Front loader for a B7200
Hugo Habicht
G1900
Jun 24, 2024
1,485
2,134
Ireland
Thanks Hugo. Were you thinking the top, bottom or both ?
I think the bottom point closer to the tractor (when bucket is up, start of your video). This way you get a better angle when the bucket is fully tilted forward. Not too much though so that it does not affect the bucket up angle too much.
3,697
2,270
Thanks - all suggestions, and photos, gratefully received.
Just spit-balling here, but maybe the four-link arrangement bears consideration. You'd have to provide a support for the bottom pivot, but you could keep the single cylinder.
Paul Allwood
Kubota B7200HSTD, RC60-72H MMM, homemade FEL, forks & ballast box, rotary hoe
Jul 8, 2025
527
855
Thanks for the suggestion. More food for thought.
I've never seen that done with a single curl/dump cylinder - maybe it's possible ???
torch
Jun 10, 2016
2,869
1,110
Muskoka, Ont.
A little time modelling with paper and pencil or CAD software can save a lot of grinding. And there are a number of online calculator websites that can help calculate the hydraulic forces and pressures required. When I built mine I had the geometry pretty much worked out in advance:
NOTE: you will see I played with the link idea and had that geometry worked out but in the end abandoned the plan due to the added weight. The extra steel doesn't seem like much at first blush, but really does start eating into the meager 500# lift capacity envelope I was aiming for.
Paul Allwood
Jul 8, 2025
527
855
Thanks for all of this. A better drawing before I start grinding is probably a good idea.
Paul Allwood
Jul 8, 2025
527
855
I've been thinking about how to modify my loader to fix the "won't curl back" problem described above. Since I'm going to be modifying it anyway, I'm considering going back to my original plan of making it mechanically self levelling. At the moment I'm mocking up a version that was designed by @torch that he included in a comment above (see his pic below). Also thinking about a mod to the top levelling arm so that I can pin it to either the normal spot or directly to the top loader arm to allow the self levelling to be easily enabled or disabled.
From what I've read, the main advantage I can see with self levelling is when being used with forks, and the main disadvantages are added weight and reduced curl when raising the loader arms.
I'm interested in your thoughts.
If you have self levelling, do you like it, or do you wish you didn't have it ?
If you don't, is it something that you wish you had ?
Is hydraulic self levelling worth looking at ? I started looking and can find descriptions of valves, but not much luck finding a self levelling valve for sale anywhere.
torch
Jun 10, 2016
2,869
1,110
Muskoka, Ont.
Also thinking about a mod to the top levelling arm so that I can pin it to either the normal spot or directly to the top loader arm to allow the self levelling to be easily enabled or disabled. From what I've read, the main advantage I can see with self levelling is when being used with forks, and the main disadvantages are added weight and reduced curl when raising the loader arms.
It would have to be more than a pin. The pivot is one side of a parallelogram. At least one other side has to be disconnected first or something will bend/break/fail.
I don't see any advantage to disabling it. One issue with a simple, lightweight, fixed, non-levelling design is that when hoisting dirt in a bucket, at max height the bucket can spill out the back and dump some material onto the hood of your tractor. The self-levelling capability would maintain the bucket orientation through the arm's range of motion.
mdhughes
L3901DT
Dec 10, 2014
1,449
1,478
Ste Geneveive county, MO
I don't know about all self-leveling FEL, but "Tractor Time with Tim" has shown that you can't curl the bucket back as far on the John Deere 120R and 220R.
Don't know if all self-leveling FEL are like that.
Paul Allwood
Jul 8, 2025
527
855
Thanks - some good videos. In one he mentions a JD 520M that is mechanical self leveling and seems to curl and dump a lot further than the 120 or 220R.
Paul Allwood
Jul 8, 2025
527
855
I've been looking for hydraulic self levelling loader valves but they don't seem to be too easy to find here in Australia. I found this Eaton valve in the US on eBay. Has anyone had any experience using it for a hydraulic self levelling loader ?
My limited understanding is that is works by taking some of the oil from the rod end of the boom cylinder and feeding it to the cylinder end of the dump cylinder as the boom is raised. I guess the opposite happens when the boom is lowered ?
Thoughts - if I decide to go ahead with self levelling, do you think this valve is a good or bad idea ? How common is hydraulic self levelling ?
