GrumpyFarmer
4,407
Nice.....admittedly I have also used the tractor to move the One-Up rack......but they are great bike racks.....
I like the beehive, is that Flow hive brand with the flow frames?
https://www.honeyflow.com/collections/flow-hives
I have a couple spots saved for hives on my place.
good eyes/good catch…yes it is a Flow hive…it’s actually the only Flow hive I have ever seen…any of my relatives and friends that have kept bees all had the traditional boxes. Step one is keep a healthy hive through this next winter…I sort of wish we would have built 2 giving a better chance one makes it through the winter or if one doesn’t maybe easier to identify the trouble, but just the one cost enough to try and see how it works. However extraction can’t get any easier IMO and no need spend money on a centrifuge.
radas
Mar 21, 2022
719
834
That's piss poor quality control. You would think that would be more difficult to make a mistake like that.
Agreed, I'm assuming they have jigs for lining up the brackets on the subframe tube, not sure how someone managed to weld it upside down with a proper jig.
Dwayne P
L3560
Dec 3, 2022
Prince Edward Island
Picked up some broken tower silo blocks leftover from a tear down at our place post hurricane Fiona. Moved some topsoil around and some yard cleanup also.
Quick
B2601, LA435, BH70, LP SGC0554 Grapple, LP RB1672 Rear Blade, King Kutter 60" BB
Sep 23, 2021
146
252
St. Clair, MO.
We had a busy day with the little lady….she transferred bike bike rack and Adirondack rack to the big barn, got a mow in before the rain this evening, transferred some straw, did a small fencing job, and moved / Transferred our first bee box outside (into small fenced area in the hillside - bees should arrive this week!).
Silly question perhaps. Is there a reason why both of your 3rd function connectors (can see in pics of loader) are male? I have dealer installed male/female on mine.
(cool bee hives, BTW)
Trapper Bob
Jan 17, 2022
446
818
Andover, KS
The 3310 is on root duty now.
I love a good root grapple & you know how to use it. You might push the male & female hydraulic connector covers together to help keep both clean.
Are those Birch trees? Are those root suckers from those trees?
S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,532
3,739
PEI Canada
Besides the rear mower I'd say the grapple is my second most frequently used implement and my favorite. The connector caps fit the male/female couplers fine but don't stay together. I give them a shot of brake cleaner and wipe them out with a shop towel before storage.
The roots are from some kind of thorn tree. The thorns will go through soft tires and the sides of work boots. Apparently, they were planted in lieu of fences to keep farm animals in. I haven't punctured the R14's yet but probably had three dozen plugs in my front pair of R3's and a can of tire slime.
Reactions: 8 users
Trapper Bob
Jan 17, 2022
446
818
Andover, KS
Thorn trees šŸ‘¹, I know them well. We are doing pretty much doing the same thing (I’m also using chemicals). Mine may have started in a fence row, but have spread all over.
Keep after them. I’m rooting for you. (Sorry, couldn’t resist)
Trapper Bob
Jan 17, 2022
446
818
Andover, KS
These 2 gate posts had leaned (lifted) quite a bit. Had my heavy equipment guy use his track hoe to push the posts back in. I put in a 3rd post & will cut off about 6ā€ above ground. Then, run a dead man to support the other 2. Shouldn’t lean again.
GrumpyFarmer
4,407
Sure….the dealer suggested and set them up that way with common couplers for BX I had originally and I agreed as it made sense to connect both in same way. I think really just to keep the process the same…I asked for it that as I think it is easier to hook up doing both the same way….personally I like the push sleeve over the male couple…seems like it sets a little easier than the opposite layout of rear remote types…at least for me . I’ve continued it on my B and MX. (I use colored tape to visually see which is which on the hoses for both the machine and the implement (grapple). I don’t believe it makes a difference just personal preference. I have all common type connectors on the rear as well…not some male and some female. If there is a some technical reason I am sure I don’t know. šŸ¤·ā€ā™‚ļø šŸ˜‚. Have a great day. ā˜•
soloz2
78
75
WNY
Put my grapple to use yesterday to get brush to the curb for pickup and then move some logs around the property so they were out of the way. Had to lift high enough to get over posts by the gate and then weave through some more standing trees I need to get down next month.
Kennyd4110
Vendor Member
Sep 7, 2013
1,413
740
Westminster, MD
www.boltonhooks.com
Both mine are female on the tractor side...makes no difference in functionality. A few colored zip ties to mark hoses and you never hook it up backwards.
CiscoRanger
L4150DT / BF900
Oct 3, 2022
254
130
very nice artwork on your flowhive. This is our first spring to have one as well. Just waiting on our little friends to finish filling it up.
GrumpyFarmer
4,407
Thanks. However I can’t take all the credit…I am mainly responsible for material handling and use of equipment and tools and general site prep and sort of site foreman and HGLOT (head general laborer of tasks)…generally I am not to be trusted with appearance / color selection. šŸ˜‚. I was permitted to paint some the single color areas, mainly the blue super and also the brown roof….everything else spousal unit did the great painting work and consideration. It will be interesting if we need to add a second box on the bottom. Any of my suggestions were not considered helpful or even appropriate for the exterior. šŸ˜‚. I did get it assembled…and boy did it use a lot more screws than I expected. I am a little worried about wind…I put a ratchet strap over just before it started raining…but I think maybe if we have some clear weather today I am going to add some ground anchors and a more secure strap over the top…until the bees get it waxed together I am not confident some heavy winds would not topple it.
CiscoRanger
L4150DT / BF900
Oct 3, 2022
254
130
Thanks. However I can’t take all the credit…I am mainly responsible for material handling and use of equipment and tools and general site prep and sort of site foreman and HGLIT (head general laborer of tasks)…generally I am not to be trusted with appearance / color selection. šŸ˜‚. I was permitted to paint some the single color areas, mainly the blue super and also the brown roof….everything else spousal unit did the great painting work and consideration. It will be interesting if we need to add a second box on the bottom. Any of my suggestions were not considered helpful or even appropriate for the exterior. šŸ˜‚. I did get it assembled…and boy did it use a lot more screws than I expected. I am a little worried about wind…I put a ratchet strap over just before it started raining…but I think maybe if we have some clear weather today I am going to add some ground anchors and a more secure strap over the top…until the bees get it waxed together I am not confident some heavy winds would not topple it.
Lol. Same here. My wife stained ours on the outside and painted the roof blue, whilst Ignoring any suggestions I might have had. šŸ˜‚. She said your hive looks ā€œsuper cuteā€ btw.
I had the same worry, and also worried about animals like raccoons. I had considered short pieces of angle on the corners screwed To the brood box and going up the super a couple of inches. But so far no issues and we routinely see 40+ mph wind. I did put some ATF in the ant guard cups which stopped ants from crawling up the legs. Can’t wait to get some honey from these guys. It’s been a great spring so far for the flowers.
Reactions: 6 users
Siesta Sundance
Oct 23, 2022
1,832
2,544
youtube.com
Yeah are those pricy hives, but I do like the simplicity of the frames to extract honey.
I was kinda hoping to find someone using the knock off version of the flow hive, the cost is almost half what the flow hive kits are.
Texas has a max acreage of 20 acres for the land tax exemption for apiary, I'm considering converting 20acres of my land over for bees. Aka, that also means having a dedicated hunting location too with no livestock...lol I would need 10 hives.
GrumpyFarmer
4,407
We had some excitement at the Hofferosa today…
A few years back I had the opportunity to deconstruct some large equipment pallets for machinery and keep the Timbers…which since they were my favorite price I got a trailer load and have been keeping covered since.
today we pulled back the tarp to pull out a few and to our surprise we found an infestation or raccoons (I am not really sure how many, but IMO 10-15 at least if there was 1)…as soon as I saw them I yelled to spousal unit at far end of trailer to get back and that that moment she saw me reaching for Mr Kimber and the family of raccoons scattering…in the same moment there was some aweful yelling screaming and what I could discern as ā€˜don’t f’ing shoot’….any way I was not able to deal with the squatters as the spousal unit froze and stayed there at the end of the trailer. There was no dispatching and no one hurt so that is good…but what a mess and collection of fur and feces. It was aweful. But we finally got 8 of the Timbers and then cleaned them off. Since I did not have a clean shot, I managed to get the phone out and get a couple pics of the last few that came out.
Reactions: 7 users
Siesta Sundance
Oct 23, 2022
1,832
2,544
youtube.com
today we pulled back the tarp to pull out a few and to our surprise we found an infestation or raccoons (I am not really sure how many, but IMO 10-15 at least if there was 1)…as soon as I saw them I yelled to spousal unit at far end of trailer to get back and that that moment she saw me reaching for Mr Kimber and the family of raccoons scattering…in the same moment there was some aweful yelling screaming and what I could discern as ā€˜don’t f’ing shoot’….any way I was not able to deal with the squatters as the spousal unit froze and stayed there at the end of the trailer. There was dispatching and no one hurt so that is good…but what a mess and collection of fur and feces. It was aweful. But we finally got 8 of the Timbers and then cleaned them off. Since I did not have a clean shot, I managed to get the phone out and get a couple pics of the last few that came out.
There are messy animals for sure!
I try remember to set traps every now and then, but I usually end up catching one our farm cats, lol.
Siesta Sundance
Oct 23, 2022
1,832
2,544
youtube.com
Where abouts is your place located?
