Pros and cons of snow removal options
Moose7060
Oct 14, 2023
525
1,176
bc
That lo
That looks cool. Don’t think my 1880 would pull that heavy beast. If I get another tractor, a B would be on my list. Maybe a L.
That brand is Farm King. Landpride makes a 64" inverted 20-55 HP which may also be too large.
Wifo equipment makes a wide range of inverted blowers as small as 46 inch, 10-20 HP.
NoJacketRequired
May 25, 2016
432
68
Ottawa, Ontario
That lo
Inverted blowers generally tend to require a larger tractor per inch of snowblower as opposed to a unit that one pushes into the snow, either front mounted or traditional rear-mounted. If the snow is wet and sticky the tires compact it into two humps of near-ice material that's hard to remove. Plus you still have to look back to make sure your snow discharge is going in a safe direction.
For BX and B-series tractors the front-mounted blower is king of the hill. I have three of them and will never go back. (Pun intended!)
Moose7060
Oct 14, 2023
525
1,176
bc
I have had absolutely no humps left behind. The weight of the blower following cleans it right down.
Bearcatrp
Mar 28, 2023
641
342
Minnesota
Looked up a 54 inch. A little over 4 grand. Too much for my blood. I would go rear push if I would get one and deal with the neck pain. A bit cheaper. But with the lack of snow these past years, my rear blade is doing pretty good. Just need to get a front blade of same size as my 3 point.
WFM
L3800
Apr 5, 2013
1,342
671
Porter Maine
That's the same here. The lack of snow in the past few yrs makes investing in snow removal equipment for personal use hard to do. And nothing ever drops in price.
NoJacketRequired
May 25, 2016
432
68
Ottawa, Ontario
Your bigger tractors allow you to pull a bigger, heavier blower and to have more traction. I've seen the smaller (compact, sub-compact) tractors struggle with having sufficient traction to remove the compacted icy ridges.
airbiscuit
New Holland T2310, New Holland TC21D, Kubota l3010 GST, Farmall H
Mar 18, 2021
215
150
NW WI
8I have absolutely no problem with my 68" M K Martin rear pull snowblower scraping the tire tracks clear.
TJP440
Gr2120 and B3200
Apr 16, 2017
37
27
Omaha, Ne
I run a rear mounted blower and use the loader bucket when needed as there are areas i cannot access with the blower. Put a soft cab on a few years ago with electric heat.Went with the electric as I really id not want to mess with the plumbing aspect and there is not a lot of extra room for a water based heater.
I also upgraded the charging system for a second heater but haven't needed it yet.
Our snow have bee milder than years back when i can remember running out of places to put the accumulating snow. The blower gets it far enough away it doesn't pile up as it did with the blade
