Old_Paint
Dec 5, 2020
1,955
2,143
AL
I have been noticing more and more Kubota replacement parts have been coming from China.... So after the warranty is up, order the cheap clone filter(s) and cut one open and compare it to of the used "Kubota" ones.
Yeah, it's the way of things these days, but here's hopin' some good ol' Murican parts will start showing up over the next 4 years. I kinda figured they were Chinesium parts, to fit a Japanese tractor, assembled and sold in the USA. I'd say our tractors are quite culturally diverse.
Old_Paint
Dec 5, 2020
1,955
2,143
AL
Straight trans fluid...wait, that sounds weird.
Undiluted transmission fluid is what I used last.
I used to apply old engine oil and cut that with diesel. However, that does leave the trailer deck a bit sticky/dirty. The trans fluid is a much better option.
I'm doing the 50/50 Diesel/used oil mix. It's a trailer, not a show car. Got the first coat on before screwing the boards down, and will be putting a second coat on after I get it finished. Probably be slicker than greased monkey snot on a boiled egg when it's wet, but I'm not typically using an open trailer when it's raining, either. Rain means too wet to tractor and too wet to build. Snowing means the global warming theorists were LYING in Alabama. Now that I've put that in print, I'll probably get arrested because a greenie will call the EPA on me. If you only knew my luck......
JimDeL
Aug 31, 2022
405
462
Austintown, Ohio
You can always toss a little sand on it while it's still wet. Makes pretty good anti-skid...
EC135P3H
LX2610SU
Nov 24, 2024
17
Georgia
What year model is your SU? Mine's a 2019. Can't say I've ever left the switch on, so I wouldn't notice the problem.
Hope you're enjoying your SU as much as I have mine.
I just got it this year off the dealership floor. Not sure what the manufactur date is?
I am really happy with it so far!
5,161
If you bought it outright, you can request the selling dealer to get you a Certificate of Origin. That is a birth certificate for a tractor.
biketopia
Feb 15, 2024
387
395
Warrenton VA
We got about 8" of the white stuff overnight Tuesday into Wednesday, spent some time clearing the driveway yesterday afternoon. It went a lot better this storm with the skid shoes on the bucket and using the rear blade before it had been run over a hundred times. We don't typically get a lot of accumulating snow in our area, but we've gotten two storms over 6" in the past month, and it's stayed cold so it hangs around. Thinking about a front blade to just have. We don't plan on moving anywhere for the next 18ish years until I can retire anyway.
nerwin
Nov 13, 2024
602
1,611
Vermont
youtube.com
I will warn you when you have a leak like that it does not pull fluid from the reservoir back to the radiator.
So let it cool completely then open the radiator cap and check radiator fluid level directly. ;)
Thanks for pointing that out, I tried to check it this morning but I couldn't get the cap off. I tried and tried and ended up cutting my finger open. I might have to buy a new radiator cap in case I break this one trying to get it off.
What the heck 😤
6,366
What the heck 😤
Were you pushing down on the cap while trying to turn it?
7,144
What the heck 😤
Only take the cap off when cold.
Try pushing down on the cap a little when turning.
Shouldn't be hard to take it off.
Are you turning in the correct direction? Should be lefty loosey-righty tighty....
3,366
Shoot a little lube up under the cap where the lugs are.
Silicone spray, WD-40, or similar
Bmyers
May 27, 2019
3,530
4,564
Southern Illinois
Wrap a little of this around the cap and it should come right off.
10,168
Quite a bit of snow to remove this morning before taking my dog to the vet. We had 3" or more overnight and it was snowing as I was blowing, and it's snowed a bunch more since getting home so no doubt I'll be back out this afternoon or this evening.
