jkrez
Gr2120, LX3310, bh77 hoe, 64 inch commercial snow blower, landpride pallet forks
Apr 16, 2021
85
84
Berks County PA
Well I did not do this. I was sleeping when a tree branch broke off. It appears that only the hood is dented. Debating using the insurance. I was able to push most of the dent out from the inside. there is a small paint chip. I guess 250 bucks for a new hood is a good deal.
The thing that does tick me off is that The Kubota is normally in the garage along with the GR 2120, but the steering linkage bracket broke and I had it apart until the part came in.
Oh It appears the self leveler saved it from being worse than it is.
  • Angry
Ikc1990
Kubota m125x, m9000, b2710, and other equiptment
Dec 2, 2020
292
130
Vermont
Papa joe you probably would be a home body if ya had gotten jolted in them tender areas lol might be afraid to go out side let alone near the property lines.
5,245
That is why you should replace the batteries long before they stop working. 60 days is what we recommend, but never beyond 90 days, or your dog will be outside the protected area looking back in, and will not cross over, since the collar will be beeping. I have seen dogs intent on chasing an animal that will be moving so fast that they barely have time to hear the beep, and the shock fails to stop them. Those type of dogs need a better restraint than a perimeter wire system.
Back when he had dogs, one of my father’s dogs learned to run at the wire full speed to blow past it. He ran a second line about 20’ past the first line and made sure he was around to shut it off to save the dog stuck between the lines first and second time he let that dog out. That stopped the line jumping.
lerxstland
MX5400 , New Holland 4630, LP BoxBlade, land plane, Grapple, rake, rear blade,
Mar 7, 2016
20
37
McHenry, MD
2. One for the top link, one for the side link. “Standard” is center return (up/down/off). If you want one or more to have the ability to float or run constantly (to run a hydraulic motor, etc.) be sure to spec the functions the way you want them. Personally I have no use for a constant flow. I do really like the float option.
I have three sets of remotes on mine. Have to pull the right rear wheel and fender to put on one so from a labor standpoint installing 3 isn’t much more than installing 1. Needed 2 and the third was just the additional part cost so went ahead and had it done.
I know there are some really good A/M options for rear remotes, some which may better than or cheaper than OEM. However, my whole setup, cylinders and valves, was done by the dealer. I couldn’t source the cylinders cheaper than the dealer quoted.
Pic of the remotes on the back of tractor and valve handle location below. I like the valve handles being in easy reach while driving and like them all being different height so no confusion which one I’m grabbing. View attachment 63230 View attachment 63231
Thanks for that... very helpful. I'm going to have the dealer install mine as well.
River19
B2601, RB1560, BB1260 and BX2830 blower
Sep 10, 2020
335
554
NH/VT NEK
Since we got ~7" of rain over the past week and some real nasty flooding around town wiping out some roads etc. The gravel drive took some minor beating with some washed out strips about 6" deep from water washing down over several days.
Took care of it last night.
As a side note, I'm waiting on my tooth bar to do some improvement and bolstering of my drainage program for the driveway.
Reactions: 10 users
Crash277
BX23S
Jan 17, 2021
844
621
Getting ready for gravel. Wouldn’t know I poured 4” on that spot 4 years ago. Did 3 passes over the entire section with the scarificers dropped all the way down and max aggression. Hopping it gets dropped today so I can finish my driveway expansion and then touch up a few spots with the extra.
5,933
Cleanout installation because camera couldn't make the turn in 1/8 bend 4" cast iron pipe. I took this opportunity to teach a young new tech on how to run a small backhoe (excavator would not fit in this wooded area). He did a great job for his first time in the seat. I think he really enjoyed it too...maybe I've created a monster that won't want to give up the seat for an old guy??? Anyway, it was worth it to me to let him have a go at it. They need to learn sometime.
Truck goes back in the shop for the third attempt at fixing the fuel tank issue. :mad:
KbotaL185DT
Kubota L185DT (sold),Kubota B7800, LA402, 5 foot Bush Hog Squealer
May 29, 2020
19
27
Rangeley, Maine
Designed and built a man sized cup holder for my B7800. None of these little can sized cup holders. I needed a Yeti holder for my long bush hogging days.
Newaterman
LX2610 HSDC, Z422-54KW
Feb 14, 2021
99
274
53
Vermont
You have to love the placement of these oil drains, coupled with the hole in the frame with nothing below it for the oil to run out right to your catch pan.
This was the break in oil change, admittedly a couple hours late, so it was all glittery.
After that it was time to grease everything, then cut some grass, and work on the backyard bike park for a couple minutes until mother finished up in the home office.
aaluck
Oct 9, 2019
982
833
Snowdoun, AL
Boy, the summer heat must have us all doing nothing with our tractors! Almost a week with nothing.......
