Electrical - Wiring Diagrams
JeepDude84
M4050
Jun 12, 2026
Missouri
Please help.....If this is on here somewhere or someone knows where I can find a wiring diagram for a Kubota M4050. I think its an '85. Called my local dealer and they said they dont even have it because it was a weird time or something. Any help would be appreciated.
JohnDB
M4500DT with FEL, back blade, Someca K28 hay mower, drag broom, post driver
Jun 9, 2018
551
183
NZ
Welcome to the forum :) If you can't find a M4050 diagram from Kubotabooks.com, or someone here, the M4500 diagram is probably a close approximation. That's available on Kubotabooks.com.
Hugo Habicht
G1900
Jun 24, 2024
1,542
2,237
Ireland
.... the M4500 diagram is probably a close approximation.
Caution with "approximations".
They are a great opportunity to waste time.
Like I did on my tractor looking for an electrical fault and then found out the schematics were from the correct model but an incorrect year.
Wrong information is typically worse than having no information. ;)
JAVIER LOPEZ
L1361 tractor with front loader
Jun 15, 2026
Barcelona
Hello,
I am new in the forum, just bought a second hand L1361 tractor with front loader and got the operator, maintenance manual (in spanish) and parts catalog from the previous owner that I will be happy to share if somebody need it. Does anybody have the wiring diagram from the L1361?
Thank you,
eglaude
ZD18 Mower W/54" Deck, L3400 Tractor, JD Gator 4X2, and chainsaw/tracto addict
Jun 14, 2011
10
Richmond, TX
Howdy GeoHorn, quick one you, and some of the other guys if they spot this post, is this L2650 wiring diagram pretty much that Kubota has used for the L3400D modei? Looks pretty close but that line works better when your playing horseshoes! If you got an in for a L3400D please post it up when you get a minute please.
Thanks a lot my friend.
11,023
The l2650 is not even close to a L3400
