Fixing hole in side of block
Status
Not open for further replies.
Chanceywd
Mar 26, 2021
751
705
central ny
nature
barely able to get the big ag wheel on your japan robot,
you are so fatigue from doing the everything, say you to nature:
please let the robot not come apart, at least for a bit long while you shape your realm some more
Using plated bolts and nails for your filler metal can give off fumes that can make you sick, headaches breathing issues. Zinc, cadmium, galvanized,
Just not a good plan.
jaxs
B1750HST
Jun 22, 2023
1,001
773
Similar to Danbury Shakes aka Mad Hatter Disease. That could answer questions some have about recent developments.
joesmith123
L295DT, BX1500
Mar 18, 2023
296
140
earth
molten land narrative continue:
this narrative really stuck in your head in that:
you were having trouble leveling an area, getting frustrated, ripping apart your Japan robot, what an idiot
wondering why you could not get it to level properly
the angle you run your machine, similar to the angle of how you run your flame
drop you molten into the low area by aiming around the low point turning the higher points into molten and they successfully fill your low point
this discipline / action lead you to now:
like a Japanese artist, your realm is your canvas
you swing that big steel bucket around after playing with the lava, with a new understanding of how to grade your realm properly, instinctually
somehow your rear bracket did not break, but you are nervous it will breaks since now the front support is flexing/broken
later today:
we are fixing to cut an I beam that is laying around, we fixing to melt a massive I beam and go insane with the flame, fusing together your robot so it does NOT come apart again
that bracket that did not break: you are really surprised and amazed that your molten rebar nail bracket complex held, and so amazed/grateful
50 something page into your thread, the narrative beg the reader:
go play you with the molten, your life is bs and all your everything is nonsense
if you play you with the molten, it will solve problem that you have been trying to solve for decade and decade!
i beam: figure you out a way to cut it, and somehow use it to hold together that front support that keep busting
maybe: melt you some 90s on both side of your busted support,
or get crazy and come up with elaborate pattern that will hold
you dont know yet, just keep brainstorm, no decision
also, you do have 2 inch square tube that can be used to make 90s etc
the only problem: using cut off disc difficult, you need miter saw or something expensive
you still aint no magician, that front support busting making all the rest of your robot come apart
try to go cut you that I beam and make your 90s for your support,
if you cant cut them, then you need a special blade for your miter saw
again, your fel valve bust, setup lumber give it support
put you a locking vice onto a bolt head laying around where you broke your weld
tired of your magic trick not working, spread you massive molten longway
your fixing to run out of magic gas if you cannot get your robot to stay put together
woah narrative wont let you go:
"manipulate you the molten and level out your realm are connected left and right foot,
your talent in those is synonomous, in your ability to do them properly
get you better at playing with the molten, get you better at shaping your realm with your robot"
stop ramblin go finish you a magic trick
lost in molten, superman start to lose his power
you ran out of magic gas
million other task you need to get to, and no magic gas to keep magic show,
say you - i wish i had infinite magic gas and play with lava from now until the end
joesmith123
L295DT, BX1500
Mar 18, 2023
296
140
earth
wheel spacer hold together your robot
your robot keep busting through your magic trick
get you a thick wheel spacer, first melt onto the top steel rail, then
heat up the center part of spacer, smack with sledgehammer while it is hot,
bending it the shape you want, then
melt you the entire spacer onto both rails,
in hope your robot stay put together
hit everything with grinding wheel, wipe with part cleaner everything
melt half of your wheel spacer onto the top rail
heat up wheel spacer evenly with big flame, smack it with hammer, weld broke
clamp it back up, go insane with flame connecting your wheel spacer to the steel rail
this time: dont smack it with sledgehammer until all area melted together
big ol flame in left hand, sledgehammer in right hand,
heat up your wheel spacer, smack it with sledgehammer shaping it to connect properly to your 2nd entity
did narrative not tell you already, that
you are your ancestor, in a dreary shop, playing with molten, in 1680 something?
pump you insane amount of gas committed to holding together your robot
thousand plus post into your thread, become you magician to make your robot 1 entity
pump you dollar and dollar of magic gas, make you strides going from bottom to the top
fuse together your robot
hour and hour go by, melt you wheel spacer on your busted support, say you:
if that weld come apart, your fixing to shut thread down and give up completely
5,185
This thread is truly,......UNBELIEVABLE !!!
3,309
"Severely overheating steel primarily damages its structural integrity by causing a significant loss of strength and hardness due to changes in its microstructure, potentially leading to warping, distortion, and increased susceptibility to failure, especially under stress; it can also affect its ductility and impact toughness, making it more brittle and prone to cracking."
Chanceywd
Mar 26, 2021
751
705
central ny
I don't know what you are calling parts cleaner but some of them spray cans like "Brake Parts Cleaner" will make toxic gas when welded over.
Not a joke Joe, the wrong stuff can kill you!
L35
Jun 13, 2010
641
693
CT
Still my favorite thread on OTT 👍🏼
Hugo Habicht
G1900
Jun 24, 2024
1,064
1,547
Ireland
I do not think this old Kubota deserves this treatment. Isn't there some "Kubota Tractor Rights" movement out there somewhere? If not, maybe now is the time to start one?
Chanceywd
Mar 26, 2021
751
705
central ny
Could we start a Kubota Rescue like the dog rescues where they come in and just take them?
Would we have to euthanize some because they are beyond repair or take them to a tractor sanctuary?
Should they have organ donor cards so their wishes are respected and not put thru extreme procedures when there is no hope?
Maybe at least a DNR?
Bill
joesmith123
L295DT, BX1500
Mar 18, 2023
296
140
earth
will your robot hold, proof that your an idiot (the OP)
woah, shape your realm for 30 minute, and
your wheel spacer molten nail steel rail complex holding
you spent 50 dollar just in magic gas to do the magic trick
joesmith an idiot:
reflection: you broke your entire robot because you ran your robot with brackets not attached, meaning
if you would have just stopped your machine and fixed the broken entities, you would not have this big steel mess
you even made a crack in a MAJOR support that was not there because your an idiot
if your robot stay put together, surprised you will be
unbelieveable how big an idiot joesmith is
This is that crack in a major support
Say to yourself you're an idiot
How many time? The number of post in thread!
joesmith123
L295DT, BX1500
Mar 18, 2023
296
140
earth
you mighta broke your starter
i show what happen:
your voltage reading 14 ish near the start solenoid, when you crank, it go down to 12.5, meaning
battery is strong, but
your starter acting like it dont got power, and it cannot spin fast enough to turn on your big diesel
what you fixing to do:
first, try to get the starter from your 2nd d1301 and see if it crank better
you checked all wire, everything tight/strong, hit it with file
take you off your current starter, try to put the 2nd starter
reflection: what an idiot, you went through the entire trouble of building the entire tractor down to the crank,
and you cant get yourself to fix you those last 2 leaky bucket cylinder? what an idiot
fix you your starter, then seal off your leaky cylinder, the kit come in long time ago
leaking injectors: vibration exposing your flaw in your build, couple injector leak, rear one worst leak
woah, up close of your molten wheel spacer connected to your loader rail, it held so far for 5-6 hour of earth carving
take off your exhaust manifold, try to tighten the top bolt on your starter to your engine block, loose and wont fasten, thread strip
take off your starter, hit everything with file, then clean with solvent, put ton on plumbing tape on your busted thread, trying to ground the starter better to block
this could be the culprit, bottom bolt is tight
i show you a leak that is causing you to stress out your 45 year old starter
this leak in your diesel line is causing you to lose prime, then you over work your starter and now have to take fix it
hit both mating surface with hard wire wheel on drill
clean with solvent
wire wheel all paint off your starter
rig up all your hillbilly wiring, try to start it, nope
even put another jumper vehicle to give more power, nope
it still seem to be ground issue, there is a ground wire smoking on the starter, that wire seem weak
try to rig up a good wire where that smoking wire is, see if you can get it to ground better
get your spare starter from your other L295 engine, boom, she start right up
woah, your japan diesel robot complex, that you turn into molten, is staying one entity
the structural magic tricks holding and you are shaping your realm with MIGHT
you finally figure why you cant fix your leaky cylinders,
youre too addicted to riding your big steel japan molten rebar complex
what an idiot
Status
