chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,925
2,369
Near Lancaster, PA, USA
I'm not 100% certain that it's the heat. The white/yellow hoses are always the ones that end up with stored pressure. I never had the red/blue need relief. If it's all temperature-related why don't the red/blue hoses have pressure on them? Something else afoot?
I'll need to look more closely at this with my FEL. Maybe I sometimes don't allow enough time for the last of the pressure to bleed off?
WFM
L3800
Apr 5, 2013
1,557
1,012
Porter Maine
Removing and reinstalling the FEL isn't difficult. I've had mine in and off a lot. I have a snow plow mounted on an extra SSQA plate that is on all Winter. The other three seasons the bucket is on the FEL and it's removed and parked in the shed. The FEL is reinstalled whenever it's needed for a task.
When removing the FEL, I get it all unpinned and back away a bit with only the hoses attached. Then I shut the tractor down and keep moving the joystick till pressure is all equalized. THEN I disconnect the hoses. When reinstalling I stop short of the frame to get good access to the hose connections, hook them up and them drive the rest of the way into the frame.
Ill probably give it a try. Once the heat breaks. Park the fel in the shade if I can. Lube pins ect before re-attaching.
nerwin
Nov 13, 2024
602
1,611
Vermont
youtube.com
It may still have a pressure difference parked in the garage. Like others said above, easy to release the build-up.
They don't mention this when taking the FEL off. The videos simply show them taking it off and putting it back on haha.
WFM
L3800
Apr 5, 2013
1,557
1,012
Porter Maine
Tried to get my field bushhogged today.
But the 'heat dome' did me in. I got it half done.
Plenty of wild maine blueberry growing.
Looks like a good crop.
Reactions: 10 users
S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,543
3,794
PEI Canada
Looks like there was a big ball of wool mixed in with the sheep $hit! Hopefully you caught it before it blew over to the neighbor's property like a tumbleweed! 😂
That's Daisy, she just got a trim Friday and only has about a third of the fur now.
Before pic, she likes to be comfortable😄
mdhughes
L3901DT
Dec 10, 2014
1,396
1,267
Ste Geneveive county, MO
I have had mine off many times and this is the first time that I have had to releave the pressure on it. But this is the first time the temperature changed this much. It doesn't tale much of a rise to cause the pressure to build since the hydraulic fluid doesn't compress and expands as it warms.
S-G-R
Jun 17, 2020
1,543
3,794
PEI Canada
Put the seedlings on skids. Corrected total is 137.
Moved a few things around while the forks were on.
Reactions: 6 users
GrumpyFarmer
4,524
I've had this load of wood on the trailer since mid April so it is past time to work it up so I can use the trailer for something else. I started on it the other day.
Over the winter I made the left hand stakes so they would fold down and built the cutting table. This is the first time I used them together.
It started out warm and cloudy but when the sun came out it seemed like a good time to stop.
Just for fun I used my 47 year old HomeLite Super XL that I bought new in 1978.
Today was cool (63*) and windy with a slight drizzle at times. Nice weather to get it finished up before coffee time.
gg
That’s awesome!👏
JonM
Nov 29, 2024
139
299
wisconsin
Well it's good to know that if I ever take the loader off to not leave it in the hot sun haha. Wonder if it would be safe to take it off in the garage?
make sure the hydraulic fluid is at operating temp before which is usually higher than ambient. when it cools it decreases volume sunlight shouldnt be an issue if you cover the cylinders or put it in the shade
chim
Jan 19, 2013
2,925
2,369
Danger. I was having some thoughts.
According to a quick search, it appears that 10 meters of rubber hose will grow by 140mm with a 100°C (212°F) increase in temperature. Steel grows by about 1.2mm per meter for every 10°C. The coefficient of expansion of SUDT2 could be such that the hoses and cylinders shrink internal volume more than the SUDT2 on cooling. With the system components heating up and expanding, not much happens. Excess liquid ends up in the sump.
Making the "container" (hoses, cylinders, hard lines) smaller by cooling it with a fixed amount of liquid inside might pressurize the liquid.
EDIT TO ADD: When I re-read this it didn't convey my thought very well. The last sentence that is now separated was to imply what would happen if the FEL would be disconnected while hot, then left to cool.
mdhughes
L3901DT
Dec 10, 2014
1,396
1,267
Used the L3901DT to move my ash pile. Move almost 3 bucket loads.
Then gave the tractor a little bath. Didn't do a really good job, it was over 90 degrees.
10,014
57°F for the high here today, and after a few days of rain it was perfect weather to move some dirt and widen the transition to the second driveway. When I bought the new 30ft gooseneck trailer home a couple of weeks ago I asked my neighbor to mark the grass with line paint as I made the turn up the hill. I asked him to offset the line a couple of feet from the trailer tires. The gooseneck cuts the corners quite a bit so my initial entrance wasn't even close.
I'm in no hurry with this second driveway and will continue to chip away at it. The box blade fills up really quickly but the M6060 and the EA work well together. I've started clearing for the new barn/shed too and this driveway will split off to the new shed as well as head up to the house. If I can get the shed built before the snow comes, and get some 1-1/2" pit run down on the driveway I'll be more than pleased. If not, I'll live with it.
Reactions: 9 users
Gaspasser
L6060, FEL, forks, front snowblower. KX033 mini ex. Dump truck, Husqvarna saws.
Dec 16, 2023
394
610
NH
Box bladed the mud and organic material covering the crushed stone driveway that was deposited by the loggers. Trying to get down to original top layer and then will topcoat with new stone. Continued stumping and clearing slash. Tomorrow will hook up chipper.
Bmyers
May 27, 2019
3,519
4,529
Southern Illinois
They are resurfacing the road next to the farm and redoing the drainage and such. A gentleman stopped by and was wondering if he could park some of his construction equipment on our property while the work was going on. He said that it would for about two weeks. I explained what space was available and he though that would be perfect.
Didn't expect anything for it in return, was just trying to be helpful and it wasn't costing us anything. He asked if we would like some asphalt millings to use on our driveway or for whatever. I said sure, we had several projects that would be handy for.
Well, we ended up with what appears to be about 50 tons of asphalt millings, which is wonderful because that will help us with the driveway repair and improving the access to the barns.
Reactions: 14 users
6,185
We had some rain in the am yesterday which cooled things off enough to get a pile of millings moved out of my driveway. TWP milled my road and left me 25 yds...was hoping for a bunch more. Anyway, they'll be put to use soon enough.
almost done
Reactions: 12 users
Old_Paint
Dec 5, 2020
1,944
2,130
AL
I cracked a headlight lens on my tractor and just ordered a replacement assembly from the dealer.
My tractor i bought new in 2013. I've never removed the FEL. So I'm very very skeptical about doing it now. It would however allow alot more room to work to get the headlight assembly out and in. If I was a skinny twenty yr old id flex under the hood better. But I'm not.
Most skinny 20 year olds can’t afford a tractor unless they inherit it. I said most, not all. We all seem to get the things that are hardest to work on after we get too old and stiff to do the work. But yeah, getting the loader out of the way is a brilliant solution to bruising ribs on the boom.
S-G-R
Jun 17, 2020
1,543
3,794
PEI Canada
Nice score!
BBFarmer
Jul 12, 2024
789
1,621
Terry, MS
OK, I'm going to admit no being able to understand this. Could you explain it to me (and maybe one other person on the planet who also doesn't get it)?
I'm right there with you. How does this actually happen @JonM ?
5,424
Mostly a tying up loose ends day for the L today. Started by bush hogging the top and ends of the dam, mostly so I could drop the bush hog and do other things before it got stupid hot. Sorry, no pics.
Put the loader back on and ROPs back up. Dropped the bush hog in favor of the trailer mover and got out the wood splitter to finish the last few rounds before covering the most recent wood pile.
Then closed the gate on the driveway from the public road to the old tobacco field / meadow we added about a year ago. The gate is the logs. There’s a culvert there under the log on the ground where there was a driveway that went to a detached garage for a house that’s been gone at least 25 years. I moved them recently to allow access for a contractor to do some work but that’s over, so time to close it off again.
This picture with the logs. Ever take a picture and when you look back at it you see something that makes you wonder how in the world you didn’t see that when you were taking the picture? Well, I sure did with this one. I jumped off the tractor, snapped a pic to maybe post later, hopped back on and didn’t look at the pic until about 12 hours later. That thing by the near end of the log on the ground: I didn’t notice that at all when I was out there. It’s right at the end of the culvert. At first, I thought it was the construction workers at the development across the street letting some packaging blow over to our place (not unheard of). But as I zoom in on it, it looks to me like maybe somebody lost a skid plate there. 🤔
Whatever it is, I’ll have to move it so it doesn’t clog up the culvert. If the culvert gets clogged, the water will run across the road, down the embankment and into the back side of the new houses in the development. Hmmm… maybe I’ll just leave it there a little bit longer.
