chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,846
2,256
Near Lancaster, PA, USA
Although it was hot early today it was time to pay some attention to a few things. Cleaned underside and sharpened the blades on the RFM and lubed it Blew out radiator, A/C coils and hydraulic oil cooler. Blew out the air filter elements. Replaced fuel filter. Couple of notes:
For supporting the RFM while working under it, a pair of HF jack stands works well. Raise the deck, set the stands under the front edge of the deck and lower the deck so it rests on the jack stands. This keeps the deck more or less level and it can't fold or settle. The jack stands support the front and the top link supports the back. I once set the jack stands on the sides of the deck and removed the blades. While off getting the blades cleaned and sharpened, the 3PH had enough leakdown to let the deck pivot and almost slip off the jack stands.
Drilled 4 holes in the fan shroud to make life easier. Oops, didn't have my phone for pics. Maybe I'll remember to take a couple tomorrow when it's mowing time. One high and one low on each side in the space between the fan and the radiator. The blow gun can then reach pretty much the entire back side of the radiator without fighting to get between the fan blades. Squeezing the wand between the blades made it tough to get 100% coverage, plus it concerns me to be poking around hitting the radiator fins. With the access holes, the wand runs smoothly parallel with the back of the radiator. The wand of choice for this is the bottom one in the picture. The end is blocked and I cut a kerf in the side for a 90° blow.
Per the WSM, turned the fuel valve off, dropped and replaced the filter, opened the fuel valve and the bleeder valve, started and ran engine for about 30 seconds, shut it off, closed the bleeder. There was no hesitation when starting it and no sputtering or anything. It started and ran just like normal for both bleeding and when complete. One of the previous Kubotas (perhaps the L3200) was a PITA to bleed after disrupting the fuel.
Reactions: 6 users
g_man
Feb 3, 2023
305
1,383
NE Vermont
^^^^^^ Good idea on the blow gun access holes chim (y)
I will steal that one.
gg
S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,533
3,741
PEI Canada
Had one missing and one broken bolt on the FDR2584. Everything was there when I last hooked it up but I didn't notice the missing and broken bolt until yesterday when I was walking by.
The rest of them were tight. Not sure if one backed off and the other snapped due to the weight or maybe they both broke.
nerwin
Nov 13, 2024
594
1,587
Vermont
youtube.com
Went to the Kubota dealership today to get oil change stuff.
Got the oil, 7 quarts, oil filter, air filter and fuel filter for $113 not bad I must say for some easy maintenance.
I also walked out with a Kubota hat. I mentioned I occasionally wear a John Deere hat while using the tractor and he says that's just wrong! 😆
But I made a huge mistake.
I sat on one of their new zero turns and I didn't want to get off from it. I could sit in it all day. I want this in my living room to watch movies with. I want one so bad 😭
Reactions: 8 users
5,296
Yeah, that’s a really bad move, going to the dealership for a couple little things and “just checking out” the new equipment. A few years ago, I went to my local dealer on my lunch break to pick up a hydraulic fitting. Got a work call when I was 10’ from the front door, it was pseudo-important and the guy on the other end of the call wouldn’t shut up for anything despite the issue being resolved in the first 3 minutes of the call.
I wandered around sitting in mini-ex’s, big cabbed M’s, zero turns, CTL’s, a MX6000 (should I have gone one frame size bigger?), RTV’s, BX’s, and anything else with a seat. By the time the call ended an hour later, my shopping list was about $500,000. Took me a couple weeks to get over the experience.
When I finally made it inside, they didn’t have the fitting I needed so I left with nothing. Had to go another couple miles to the Parker Hannifin store where I should have gone in the first place.
MotoBBQ
L3902HST w/ LA526 loader; rotary cutter; box blade
Jun 26, 2023
41
247
MN
Added some grass clippings and turned the compost pile. It's supposed to be "feels like" 100 degress here today. That's hot in MN. Just a before photo only. Headed indoors the rest of the day.
Reactions: 6 users
NorthwoodsLife
Oct 15, 2021
1,411
1,470
Wisconsin
Found this today after moving dirt to backfill an erosion spot by the driveway...
This failure is unacceptable IMO.
Steering tie rod boot. 3 year old LX2610 that I am guessing is out of warranty.
Might try the inner tube fix that I found here on OTT.
Shawn T. W
Dec 9, 2024
422
759
SW Missouri Ozarks
Well the Kubota didn't get a lot of work done today, but used it to gauge how high I had to trim some of the neighbors trees overhanging my field ... Before I could start on the next project ...
All trimmed up!
Then I could start on the real project ... I had a drainage pipe that wasn't covered up all the way, as I ran out of time and dirt ...
I used the rototiller to loosen up the hard packed clay - 15 second dusty video!
https://rumble.com/v6wrl5i-rototiller-virgin-ground.html
Then using my 6' rear blade I found out in the weeds when I bought this place, I scraped it up, in A/C comfort!
So I could scoop it up with my Little Baby Fergie and dump it on the exposed piping!
Not perfect, but the piping is covered up, and it's "mowable" now, good enough for a field!
Unfortunately there was very little Kubota time, and lots of Stihl & Massey Ferguson time ... It was/is hot out, and I'm plum wore out!
Reactions: 11 users
MOOTS
MX6000
Jun 27, 2019
2,189
2,716
Canton, Georgia
All trimmed up!
Chainsaws and ladders, what could go wrong?!
Looks good though.
MOOTS
MX6000
Jun 27, 2019
2,189
2,716
Canton, Georgia
Watered my dirt.
Pulled all the post and wire yesterday and tilled under 2 rows of peas, 1 row of cucumbers and a row of green beans. Going to replant some things.
It sure doesn’t look like 275 gallons out there.
Reactions: 7 users
Old_Paint
Dec 5, 2020
1,937
2,109
AL
We’re hoping for a “feels like 100 degrees temperature “ in Alabama before we’re all give up on church and figure the worst happened when we last fell asleep without being in a pool of sweat. I grew up without air conditioning in LA (lower Alabama) where anything below 98% humidity and 98 degrees Fahrenheit was considered a nice brisk spring or autumn day. It was so hot that the trees chased the dogs. Then, when I grew up, I got a job took me to places like Barstow, CA, where the temperature change in 6 hours is the same as the high temperature for a nice spring day in Alabama. I SAW the temperature start at 38F at 0600, and climb to 118F by noon. I know why I like living in Alabama now. At least I know what to wear and that I won’t have to change clothes by lunch.
MotoBBQ
Jun 26, 2023
41
247
MN
I knew I would catch a lot of flack with thr "feels like 100 comment". We have a saying in Minnesota, "it's not the heat, it's the humidity".
Come back in 6 months when it's -20 degrees real temp. Haha.
2,439
Are you sure there is a failure in the boot? It looks intact in the picture and just locate improperly and missing the wire spring that holds it in place but I am looking at it on a small screen.
NorthwoodsLife
Oct 15, 2021
1,411
1,470
Wisconsin
Thank you. I hope that you are right.
I think I saw the spring retainer still on the rod It looks as though the boot is not torn.
I am going to look deeper into it today. May be a quick fix. I don't know. It looks like I need to remove the armor shroud to get to it.
After a long day yesterday I wasn't up for a repair project. Did my end-of-day quick walk around checking for issues and I found one.
Edit: I found this video...
2nd Edit: Fixed it this morning. Boot is not torn. The larger compression spring was still on the tie rod, but putting it back in place I ruined it by over stretching it. So I fastened the large boot end using bailing wire with a twist. The boot is on tight, but I would rather have used safety wire. I will keep an eye on it.
MOOTS
MX6000
Jun 27, 2019
2,189
2,716
Canton, Georgia
Tilled and laid off the new rows this morning. Yea, some are crooked, I didn’t feel like pulling the T post on the far end.
Youbet
Kubota M5-111
Sep 1, 2022
Kentucky
All trimmed up!
Safer to climb in ( or use ladder to get in ) FEL bucket to cut limbs up high as opposed to just use ladder with chain saw.
Old Machinist
May 27, 2024
538
623
NE FL
Washed mine and cleaned the radiator and condenser also. Did a lazy man's wash on the outside. I used a Ortho chemical sprayer on the hose to soak it with soap then rinsed it off.
I have a homemade spray wand I connect to the hose for cleaning the radiator. Just a piece of 3/4 copper tube with the the end smashed closed and bent to get in tight places and increase the pressure a little.
My AC has been increasing the high side pressure enough to make the clutch slip at idle lately after mowing so keeping the condenser and radiator clean is a must. I'm going to have to remember to turn the AC off when I lower the RPMs to disengage the PTO. I am contemplating relocating the battery to increase the cooling area in front.
Shawn T. W
Dec 9, 2024
422
759
SW Missouri Ozarks
I've done that too in the past, but moving the ladder was faster easier in this case ...
It depends, but neither your way or mine is approved by OSHA ... FEL's have been known to fail too ...
Life is full of dangerous things ... Pick your poison, I'm an adult and except the risks I take . . . I don't need a nanny.
