of rain…somehow someone found a way to drop in the snow / ice with a cleared off driveway…..but nothing like a romantic evening with my girl in the rain…aint 4WD great?!
MOOTS
MX6000
Jun 27, 2019
2,189
2,718
Canton, Georgia
Dropped off at dealer to have 600 lbs of wheel weights added and the wheels set to their almost widest setting.
Outnumbered
Kubota L3901, FEL, BB1260, RCF2060, FDR2572, Forks, 55" Grapple, 5' Tiller .....
Oct 26, 2019
258
448
Moseley, VA
Unloaded my new generator the other day and uncrated it today. Wanted one large enough to carry my water heater and AC during the summer.
jyoutz
Jan 14, 2019
3,469
2,553
Edgewood, New Mexico
Would you mind sharing make/model of it? Thank you in advance.
GrumpyFarmer
4,524
That’s what I found when I goo
I googled it but I thought maybe yours looked a little cleaner in the photo. Do you feel it is robust and worth the 💰?
6,062
I have one of their L01 grille guards. Real pretty when installed but its already bent and beat up from the first summer's use. They protect the grille but if you use your tractor like I use mine they won't stay pretty.
6,062
Snow finally melted and I decided to harvest a little of the bounty Mother Nature keeps providing. This should keep the fireplace fed while we watch the game :)
