radas
Mar 21, 2022
719
834
As one of the last parts of my landscaping project I had 8 yards of 3/4 marble chips delivered. I wanted to spread them in the beds in front of the house.
The 1st few loads I used the L3800 to bring full buckets there. Unfortunately that meant crossing my new front lawn several times. I did not like the look of what the nearly 4000lb machine was doing to it.
So I opted to get a 1200lb rated yard dumping wagon. Used the fel to load it up and then pulled it to the beds by hand:
When the front was finished I decided to make a small bed to protect my survivor Azalea plant. The poor bastard has been pulled out of the ground twice (once to remediate the oil tank near it and again when the electrical wires had to be dug up). It has also been hit by my former snow plower (2x) and more recently run partially over by the oil delivery truck.
Not much left of it but I don't have the heart to pull it out. So decided to 'protect it' from further abuse. First find a protector:
And put it on guard duty
Didn't know they sold marble chips. I've seen granite but never marble. Looks good!
I figured out a bulletproof way to hang my hydraulic top link. Used two eye nuts and a threaded rod through the top link factory mount. Also extended and used the factory toolbox bolt holes and some eye nuts to run chain from the top link to the light bar. Right now, I'm running straps in place of chain until I can get some larger threaded chain links to show up.
5,993
quick yard "cleanup" post excavation to ditch some boulders. Excavation work was done by another who didn't show up in the am for the "clean up". About 96 degrees too.
Kubota engine kept cutting out on me after approx 2 mins of run time. Once when I had the "boulder" on the right in the bucket. :mad: Drained the fuel bowl three times to get it to run as usual. Must have been some water in the fuel.
hard to tell from pics, but it was quite messy and the large bolder/concrete debris on the left was approx 7 foot long. I was able to bucket the other junk to the customers stream bank, but that biggie I had to lift with the loader to get a chain around it. I was then able to lift the front of it by chaining it to the box blade and drag it to its final resting place. I needed a plumber to sit in the loader bucket to keep my front wheels on the ground. Split brakes used as well.
Then a couple of passes with the box blade to smooth things out just a bit. maybe I'll get the call from them to come back and finish grade/reseed.
Reactions: 8 users
Dieseldonato
Mar 15, 2022
728
439
Pa
Beautifully done.
5,299
View attachment 85051 View attachment 85052
I know various models have various setups so mine is probably different from yours. My tractor came with a wire hook to hang the toplink when not in use. When the dealer installed the hydraulic toplink they put a big zip tie on it to provide a way to hang the toplink in the too small for a hydraulic toplink wire hook. Seemed kind of crappy but it worked until I snagged the zip tie on something and ripped it off. Next time I needed it, it was missing and I didn’t really have a bunch of time for something creative so I used the Channelock’s in the tractor box to bend the wire hook out so it would fit the hydraulic toplink. Now it works just like it did with the standard toplink. Not sure why the dealer didn’t do that to begin with.
radas
Mar 21, 2022
719
834
Yeah my factory link to hook connection was horrible. It would pop right off every time I hit a bump. Your solution is what I thought about doing before I got the hydro top link 😁
I played around with the BB in the woods I cleared tonight. It was in rough shape and I smoothed it out quite a bit but I'm not 100% happy with it. I need more practice for sure! I also uncovered a bunch of debris that I need to move and burn but now I can get the ZTR in there to mulch leaves and keep vegetation down.
9,773
One of the nice things about having two tractors is that one can be set up with the grapple and the other in quick change mode between pallet forks and bucket. It was the MX's turn this morning to lift the latest acquisition off the trailer.
I started out with the M, grapple and a chain, but as I began to lift the plow off the trailer it occurred to me that there wasn't much to prevent the plow from flipping over (rotating) and smashing the tractor. I stopped what I was doing, got the MX and pallet forks and it went as smooth as can be.
radas
Mar 21, 2022
719
834
Man, that is a hell of a machine...
9,773
The MX is a really good tractor ... no regrets at all with the cab model.
SadFace
B2650, loader, backhoe, scrapper, finish mower, post hole digger
May 16, 2018
9
B2650, chasing a OPC fuse issue. Keeps blowing when the tractor is under load. All the safety switches tested good...I don't think its the wiring hardness. I keep my tractor clean and in good condition.
9,773
I got hoses made up at the local Kubota dealership for the "new" John Deere three bottom turnover plow. While I was there I picked up the front weight bracket with bolt bar kit for the M6060 so that I have the option to add suitcase weights this fall if needed. The bracket is a beast and one heck of a deal for $156. It had been laying around for quite a while and turned up during a recent new owner inventory check. It's made out of 3/4" plate and is one heavy chunk of steel. I can't find much information on the M1875 kit but I don't think it's equivalent to the M8075 bracket that comes with the M6060 when you order front weights from the factory.
If anyone has any Kubota suitcase weights that would fit this bracket I'd really appreciate a photo and some measurements. Never mind. The EA kit tells me what I need to know. I hadn't realized that the bolt on piece of HD angle passes through each weight to keep them secure. Looks like the bracket will accept 7 of these.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,492
2,074
WestTn/NoMs
Since I already took the picture, this is my modified Kubota rack (made from two 5 holers) to fit our Ford with 5011 weights, 55 pounds each, I think.
9,773
Awesome! I think I might order the Kubota weights from Everything Attachments. It's a decent deal for 1,020lb at $1.19/lb or 1,078lb at $1.35/lb delivered depending on which weight type fits my bracket. I might have to get creative with the cheaper weight to get three of the weights on since they're 2-7/16" thick. If the more expensive one works with the bracket I can get all eleven weights on since they're 1-7/8" thick.
Added in edit: After some digging I found that the Kubota suitcase weight for the bracket I have is M8071 which is basically EA's 5014 102lb weight. Those are the cheaper of the two which is nice, so $1.19/lb it is and eight will fit on the bracket as it currently sits. I'll look at modifying the bracket to take all ten weights.
Trapper Bob
Jan 17, 2022
446
818
Andover, KS
I completed my 400 hour service today. Now, back to work.
Reactions: 8 users
radas
Mar 21, 2022
719
834
Got my implement pallet carts built. The one for the BB is unfortunately too high (I should have measured), so I'll need to figure out a better way to use it. I may replace the top planks with 1x material vs. 2x material to reduce the height by a bit.
9,773
Got my implement pallet carts built. The one for the BB is unfortunately too high (I should have measured), so I'll need to figure out a better way to use it. I may replace the top planks with 1x material vs. 2x material to reduce the height by a bit. View attachment 85197
Could you make up some steel brackets that bolt to the side of the pallet and hang the casters of those such that the bottom of the pallet is an inch or less off the deck and can still roll around? It wouldn't be as nice in terms of having pallets butt up to each other but it's a work around.
radas
Mar 21, 2022
719
834
That's a good idea, I'm going to take some measurements tomorrow. If I can get away with .75" of height reduction, I'll go with the 1x for ease. If the gap is more than that, I could weld two 5" angle iron brackets together in a Z shape, bolt the bottom of the angle iron to the bottom of the pallet and drill the portion that hangs off of the side for the casters.
By the way, good call on 1000lb casters, these things are smooth as butter even with a heavy bucket and the weight of the pallet on it.
9,773
If you go with the double angle idea which is a good one, you might want to gusset the angle so that it doesn't deform under load.
Yeah, good casters are pricey but well worth the investment.
Old_Paint
Dec 5, 2020
1,937
2,109
AL
Here's another way to get 1/2". Instead of 4x4's for the structure, stack two 2x4's. A 4x4 is actually 3.5 x 3.5. A 2x4 is 1.5 x 3.5. Two stacked would give you 3 x 3.5. Assuming a half inch would help, that is.
radas
Mar 21, 2022
719
834
Another good idea. I may be able to do that and get 1.25" with 1x planks on top.
