Kubota b2150 HST not working
ruger1980
L4310 w/La682, L225
Oct 25, 2020
528
210
CNY
No that is case drain to the reservoir. It is very low pressure. The filter is charge oil but I don't know if there are any taps there to connect a gauge.
If it were me I would probably use a modified banjo bolt in the line from the hydraulic outlet block to the filter housing to test. I have a bunch of them modified by drilling out the end and tapping to 1/8 npt for just this purpose.
3,501
2,094
That sounds like a good plan. Since the power steering works there should be adequate flow to the hydrostat. The relief (back pressure) valve may not be providing enough charge pressure.
Matoyan
b2150 and b2320
Oct 30, 2024
78
9
Rhode Island
how would I test the relief valve or is that something that needs to be done at the dealership?
3,501
2,094
You can do what @ruger1980 suggested in post #61. In an early post, I mentioned testing the pressure at the transmission, but it requires special fittings. What he suggests will accomplish the same thing. Any means of measuring the pressure in the line around the filter would work. It should have <100 psi at that point. Tee in, don't deadend it.
Matoyan
b2150 and b2320
Oct 30, 2024
78
9
Rhode Island
Could you post a picture of the modified bolt?
ruger1980
L4310 w/La682, L225
Oct 25, 2020
528
210
CNY
This will give you an idea of what the modification to the bolt is or you can purchase bolts like this, but make certain what size bolt you have on your machine. They can come in 10mm, 12mm, 14mm, or 16mm.
Personally I have just drilled out the center on my bolts and tapped them with 1/8npt to install a fitting to connect my gauges to.
Matoyan
b2150 and b2320
Oct 30, 2024
78
9
Rhode Island
I went and was checking the tractor over and making sure all of the fittings and such and decided to lift tear end and see what happens. The wheels definitely turn in all 3 speeds both forward and reverse but I did notice that it’s very easy to stop the turning with your hand. The other side still spins though.
ruger1980
L4310 w/La682, L225
Oct 25, 2020
528
210
CNY
That is the function of a differential. It allows the drive wheel speeds to differentiate from each other. You can stop one wheel and the other will spin at twice the speed as both would normally.
3,501
2,094
Can I unscrew the check and high pressure relief valves and the charge relief valve to inspect them?
If you can't test the relief pressure, take it to the dealer and have them do it. The relief valve doesn't come out that way. That view is of the end of the relief valve.
ruger1980
L4310 w/La682, L225
Oct 25, 2020
528
210
CNY
The charge relief is only able to be removed from inside the case. The charge check/high pressure relief can be removed but unless you see something visually wrong there is no way to determine of the are faulty. If the issue is with a check or high pressure relief it is generally in one direction and not both. And if there were an issue with a neutral valve it would also likely be one direction not both.
Matoyan
b2150 and b2320
Oct 30, 2024
78
9
Rhode Island
So you made me think. I went and tested the tractor again and reverse always works better than forward. It still won’t climb a “hill”, but reverse seems to work better than forwards.
I’ve ordered the new bolts so that I can check pressure.
Matoyan
b2150 and b2320
Oct 30, 2024
78
9
Rhode Island
I gave up on the tractor and sold it to a young kid that wanted to take it apart and rebuild it. I lost some $$$$$ on the deal but the unknown was stressful and I have my garage spot back. Thank you for all the help.
Satsuma
B5100
Sep 16, 2018
14
Ireland
So, I have pretty much the same issue with my b2150, I will probably post some questions once I have worked my way through the steps already posted. It does the same, struggles to climb. I did change oil and fuel filters, to be honest I have not even tried the clutch check or cleaned strainers. Dumb question, where are the strainers? They were on the bottom in one of the hydraulic lines on the last Kubota.
Satsuma
B5100
Sep 16, 2018
14
Ireland
Initial results, adjusted the stop valve on the hydraulic head and it runs much better. Now getting smoking from the fan belt......hopefully just because it's not been run properly for a while and need a new belt
