A truck and trailer thread.
10,939
That is some strange marking on those rotors. Is pad material coming off the pads I have seen that happen. In all my years around heavy duty disc brakes I have never seen that much slop between the wheel studs and rotors. I would wonder if some of those Fords have different sized wheel studs. Its been a long time since I have had to put a set of rotors on a ford super duty. My super duty doesn't have that kind of slop. Even my semi grain trailers with disk brakes don't have that kind of slop between the rotor and stud. I wonder if they didn't sent you the wrong rotors. I would also check all your bushings on your front axle to make sure its not moving when your braking and making a noise. I have had that happen on the super duty's with some miles on them the bushings wear out.
I can't feel any material on the rotors so if the pad material is coming off it's depositing in a very even manner. One of the reasons I ordered new torque wrenches today is that I'm wondering if it's a wheel lug nut torque issue. The Ford spec is 150 lb-ft to 165 lb-ft and I remember setting the torque wrench (which broke yesterday) to 150 lb-ft. I went into town yesterday and had one or maybe two soft "thumps" when braking. Not immediately when braking but at some point in the process. It's plausible that the rotor it moving under braking but I'm not sure.
Once I can torque the lug nuts with some confidence that they're in spec, if the thump persists I'll look at other things such as the bushings and any other related parts.
Thanks.
3,435
I had a somewhat similar issue with a '99 LHS.
Out of nowhere it developed a sort of intermittent thumping noise when braking, but it was accompanied by a brake pedal pulse & you could feel it in the steering wheel also.
Turns out a plastic grocery bag had gotten lodged on the caliper/rotor and melted from brake heat, bleeding out plastic residue from the rotor holes/slots when the brakes got hot enough, apparently causing either a sticky spot or a slippery spot.
My mechanic tried to clean it, but finally had to replace that brake setup,
armylifer
Mar 26, 2013
2,267
1,037
Thurston County, WA
You might try backing up and braking hard. Then try going forward again and braking a little hard and see if the thump happens again. My theory is that if the thump can be replicated in this manner that the slop in the disk is probably causing the thump. I think it is worth a try anyway. What have you got to lose by trying that?
10,939
I had that same thought and figured it was my reversing/braking that rotates the rotor one direction, and then at some point it rotates the other way and "thumps" and remains there until I reverse and brake again. Are the holes in the rotor oversized, maybe. Is the lug nut torque in spec, maybe. I can verify the latter next week when the new torque wrenches show up.
I replaced the windshield washer nozzles last night and just about froze my hands in the process. It's incredibly annoying and dangerous to drive around with ineffective or inoperative windshield washer nozzles. $5 per nozzle and $5 shipping from RockAuto got it done.
10,939
I guess you get what you pay for. I tested the Dorman windshield washer nozzle this morning and the pattern isn't good at all. Way too low compared to the factory one on the passenger side. I tried to take a photo of the pattern but not easy to do while driving. I called the local Ford dealer and they had two nozzles in stock and it was $48.60 for the pair!!!! 😮
I compared both using a loop and the difference is very apparent. The difference in quality of the injection molding is obvious, not to mention the geometry difference for the part that controls the pattern. I guess I wasted $15 buying Dorman crap from RockAuto. I bet Ford's cost on that nozzle is around $0.10 each but it's a serious safety feature i.e. having the ability to properly clean the windshield, so what is one to do other than pay the man.
A .50 BMG case works well to hold the nozzle for close up photography work! :)
10,939
After today's test drive to town I'm more and more convinced that the rotor is rotating relative to the hub and causing the thump. I heard it today while backing up, then it happened again the first time I braked moving forward after I'd backed up, and then didn't happen again (I didn't back up after that) despite some braking with a lead foot to test out the hypothesis.
armylifer
Mar 26, 2013
2,267
1,037
Thurston County, WA
It sounds very much like the slop in the brake disks are at fault. I am thinking that you were given the wrong brake disks when you replaced them. Did you replace the old ones because they were compromised or was the reason just because you were in there already? If you still have the old disks, can you take a inside caliper and measure the diameter of the lug holes on the old ones compared to the new ones? If the hole size is different maybe consider talking with the place you bought them from for a replacement. I think I read earlier that you got them from NAPA. Our local NAPA dealer is pretty good about making things right if they made a mistake. Maybe yours will too, if they gave you the wrong part.
10,939
The rotors and pads are from Power Stop. I would expect the holes in the rotors to match the holes in the wheels. There is a bit of play of the wheel on the lugs so maybe clamping force is what prevents this sort of thing. I'll know more next week.
I just replaced the Dorman windshield washer nozzle with the Ford part and it's night and day difference. The spray pattern is as it should be and the nozzle fits in the cowling better too. The last photo shows the spray pattern from the Dorman nozzle which barely gets above the bottom half of the windshield. I'll email RockAuto with photos and tell them that they're selling junk parts and see if they respond. Another example of the aftermarket doing a junk job of making "equivalent" parts.
biketopia
Feb 15, 2024
399
416
Warrenton VA
Unless your wheels are very loose, I'm not fully convinced your rotors are moving; the holes look normal. We have a fleet of over 200 SuperDutys and I have been doing breaks on them for 20 years. I don't see anything abnormal, are there witness marks on the threads of the wheel studs? I'd be investigating bushings, leaf-spring hangers, u-bolts, and even ball joints.
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,202
3,516
One issue I need to address with the F-250 is an intermittent soft "thump" when braking, and thought it was something in the DECKED drawer system sliding around. But after removing various things and realizing that I can feel the thump in the floor of the truck, I figured it has to be something related to the brakes themselves. I'm not able to reproduce the "thump" on demand and it seems random enough that I haven't been that concerned about it.
Last year I replaced all four rotors and all sets of pads using Power Stop products, and even replaced the front calipers with Ford remans from NAPA. This was done around 5,000 miles ago with no issues until recently. Around 4,000 miles ago I replaced all the soft brake lines too with teflon lined stainless steel hoses and flushed all brake fluid and power steering fluid and bled all the systems. The brakes were the best they've ever been and still seem to work well.
This afternoon in 20°F weather I removed the front driver's side wheel and looked around. I've done too many brake jobs to count over the years and have replaced many sets of rotors and pads, but I can't remember if the "slop" of the rotor over the wheel studs is normal. I can spin the hub and the studs will move in the rotor holes and I show the two extremes below. So now I'm wondering if the rotor is moving during breaking, not always but sometimes. I should have checked the lug nut torque values but forgot to do that. The spec is around 150 lb-ft and it would make sense that the rotor could rotate relative to the studs if the torque wasn't high enough since it's clamping force that prevents the rotor from slipping if the holes are oversized. Does this amount of play of the rotor on the hub seem normal or are the holes oversized?
Another thing I noticed is that there's some weird smudging on the rotor but I can't feel it at all. It looks like I should be able to feel it but it's silky smooth.
Can't say I ever recall seeing wear patterns like that.
  • Sad
10,939
I'll figure it out, but these things aren't much fun to figure out when it's really cold out. Problems seem to like to show up at the worst times.
10,939
I helped my neighbor hook up his truck to my Kaufman trailer this morning. He doesn't have a gooseneck hitch so is borrowing my B&W set. I'm not loving how he chained his truck down but the front suspension is coil over with control arms so not the easiest to work with. His older Chevy probably has a cracked head so it's off for a two-week visit to a local diesel shop.
I showed him the two new Mytee Products binders that I bought a few months ago but he was skeptical about taking the tension off them to release them so didn't use them. šŸ˜‚ I was hoping I'd get to see them in action but I guess I'll have to wait until I haul tractors around this spring.
By the way, he recently got his truck wrapped and I'm impressed with the thickness of the wrap and the overall quality of the application.
10,939
To all those doubtful that the soft thump when braking was due to a rotor turning on the hub .... you get a gold star! ☺I checked the lug nuts this morning with the new TEKTON torque wrench set to 159 lb-ft and all 32 were fine. A trip to town revealed the soft thump to still be there.
Looks like I have some investigating to do. Overall though the truck is driving very well, and the new VisionX lights will be here on Thursday.
armylifer
Mar 26, 2013
2,267
1,037
Thurston County, WA
I was going to hold off on this suggestion until I heard back from you on tightening the lug nuts. Now I am wondering if it could be one of the brake calipers.
10,939
I installed refurbished brake calipers (Motorcraft from NAPA) and made sure to grease the caliper pins. There was mention of ball joints and I bought MOOG ball joints a few years ago with the idea to swap out the original ones. This is the time when I really wish I had a lift at home. It's much easier to push, pull and pry on suspension components when the vehicle is up on a lift.
I'll look at the sway bar, leaf spring u-bolts, shocks and more as well as the calipers. Something is causing the intermittent soft thump which is more annoying than anything. I like things to work properly and clearly this isn't the case. I had hoped it was the DECKED drawer system that was moving fore/aft. I noticed last year that the front mounts inside the front "ammo cans" were broken and reached out to DECKED who sent me upgraded parts at no cost. I bought the drawer system in July of 2019 so it was very good of DECKED to take care of me with replacement parts. I haven't replaced the mounts yet so it could be that, but I feel the "thump" low down in the floor of the cab.
I'll update once I've figured it out. (y)
10,939
That expression "I'd rather be lucky than good" comes to mind.
The F-250 has "shift on the fly" in the form of a knob/dial to select 2WD, 4WD HIGH, 4WD LOW but also has front locking hubs. The system uses vacuum from the engine to engage/disengage 4WD. I typically have the front hubs locked in during the winter, and when I was checking the torque of the lug nuts last week I decided to unlock the hubs since winter seems to be over, not that it ever really started. So now a week later I haven't heard the soft thumb when braking since unlocking the hubs.
This should make it a lot easier to figure out what's causing the thump. With the hubs locked in, the front axles are turning along with the front differential (I think). I'm much more familiar with my Jeep's 4WD system than the Ford, but I'll investigate when I get back from yet another trip. A bad u-joint would be the most likely suspect but I would expect it to be consistently bad and not intermittent.
I'll follow up once I have this figured out, but the truck is driving really well with this one exception. The new VisionX lights came in so that'll be another project when I'm back, but surgery on both hands on March 3rd is going to limit my wrenching activities for a while.
6,697
From what you are describing it sounds like more suspension/steering component related to me. If it were a braking issue in the front, you'd be feeling it in the pedal or the steering wheel.
Check the ball joints and sway bar bushings.
10,334
Front drive
Front driveline U-joint or spline issue comes to mind on this.
10,939
A bit of an update. The soft thump is 100% due to the front locking hubs (or hub - driver's side). The driver's side was "sticky" and after engaging/disengaging multiple times, I've yet to hear/feel the thumb when braking after a few hundred miles of driving.
I will admit with some embarrassment that I intuitively thought that turning the hub lock clockwise locked the hubs, and counter-clockwise unlocked the hubs. Boy was I wrong. There are no markings on the hubs, and after looking at the owner's manual I learned that it's opposite to what I assumed. Not the end of the world since it shows that the "shift on the fly" that locks the hubs and transfer case is actually working.
The hub lock feature is really to allow 4WD to be engaged in the event of a failure of the vacuum system at each hub. Running in 2WD with the hubs unlocked is the most fuel efficient since the front axles aren't turning, and there's less wear on various components. Now I have the hubs unlocked and have tested locked hubs too and no thump so I will need to take a look at the hubs this spring and see if they need to be serviced or replaced.
I added images below of both hubs in the AUTO position (unlocked) and the dimple is obvious on both hubs, but if there was ever an arrow with AUTO and LOCK it left the chat a long time ago. I've owned this truck since 2018 (bought from a friend/original owner) and I've never seen any markings on the hub.
Driver side hub.
Passenger side hub.
10,939
Dammit! I think I was right that clockwise is locked and counter-clockwise is unlocked which makes sense to me. I think I was interpreting the drawing in the manual incorrectly. In order for the LOCK arrow (missing on my hubs) to align with the dimple, the hub would need to turn clockwise. I guess I need to raise the front of the truck at some point and convince myself that the hubs are locking and unlocking. Sorry for the confusion. :unsure:
